Old 04-26-2013, 06:53 AM   #3706
WayneC1
Oddometer: 2,557
It is the axle to run the GS wheel with YZ forks, hopefully the post means that HOH has secured a manufacturer tor them and the caliper mount after taking over from JDRadman/Hawk Engineering but there were no words to go with the post
WayneC1 is offline   Reply With Quote
Old 04-26-2013, 08:07 AM   #3707
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,004
Originally Posted by creola View Post
Pardon my ignorance, but what is that bolt's use? Is it the swingarm bolt or front axle bolt?
Who cares - it's perrty
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 04-26-2013, 12:36 PM   #3708
creola
creola's Avatar
Oddometer: 303
Wayne, do you know what metal they are using for the axle and do you have a dimensional drawing for the caliper mount? I may be able to assist.
'06 F650GS, 80,000+ miles. Flat black "ratter".
creola is offline   Reply With Quote
Old 04-26-2013, 06:55 PM   #3709
Kainic
Almost there
Kainic's Avatar
Oddometer: 385
Originally Posted by xt500nz View Post
anyone else ? these are links to raise the rear of the bike about 1 inch. when you finish the front forks install, then there is the rear to consider.
Noob here on the YZ swap. Does this need to be done if I swap out my front forks? Why and if not what are the consequences?
Kainic is offline   Reply With Quote
Old 04-26-2013, 08:00 PM   #3710
Achtung
Wicked Pisssah Adventurer
Achtung's Avatar
Oddometer: 972
HOH will have the full conversions available shortly. This axle is to replace my damaged one.
Achtung is offline   Reply With Quote
Old 04-27-2013, 02:16 AM   #3711
Gravel Seeker
Thomas
Oddometer: 4,004
I'm no expert, but I think the YZ forks are longer than OEM so youll get about 1" rise on the front.
To compensate you can either lower the forks in the triples 1" or raise the rear 1".
If you lower the front the undercariage might ground out since the YS forks have more travel If you raise the rear you'll need longer side- and centrestands.
Gravel Seekers.com
Hey !
Old 04-27-2013, 07:12 PM   #3712
xt500nz
Oddometer: 43
ultimatly it means that the front of the bike will be raised higher than the back. yz forks are 2 inches longer than original bmw's. tuners advise lowering them 1 inch but no more. you'll still be 1 inch higher after that, so pushing the forks up through the clamps 1 more inch gets your bike level. or the 2nd option is raised links, that lift the rear 1 inch, then push the forks through 1 .
xt500nz is offline   Reply With Quote
Old 04-28-2013, 12:10 AM   #3713
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Nteresting. Didn't realize I need to put the forks 1" up through the triples. Thought I read somewhere that the YZ setup took up part of that length by the upper triple sitting higher vs BMW. Mine sure seems to.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 04-28-2013, 12:51 AM   #3714
WayneC1
Oddometer: 2,557
The YZ upper yoke rides higher than the GS and it varies in height dependant on whether the 250 or 425 yoke is used. The higher yoke mounting soaks up 1/2: to 3/4" of the length of the YZ forks, plus with the lower spring rate of the cartridge system you will find greater static sag is used.
Old 04-28-2013, 04:33 AM   #3715
Gravel Seeker
Thomas
Oddometer: 4,004
Instead of shorter (?) links to raise the rear, can't you just have a longer shock made ?
Gravel Seekers.com
Hey !
Old 04-28-2013, 05:07 AM   #3716
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,951
Going to an 18" rear wheel gives you at minimum a half-inch more height at the rear, usually a little more depending on the profile of the tire used.
GSBS is online now   Reply With Quote
Old 04-28-2013, 05:44 AM   #3717
michael1968
michael1968's Avatar
Oddometer: 814
Yes, I have + 10mm (over dakar) on my shock which gives about + 30mm height and travel.
The difference on mine was less than 1/2 an inch, a lot of the dirt biased 18 inch tyres have a lower profile than the equivalent 17 inch rears.
michael1968 is online now   Reply With Quote
Old 04-28-2013, 05:28 PM   #3718
Aquatic
Aquatic's Avatar
Oddometer: 1,617
What is the cost of the HoH axle kit?
Including the caliper bracket?
Originally Posted by Achtung View Post
Thank you House of Horsepower!
Aquatic is online now   Reply With Quote
Old 04-28-2013, 05:34 PM   #3719
xt500nz
Oddometer: 43
i experimented with a longer shock, but didnt like the look of the linkage block position, it seemed to be lower. a good way to brake the clevis at the bottom of your brand new shock when a rock comes along.
Old 04-28-2013, 08:54 PM   #3720
WayneC1
Oddometer: 2,557
Have emailed HOH to ask for some details and when the kit will be available so I can update the info and links I have online. Will post the response here
Times are GMT -7.   It's 02:07 PM.
