Old 09-12-2012, 09:20 AM   #3301
Parx400
Oddometer: 2,028
I sent my forks to house of horse power. They have been making springs custom for this mod.
Parx400 is offline   Reply With Quote
Old 09-12-2012, 11:55 AM   #3302
racergirl479
Flying Merkel
racergirl479's Avatar
Oddometer: 639
They quoted me 450 to do the job, plus shipping. surely they are not the only ones doing this. I want to do it myself and just buy the springs if that is possible? what have other people done for this part?
Marisa
"This bitch don't ride bitch!"
950 ADV
racergirl479 is offline   Reply With Quote
Old 09-12-2012, 12:03 PM   #3303
Parx400
Oddometer: 2,028
He will sell you the springs. He has the valving down for this mod and most people are happy with it. I tired another shop in town on my first round and was not happy with it. Wish I just went with HH the first time around.
Old 09-12-2012, 04:36 PM   #3304
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
Anyone got front Dakar ABS brake line?
Any of you KYB swappers have a lower Dakar w/ABS front brakeline laying around? Trying to avoid ordering a new one for a swap to my old forks on my GF's bike. Mine was w/o ABS.
Mods, forgive if not in swap meet. Captive audience.
Edit: Thanks!! PM/SOLD/SHIPPED!
nomad5326 screwed with this post 09-14-2012 at 09:10 PM
nomad5326 is offline   Reply With Quote
Old 09-14-2012, 07:34 PM   #3305
MCNorris
Oddometer: 5
yz426f fork & triples bolt torques
Hi all,
does anyone know the best place to get the pinch bolt / axel nut torques?
or, even better, does anyone have a list of all the toques?
MCNorris is offline   Reply With Quote
Old 09-14-2012, 07:47 PM   #3306
WayneC1
Oddometer: 2,728
JDRadman ran up a document on axle/fork tightening & torque values
Pretty sure it is included in the notes I made & put online
http://www.f650gs.crossroadz.com.au/ForkUpgrades.html
EDIT, Sorry no it seems I did not
WayneC1 is offline   Reply With Quote
Old 09-14-2012, 09:14 PM   #3307
WayneC1
Oddometer: 2,728
Found the YZ Yoke bolt torque figures but not axle pinch bolts
Yoke bolts, Upper - 18 ft-lbs, Lower - 15 ft-lbs
Old 09-15-2012, 04:44 AM   #3308
Barnman
Barnman's Avatar
Oddometer: 222
6. Install:
 Nut (wheel axle) 1
105 Nm (10.5 m kg, 75 ft lb)
7. Tighten:
 Bolt (axle holder) R. .
23 Nm (2.3 m kg, 17 ft lb)
NOTE:
Before tightening the bolt, fit the wheel axle to
the axle holder by stroking the front fork
from Yamaha manual, hasn't cut and pasted too well, because its a picture in the manual. But hopefully gives you want you need
Barnman is offline   Reply With Quote
Old 09-19-2012, 09:24 AM   #3309
WERA456
WERA456's Avatar
Location: North Ga. (The site of the first major gold rush)
Oddometer: 202
DRZ400sm forks
Originally Posted by wiz.au View Post
Don't know that this helps, but from the Suzuki Web site:
"...advanced suspension front and rear, including an RM250-derived inverted fork."
So I asked a little while ago if anyone knew anything about doing a fork conversion for a drz400sm forks. Someone told me they were the same as the yz forks.
Anyone know anything.
I thougnt it would be nice for me. I also have a Drz if the front ends were the same I could just swap wheels around for whatever tire I wanted at the time. Agressive knobbie, supermoto, etc.
WERA456 is offline   Reply With Quote
Old 09-19-2012, 06:54 PM   #3310
WayneC1
Oddometer: 2,728
There are threads about fitting DRZ forks to other machines, there may be one at f650.com as well, suggest you do a little searching
Old 09-19-2012, 08:09 PM   #3311
michael1968
michael1968's Avatar
Oddometer: 885
Try to find out the steering head bearing size, if the outer diamiter is the same as the BMW / YZ then you may be in luck. Also try asking anyone (on forums etc) who know more about the drz and YZ, if they are the same I'm sure someone would know.
michael1968 is online now   Reply With Quote
Old 09-21-2012, 10:28 AM   #3312
kion
kion's Avatar
Oddometer: 184
Fork oil Weight
Just got back from western TAT about a week ago and the fork seal on the right leg is leaking oil. I got the 46 mm Yamaha forks.Don't know what Richard used so I don't know what to put in. 5w should be fine?
kion is offline   Reply With Quote
Old 09-21-2012, 10:31 AM   #3313
Parx400
Oddometer: 2,028
5w is what he uses.
Old 09-21-2012, 11:04 AM   #3314
kion
kion's Avatar
Oddometer: 184
5w is what he uses.
Nice. Thank you
Old 09-21-2012, 11:07 AM   #3315
Parx400
Oddometer: 2,028
Nice. Thank you
Also make sure and get Yamaha or SKF seals. Don't use any of those seal kits. They are shit.
Times are GMT -7.   It's 08:03 PM.
