Old 10-24-2008, 09:52 AM   #1
BlueLghtning OP
Riding is my passion
BlueLghtning's Avatar
Oddometer: 4,997
Source for the Coax connectors on Gerbing heated gear
Anyone got a source for the coax (coaxial) plugs or know the dimensions that are used on Gerbing's heated gear? I tried my local radio shack, but they couldn't seem to match it up correctly and told me they didn't have them?
Maybe if I have the dimensions, I could do my own searching or find the right part number? Is that inside pin 2.1mm or maybe 2.5mm? How about the outside dimension? polarity?
I'd like to build my own controller using the coax plugs.
Thanks,
Dan
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is online now   Reply With Quote
Old 10-24-2008, 12:34 PM   #2
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
I've got the Warm-n-Safe jacket with coax plugs which are likely the same, and they are 5.x mm OD and 2.5mm ID. Polarity doesn't matter to the jacket, but I used outside as ground so it won't matter if the jack touches the frame.
Radioshack does have the correct size, but they can't handle the current. I melted one of their bulkhead jacks.
I would buy some of the gerbings accessory/extension cords and cut them up.
Luke is offline   Reply With Quote
Old 10-24-2008, 01:14 PM   #3
Buccleuch
Resistance is futile.
Buccleuch's Avatar
Oddometer: 1,739
Newark has 'em. I've bought them from Newark to build DC power distribution cables for guitar effects boxes. Newark ships small quantities, and ships fast.
Here's a really ugly link, and I hope it works....
http://www.newark.com/jsp/search/bro...equestid=34182
If it doesn't, on Newark's home page, choose "Connectors" under "Product Categories" on the left, then choose "Power Entry."
Now you're presented with fields to refine the search [bear in mind, Newark's catalog is over 2,300 pages...]
In the "Gender" field, choose "Plug," and in the "Manufacturer" field, choose "Switchcraft."
Then click "Apply."
As you scroll down the page, you should see a number of different "Barrel Power Connectors."
You *DO* need to know the precise dimensions of the pin and sleeve to get the right one. All the specs are listed for each part.
Good luck!
WA.
Buccleuch is online now   Reply With Quote
Old 10-24-2008, 01:22 PM   #4
Buccleuch
Buccleuch's Avatar
Oddometer: 1,739
More...
Here's Switchcraft's page with all the specs, but they're noted in inches...
That should help you get the right part number.
WA.
Old 10-24-2008, 03:14 PM   #5
BlueLghtning OP
Oddometer: 4,997
Buccleuch, thanks for that info. That should get me going in the correct direction!
Old 11-02-2008, 06:07 PM   #6
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,834
while we're here does anyone know if the tourmaster stuff uses the same connector as gerbings and warm n safe?
also, anyone know where to get these in panel mount? Mine are currently just dangling and ziptied and I would love some panel mounts, the ones from radioshack look cheaply made and I can see it melting.
HaChayalBoded is offline   Reply With Quote
Old 11-02-2008, 10:01 PM   #7
JR356
JR356's Avatar
Oddometer: 3,645
Think Warm n Safe is making the Tourmaster heated stuff,so all connectors should be the same.
JR356
JR356 is offline   Reply With Quote
Old 11-03-2008, 11:36 PM   #8
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,291
Perhaps these?
http://www.aerostich.com/catalog/US/...t-p-18924.html
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 11-03-2008 at 11:47 PM
Stretch67 is offline   Reply With Quote
Old 11-04-2008, 08:19 AM   #9
BlueLghtning OP
Oddometer: 4,997
Thanks for the links guys.
I found that a simple 12" coax extension cable is only about $5 which has both the male and female end on it, so you just have to splice it and add it in. Not the cleanest look, but it works and $5 for 2 connectors isn't bad.
Old 11-06-2008, 12:11 AM   #10
punk_emo_tx
Oddometer: 194
+1
punk_emo_tx is offline   Reply With Quote
Old 11-06-2008, 07:05 AM   #11
VStromTom
Oddometer: 1,579
Hycha, I just stopped by Cycle Gadgets in Eureka Springs, AR and bought the coax to SAE connector made for Gerbings to use on my Synergy. The jacket end of the connector is the same for both Gerbing and Synergy. BUT, the woman at CG said Gerbing has stopped selling that connector because "people were using them for other brands". I got one of the two she had. Seems strange to me that Gerbing would take that tact, who cares what an item they sell is used for as long as it counts as a sale?
VStromTom is offline   Reply With Quote
Old 11-06-2008, 08:44 AM   #12
Buccleuch
Buccleuch's Avatar
Oddometer: 1,739
Newark sells those, too. You can even find the one which have a threaded locking ring to secure the connection.
WA.
Old 11-06-2008, 08:59 AM   #13
Moto_Muffin
Motorcycle Muffin
Moto_Muffin's Avatar
Oddometer: 287
I'm pretty sure Tourmaster is Tourmaster; warm-n-safe is a competitor. Though I don't know for sure.
I have a Tourmaster synergy jacket and the coax connector is the very same thing Gerbings uses. Gerbings gloves work seamlessly with Synergy jacket, Synergy jacket works seamlessly with coax battery connector dongle for Gerbings.
'01 Black R1100S "Rosie"
'08 KLR650 "Bruce"
'00 Honda Valkyrie "Brunnhilde"
Moto_Muffin is offline   Reply With Quote
Old 12-01-2010, 08:08 AM   #14
genka
SUV hater
genka's Avatar
Oddometer: 1,599
I want to bring this topic up because the links above don't work. So the same question: need a source (or dimensions) for Gerbings style coaxial connectors.
genka is offline   Reply With Quote
Old 12-01-2010, 09:50 AM   #15
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 831
Just an FYI, I had to repair my connectors on the jacket that connect the gloves, Gerbings didn't supply just the end so I was going to by 12" extensions (part of the failure in the first place was caused by the jacket leads not being long enough) cut them and then solder them in and cover with heat shrink. I went to buy them online and they wanted over 12 bucks just to ship them! Went to the local HD dealer (it was an expensive trip, my girlfriend ended up buying a 2011 Heritage Softail!) had the leads for less than Gerbings and no shipping.
You might consider the same solution for your controller, out of curiosity, are you using a potentiometer or a SS relay for your controller?
Good luck!
2014 K1600GT Sport
2014 S1000R
2014 HP4C
2011 R1200R
I'm not a glass half empty or full guy, I am just happy to have the damn glass!
Iron Rey is offline   Reply With Quote
Times are GMT -7.   It's 12:15 PM.
