Old 05-27-2013, 10:56 AM   #3781
john_aero
john_aero's Avatar
Oddometer: 1,173
not check this forum in ages.
wow what progress on the forks.
cant belive so many have done it since first few of us did it few years back
some serious looking bikes and all well done
keep the great pics comming
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 05-27-2013, 11:45 AM   #3782
TobyG
be happy :)
TobyG's Avatar
Oddometer: 564
Originally Posted by Aquatic View Post
The clicking and cracking is from the bearings
Ok, at least mine just didnt move at all
Sounds like fun, changing those out is pretty annoying, I just did it myself this winter,
keep us updated with a few pictures of the rusty remains of the bearings
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is online now   Reply With Quote
Old 05-27-2013, 03:54 PM   #3783
Aquatic
Aquatic's Avatar
Oddometer: 1,632
I have to get the damn bolt out first.
Moving up to a 4lb hammer tonight.
I had a breaker bar on it last night. It WILL NOT TURN!!
I sprayed WD40 everywhere I could. Hopefully that somehow makes a difference.
Its a good thing the jerry can for the lawn mower is empty. Otherwise bonfire at my place!!!
2 nights on 1 bolt is just not on.
Rant off
Aquatic is offline   Reply With Quote
Old 05-27-2013, 04:26 PM   #3784
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,843
Rant off
apply heat. use a torch .
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 05-27-2013, 08:37 PM   #3785
racergirl479
Flying Merkel
racergirl479's Avatar
Oddometer: 623
What length of springs have yall used? I will probably order race tech or progressive custom springs but need to know the size, including the shortening... Thanks!
Marisa
"This bitch don't ride bitch!"
950 ADV
racergirl479 is offline   Reply With Quote
Old 05-28-2013, 12:30 AM   #3786
WayneC1
Oddometer: 2,571
Depends on which forks you are setting up
YZ 46mm have a 460mm spring so reduce that by the size of your shortening spacer
YZ 48mm have a 479mm spring so reduce that by the size of your shortening spacer
Here is a link to the Kayaba EU parts list with dimensions for most parts http://www.technical-touch.com/index.php?id=downloads
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 screwed with this post 05-28-2013 at 12:35 AM
WayneC1 is offline   Reply With Quote
Old 05-28-2013, 07:11 AM   #3787
tomatoe333
tomatoe333's Avatar
Oddometer: 2,293
Originally Posted by swamp View Post
i used cycra fender made for the yamaha forks. however the back part of the fender was rubbing on the frame so i cut it off.
do any of you know a way to avoid cutting off the backside of the fender ? are there any that turn down at a sharper angle in the back ?
Use nylon spacers in between the fender and the underside of the triple, on the rear bolts. Might take some experimentation to find the correct size.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 05-28-2013, 01:12 PM   #3788
swamp
swamp's Avatar
Oddometer: 1,843
Enduro Earth
YOUTUBE
Old 05-28-2013, 02:35 PM   #3789
racergirl479
Flying Merkel
Oddometer: 623
Great, thanks! and if I have read correctly, for a conversion on the Dakar (not standard gs) the shortening will be by 25mm. And I will need 25mm spacer. Correct?
Marisa
950 ADV
Old 05-28-2013, 02:42 PM   #3790
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Originally Posted by GSBS View Post
I think the cowling might act as a sounding board for it. It's much louder than the horns on my Victory hack and WR-R, by a factor of 2 or 3 times.
Also, instead of the "beeeeep" sound it had before, it now has a much raspier sound, like what you'd think a cicada might make if it were riding the lightning in an electric chair.
I wound up relocating it again to inside the headlight cowling. Found a spare holt in the metal subframe (big metal bowl bottom). Mounted it on the left. It definitely is loud in there. It seems ring for sure.
Now I have two horns. One looks to be the stock one and the other is off my GSXR750 I think. Took it off when i coverted it to a trackbike. The bi-tone seems to make it much loudder.
Ride more, bark less
Gangplank screwed with this post 05-28-2013 at 03:15 PM
Gangplank is offline   Reply With Quote
Old 05-29-2013, 11:49 AM   #3791
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
trying to keep the mud out of the radiator.
if i use a motard fender wont the mud still get into the radiator?
also, i noticed that switching to the 18" rear caused some bad mojo with the center stand. bike wants to fall forward when front tire is removed. anyone else experience this phenomenon ?
One of these might help...
http://www.twistedthrottle.com/fenda...-bmw-f650gs-64
If my supermoto fender lets too much mud and much get to the radiator I might bolt one of these on or hack off the old one from the BMW fender and use that. We'll see.
Old 05-30-2013, 09:12 AM   #3792
Lupin 3rd
Raygun Gothic
Lupin 3rd's Avatar
Oddometer: 629
According to this guy on SMJ: "I used a piece of 3/4" and 1/2" CPVC pipe and cut them to the length I wanted to lower my front end." That's two separate pieces, one inside the other, pic shows a length of 3 inches, here's the link to the (well written) post:
How-to-lower-the-forks-on-a-YZ450
Lupin 3rd is online now   Reply With Quote
Old 05-30-2013, 09:27 AM   #3793
Lupin 3rd
Raygun Gothic
Lupin 3rd's Avatar
Oddometer: 629
From http://www.f650gs.crossroadz.com.au/ForkUpgrades.html
Code:
                          GS      Dakar  YZ Forks
Fork Travel or Stroke   170 mm   210 mm   280 mm
you would need to shorten by 70mm (just under 3 inches).
Old 05-30-2013, 04:20 PM   #3794
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,424
I shortened mine one inch-- 25.4 mm. According to the best measurements I could the Yamaha forks are 35 mm longer. But the Ohlins shock puts it just a tad taller.
It worked a treat.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug screwed with this post 05-30-2013 at 04:28 PM
Schlug is offline   Reply With Quote
Old 05-30-2013, 04:28 PM   #3795
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,424
Code:
                          GS      Dakar  YZ Forks
Maybe I'm not sure what Marisa is asking here, but I think she'd should be concerned about this:
GS Dakar YZ Forks
Length - Top of upper yoke to axle center
GS 825 mm
Dakar 890 mm
YZ 925 mm
If the static sag is set up properly on both forks, I think distance of top yoke to centre of axle is the key, no?
Times are GMT -7.   It's 11:38 PM.
