05-02-2009, 04:28 AM
#211 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,390
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
05-02-2009, 04:33 AM
#212 | |
Ravening for delight
Oddometer: 8,645
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
05-02-2009, 06:25 AM
#213 | |
Thomas
Oddometer: 3,390
05-02-2009, 06:43 AM
#214 |
´¯`•...¸><((((º>`•.¸¸.•
Oddometer: 346
hey GS, if i can get the adapter bracket and axle for my Yamaha forks, the stock bottom triple can be all yours.
on another note (and i know this is a long shot but what the hell, i'll ask anyway), if anybody bought the bracket + axle from JDRadman and maybe won't need it soon, would you kindly sell it to me. please.
><((((º>`•.¸¸.•´¯`•...¸><((((º>`• .¸¸.•´¯`•.¸ Australia in a Land Rover / Central America on a Moto .¸¸.•´¯`•...¸><((((º>`•.¸¸.• |
05-02-2009, 06:59 AM
#215 | |
Thomas
Oddometer: 3,390
05-02-2009, 11:57 AM
#216 |
Thomas
Oddometer: 3,390
Acutally picked up the rebuilt forks on wednesday, but didn't have the time to install them until today. Esp1tech Racing Suspension reworked the stock forks for me. We were hoping he could do a prototype build with these, but the parts needed and work nescessary was just to much to much to be economically sane. Instead we went for option 2 - a complete gutting and rebuild. These can now sort of be compared to emulsion kits, but a bit more sophisticated.
![]() A quick write up, mostly because of the fork boots, but also because if this little gem: ![]() The taper on the top is done by a lathe and the difference between left and right is actually quite big with the left being 6,5mm and the right 7,6mm (= 1,1mm). Japs are renowned for being "within specs", but never more precise than that ![]() I mounted mine at 6,5mm. Espen (Esp1) made a couple of marks in the forks for later use; 1. A dot where maximum compression is and a rubber ring that moves up so you can see how much it has compressed (mute for me) 2. A number in each outer tube under where the forkbrace goes for future reference as to what has been done to these forks ![]() When it comes to the forkboots and forkbrace I've taken step by step pics to show how I solved this dilemma today. This was discussed in the Forkboots thread and I will post this in both threads. I've cut away some rubber where the fork brace will go. You can see where the old zip tie has gone because of the brace, I've relocated the zips this time (pics further down. ![]()
So, tomorrow it's time to do the shock
05-03-2009, 03:55 AM
#217 | |
Thomas
Oddometer: 3,390
As far as I can tell, these are the stock measurements (mine's a bit bent so it might not be 100% accurate) Both C and D was difficult to measure. A: 750 mm (Renthals 740 mm) C: 60 mm (85 mm) (Seems to me the added height would be great when standing) D: 150 mm (165 mm)
05-03-2009, 07:38 AM
#218 | |
KOTW is a myth!
Location: Hey, I can see my colon from here...............
Oddometer: 6,386
05-03-2009, 07:40 PM
#219 |
Oddometer: 781
There is no problem mounting Renthal bars, including heated grips & handguards, it is simply a question of adaptors
I have Renthals fitted with both hand guards & heated grips The height of most Renthals is lower than stock and there is less rake, to accommodate this and clear the instruments & fairing risers need to be used. In my case a 25mm riser was used which brought bar height back to 1/2 inch lower than stock which is what I wanted and I shaved a little out of the Dakar fairing to give clearance I had alloy bar ends machined up simply as spacers to handle the handguards ptherwise they are not needed. Vibration without them is marginally above stock, with them fitted vibration is pretty much nil |
05-04-2009, 04:59 AM
#220 |
Melbourne , outer east .
Oddometer: 913
Quick Question
Sounds like a lot of people have fitted the Yamaha steering stem bearings into the BMW cups . Will a set of Yamaha bearing cups fit into the BMW frame ?
Farkle face , your Beemer looks great . |
05-04-2009, 12:17 PM
#221 | |
Oddometer: 961
05-04-2009, 12:18 PM
#222 | |
Thomas
Oddometer: 3,390
05-09-2009, 12:22 PM
#223 |
Oddometer: 346
hey guys, if you're like me and missed the first time the axles and brackets were offered, post up here (or pm me)!
IF WE GET A BIG ENOUGH GROUP TOGETHER, MR. JDRADMAN WILL HOPEFULLY DO ANOTHER RUN! (but we have to have enough interest in this to make it worthwhile for him) so far i have: 1. drivenbydiscovery 2. john_aero 3. AllOrds 4. Aries71 5. southbound 6. tmotten (* not 100% sure, but interested) 7. tmotten (for his 2nd bike) 8. TrainedChimp (90% sure) 9. Roughshod 10. voomvoom 11. punkamp so post up, and let's get this list filled!!
><((((º>`•.¸¸.•´¯`•...¸><((((º>`• .¸¸.•´¯`•.¸ Australia in a Land Rover / Central America on a Moto .¸¸.•´¯`•...¸><((((º>`•.¸¸.• drivenbydiscovery screwed with this post 05-13-2009 at 09:24 AM |
05-09-2009, 01:07 PM
#224 |
Oddometer: 961
will this possible be the version that has the abs sensor mount
05-09-2009, 02:46 PM
#225 |
Oddometer: 71
Yammie forks parts...
Sweet , i just caught wind of this thread. Cant wait to make this happen. Lookin at a set of forks/triples now.....the parts here should make this a heck of a lot easier.
Count me in!!! |
