Old 02-09-2009, 03:25 AM   #61
WayneC1
Oddometer: 2,737
Ducked down to the garage & took a quick measurement
To the eye wheel seems centred in forks but measurement says
43mm from RHS fork to rim
40mm from LHS fork to rim
Must stress quick & dirty measurement
WayneC1 is online now   Reply With Quote
Old 02-10-2009, 06:45 PM   #62
JDRadman
Moto Head
JDRadman's Avatar
Oddometer: 195
Almost there
I have completed the 3d model and met with my machine shop buddy to get the prototype made. The hanger will look a lot like the one on the Touratech website and we will make one new spacer to get the wheel centered with a new stainless steel axle. Thanks to those that gave me measurements on their wheel to fork set up. Variances of 2-4mm were noted.
I believe that we will need a new brake line to reach the caliper since it will be a bit lower and the forks are a bit longer. I know I will need one since I already have risers on my bars and its already tight.
So here is the question to all interested parties.
Are you really interested? If so, I need commitments sometime next week. No money yet but a good honest commitment would be appreciated so I know how many to run. I will likely only do this once so jump on board and tell your friends too. The more the merrier or cheaper for us all.
If your interested send me an email or PM and I will reply with pictures of the prototype when I get it back before we exchange any money. If you want to see a model of where we are so far, I can do that too.
The kit would consist of:
  • 1 - New Brake Hanger (7075-T61)
  • 1 - Stainless steel custom axle with spacer
You would need to:
  • Acquire a Yamaha YZ 01 to 07 fork and triple clamps and axle nut...
  • Re-spring and re-valve for correct set up. I will shorten my set up by 1" overall and adjust ride height with the triple
  • Be responsible for the bearing set-up, the new brake line and a few nuts and bolts necessary to install it all.
All parts are provided "as is" with no guarantee or warranty. The user assumes all risks for the operation and safety of any use of the parts. Let’s say these are sold for cost, as a novelty only and not suitable for on or off highway use.
If you’re really interested you should contact me off list. I will update my progress on the list but I don’t want to get off topic.
Rad
JDRadman is offline   Reply With Quote
Old 02-11-2009, 02:14 PM   #63
El Cazador
Mama didnt love me
El Cazador's Avatar
Oddometer: 12
could be interested in a pair of gs or dakar oem forks that somebody doesnt want after the switch...
El Cazador is offline   Reply With Quote
Old 02-11-2009, 02:38 PM   #64
JDRadman
Moto Head
JDRadman's Avatar
Oddometer: 195
GS Dakar Forks
Mine will be available very soon...pm sent
Old 02-11-2009, 02:48 PM   #65
El Cazador
Mama didnt love me
El Cazador's Avatar
Oddometer: 12
ok im really on the fence on this one. I need a new front end because of a wreck. I would like to make my gs(not dakar) more offroad worthy while im at it but ive got a 30inch inseam and dont plan on putting a dakar shock in the rear. Also, I am mechanically inclined but the 6000 mile service is the extent of my motorcycle experience (though JdRadman's parts would help considerably). Honestly could this mod make sense for me?
Old 02-11-2009, 04:56 PM   #66
WayneC1
Oddometer: 2,737
The mod would be far better than the OEM forks
Can you advise what damage your front end suffered ?
Old 02-11-2009, 06:38 PM   #67
El Cazador
Mama didnt love me
El Cazador's Avatar
Oddometer: 12
My Bike was parked and was hit squarely on the front end while the bike was at full lock. I Noticed immediatley that front wheel was misaligned and rotor was bent. I have replaced the rotor and (almost) re-aligned the forks by loosening clamps and yanking it back into place. The wheel is also just a little out of true. I have ridden the bike in the last couple of days and, while rideable, the front end feels a little off and I am exploring my options for a fix. I would still like to take the front fork off and apart and see what exactly is going on. My main concern for the yammy conversion is if I can drop the forks in the trees enough to get close to the height of a gs (and inch or two lift is ok). Im also worried that Im biting off more than I can chew because I havent done so much as change the fork oil before. Any advise would be appreciated.
Old 02-11-2009, 10:50 PM   #68
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 1,129
Sounds great JD- pm sent.
Matto
Matto
mattomoto is offline   Reply With Quote
Old 02-12-2009, 04:37 AM   #69
WayneC1
Oddometer: 2,737
El Cazador
Thanks for the info, sorry to hear you were an innocent bystander so to speak, sounds like the culprit did not hang around, even worse.
It is wise to think about expertise in setting up the yamaha front end, perhaps there are people close to you who could assist.
Personally I would not ever consider using an old style BMW RHS fork leg, but my outlook is colored by the fact I have had the axle mount detach.
Old 02-12-2009, 07:39 AM   #70
JDRadman
Moto Head
JDRadman's Avatar
Oddometer: 195
EL,
The following is nothing more than my opinion, so take it for what its worth.
You might want to evaluate the way your riding the bike now and how you would like to be riding in the future. Don't worry about the project complexity. It is not that bad and there will be a way to get it done. Figure out where you want to be first.
If off-road is taking front seat to on-road riding, its worth considering the a change in your front suspension especially considering the unfortunate opportunity to upgrade that was presented to you by the crash and run.
  1. If your perfectly happy tooling around touring or commuting, I wouldn't even bother with the upgrade and find a set of used GS forks and get back to business as usual with the stock setup. This is a great ride either way
  2. If your interested in doing a bit more off-road than the average bear, the Dakar forks may be the ticket to a minor improvement. Stiffer springs (per my TT setup) and more travel will make a huge difference in the bike. Don't forget about the brake cable requirements (you can have mine with the forks). If you have bar risers you can drop the forks in the triples pretty much but you still need to be concerned with ride height and attitude. A longer Dakar model shock would me nice too but maybe not necessary...I just don't know.
