12-03-2009, 05:39 PM
#871 | |
Oddometer: 545
I want to do what this guy did. I think the 650 has the ugliest headlight/dash.
12-03-2009, 07:47 PM
#872 | |
2 wheels rule
Oddometer: 859
F*** it was 14 degrees today. No riding I need ice spikes the way this winter is going...
Matto |
12-03-2009, 07:51 PM
#873 | |
2 wheels rule
Oddometer: 859
Matto |
12-03-2009, 08:26 PM
#874 | |
2 wheels rule
Oddometer: 859
I will be driving out there 11 or 12th for a race in Bonnelli Park in LA then week off before the Fontana race. What's that big OHV area just past Barstow on 15/40? Worth stopping and riding there?Not sure naked in the hot spring springs with a bunch of dudes in my thing anyway
Matto |
12-03-2009, 09:17 PM
#875 | |
A Serious Man
Oddometer: 2,347
Used an old street pilot for instruments. Can have speed and roadmap all at once. sometimes hard to read in bright sun but so is the Vapors I've seen. Anyway I have never wanted to put the pod back on. Also never gets in the way when the bike falls over. ![]() I made a custom light housing and windscreen from an F800. |
12-04-2009, 12:27 AM
#876 | |
Oddometer: 964
depends on what your going do. i want keep abs as i do mostly road miles and if ever decide sell bike its a big selling point too. but if i had the cash i would have bought an axel and wheel from yz and then have choice of both ways. may still think of that. i wanted original wheel as cash was tight and made my own calliper bracket
women are like clouds....... once they fuck off it is a really nice day.......
12-04-2009, 12:39 AM
#877 | |
Oddometer: 964
12-04-2009, 06:55 AM
#878 | |
KOTW is a myth!
Location: Hey, I can see my colon from here...............
Oddometer: 6,397
Actually, the Springs are usually full of Euro campers. From what I've seen, very beautiful Euro girls and lots of them, and they're very uninhibited when it comes to clothing
12-04-2009, 08:27 AM
#879 | |
2 wheels rule
Oddometer: 859
That's one of the best parts of my job- traveling to Europe and checking out the girls . Eastern Euro are the best.Cool, I'll look you guys up in March.
Matto |
12-04-2009, 11:41 AM
#880 | |
Oddometer: 964
12-04-2009, 11:45 AM
#881 | |
Oddometer: 545
It's from this thread http://www.advrider.com/forums/showt...118105&page=49 I think he kept the stock dash, throw away the steel bracket, used a KTM 640 Adv front fairing and light housing (which is much lighter, also more flexible for the kind of light you can use). I've been trying to score one of those KTM plastics piece for a while now. |
12-04-2009, 10:11 PM
#882 |
Oddometer: 2,282
Am I the only one that is having a shitter of a time getting the bottom bearing back on? I've used the same method as the BM one with a PVC pipe and a mallet but no joy. Also heated up the bearing but still no joy. Can't get it closer than 10mm.
I've done some damage trying to get it back off, so I'll get another setup at some point for when this bearing dies. Got the triple in the freezer now, but I'm not that hopeful. Getting the old one off was just as bad. Man those bearings are tight. Bought an seperator but couldn't use it because of the steering stops. |
12-05-2009, 12:43 AM
#883 |
Oddometer: 785
Freeze yoke & heat bearing, I use the oven when no one is looking
Saw a web site with a simple tool to make once but cant find it right now Lots of luck, will post further if I have any bright ideas |
12-05-2009, 02:58 AM
#884 | |
Oddometer: 313
If you are having a hard time it is because you are using the wrong tools. The bearing has to be pressed on using a hydraulic press. Banging away at it will cause plastic deformations somewhere else that will eventually lead to fatigue cracking etc.
You can even use your cars scissor jack to do the job. I used a bottle jack an made a frame out of a huge section of timber. also make sure you support the bottom of the yokes if you are going to press the axle out. Regards Quote:
12-05-2009, 04:04 AM
#885 |
Oddometer: 785
Kpmatias
This begs the question, since we have a bearing pressed onto a steel shaft which is in turn pressed into an alloy yoke what tolerances should correctly be applied to the interfernce fit on each In addition surely there is scope & perhaps good reason to allow a slightly different tolerance on the bearing seat to avoid difficulties with damage to the yoke ? |