  3. If your really wanting to make a big difference in the bikes off-road capability (plus the fun factor) and you can drop a few grand into front and rear suspension, go with the rebuilt KYB 46mm Yammy front end, have the Dakar rear shock re-worked and you have a very different moto to ride. Comfortable on the HWY at 70mph all afternoon and competent on the rougher trails and access roads. Don't forget, its still a very heavy bike. But that's why you need a 400EXC to do the knarly stuff.
So that is my nickle perspective on the F650GS. I have owned mine since 01. It is my only street bike now and I spend 50% of my time 2-up with my wife on back roads and trails. I couldn't see spending the $$ in a 950 or even a new F800GS. My finished product isn't even in the same league with those bikes but I can go anywhere they can, do anything they can (or more depending on who is the pilot), it was fun to build and I still have the $$ in my pocket for other adventures.
Life is so full of compromises.
I hope that helps....but its just one mans perspective.
Rad
Old 02-19-2009, 02:36 PM   #71
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,274
Done...almost
I pretty much completed my swap yesterday. All that's left to do is install the caliper which is coming today UPS.
EDIT: Caliper is now on and I took it for a ride in the field next to CSULB............What a difference! Now to get Javier (Trail Tricks) to rework my rear suspension and tune it.
Total costs were $386 which included:
2003 YZ 426/450 shocks with 11.8" of travel
New .48 Racetech Springs (sock is .45)
New Seals, Shims and Dust Covers
New bearings
Excel Rim
Brake Caliper
Oil
Beer
Had to also buy a new s/s brake line: $50
New total is now $436
SO EASY A MONKEY COULD DO IT!
Only one custom piece needed. The yoke of the Yamaha is 3/16" shorter than the BMW. So you will need to buy or have made, a 3/16" spacer to go under the spindle nut and on top of the top dust cover.
The top bearing of the Yamaha is identical to the BMW and fits the cup perfectly.
The bottom bearing fits the cup perfectly also. You must use the Yamaha bearing as the Yamaha bottom bearing ID is 30mm, not 28mm like the BMW.
Overall, the Yamaha spindle is about 1/8" bigger (stronger).
Took 2 hours flat.
Two drawbacks:
  1. No steering lock
  2. My friend who paid over $3000 for his TT suspension hates me...nothing some alcohol can't fix....Right Jim?
notmybikemodelname screwed with this post 02-19-2009 at 05:32 PM
notmybikemodelname is offline   Reply With Quote
Old 02-19-2009, 02:43 PM   #72
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,315
Excel Rim
Brake Caliper
Oil
Beer
Took 2 hours flat.
Two drawbacks:
  1. No steering lock
wath you going to do with the rear so does not feel like a choper Rob ??
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Old 02-19-2009, 03:07 PM   #73
notmybikemodelname
KOTW is a myth!
Oddometer: 7,274
I was going to talk to you about that on Saturday.
Old 02-20-2009, 04:14 PM   #74
JDRadman
Moto Head
JDRadman's Avatar
Oddometer: 195
Notmybike...,
Cool deal, sounds like you got it done.
I am interested in how the bike handled with those spring rates.
RaceTech's site says the Dakar's stock rate is in the .62 range but I can’t get that verified. RaceTech recommend a .83 rate on the Dakar with my street weight of 160 lbs. So the .48 springs are about half of what they recommended.
While most of us will be riding on a lot less aggressive terrain on the 650 than we would on a YZ, we are still doubling the weight of the bike (low 200lbs to low 400lbs) that is riding on the same springs.
Did you use the stock or supermoto aftermarket brake/rotor?
The BMW OEM brakes are 300mm X 5mm thick disk and the YZ OEM disk is 250mm X 3mm thick. The YZ caliper pistons are about 20/22mm and the BMW pistons are 30/32mm but I am not sure about the differences in the master cyl. I think we would be giving up significant stopping power especially when repeatedly stopping from highway speeds like in the twisties. That may not be in issue at lower speeds in the dirt.
And what kind of Beer would be good to know too...
I think I will end up at about $900 bucks in my forks but far shy of the TT $3,000 set up. When I am done, we will loose 1" travel/length to cut down on the "chopper" setup, have progressive wound - .83ish springs in front, new seals wipers and valving, stock brakes, stock wheel, new caliper hanger, new brake line and new SS axle. I may get the stock rim upgraded to make it stronger too.
The back shock is getting re-worked as we speak. Spring rate will be up about 20% and progressive wound for compliance on the street. It will also raise the rear-end a bit. This and slipping the forks deeper in the triples will help get the geometry back in check.
Overall, I will drop less than a $1,100 into the bikes suspension and I hope I am as happy with it as you are with yours.
I blame my buddy Quinn for all of this excessive spending. He bought a new 800GS last month. I didn’t want to drop the cash on a new bike but I just couldn’t sit still for that. So I had to upgrade…
Rad
Old 02-20-2009, 05:34 PM   #75
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 1,129
Nice bike Notmybike... I too have put my bike on a diet (well, not as extensively as yours, but getting there). Yamie fork will help a bunch and hopefully pair nicely with my Wilber's rear shock.
Rad- my bike must know something is up... My left fork seal took a huge dump today on the trail. Nice flowing of fork oil all the way home. How's the progress coming with the brace/axle?
Matto
Matto
Times are GMT -7.   It's 03:35 AM.
