10-28-2008, 11:31 PM
#1 | |
Oddometer: 9,294
GSA high lift jack for the sleeping bike
Mods - I'd like to see this in GSpot at least for a while as I think the GS/GSA's are about the only dual sports heavy enough to need one of these.
I was at DeansBMW's place in Show Low Arizona last Monday and decided to try out the new jack I recently picked up for my GSA. I have dropped the bike a couple of times and not been able to pick it up by myself, which really has me concerned about taking dirt roads when riding solo. This was my last solo ride up Lynx Road in Angeles Crest. I was having a hell of a time trying to get the bike up when a 4x4 truck driver came by to help. ![]() So I started thinking that I would like a light weight motorcycle equivalent to a high lift jack I've used for off road driving. I finally found this site which I thought would fit the bill: http://snowbuddy.com/whysnowbuddy.html Edit May 2010- looks like this web site has been hacked. See post 67 of this thread for a recent phone number that I hope still works. Quote:
The owner of the site has designed these jacks for snow mobiles (snow machines for the Alaska crew). He sent me a lightweight model that he first made for snowmobiles that he decided was just a bit too lightweight for dead lifting and pushing over a snow mobile. He sent me the light weight model with a cordura bag that is great for storage, and also is great to use as a barrier between the bike and the lift cable. For a reduced price (I think about $130) I was sent the full snowmobile jack minus the foot plate and first half a bar, the foot plate being designed for snow. As the jack is made out of 1/2 inch square bar stock (aluminum), I had Dean's welder buddy in Alpine TX (we were in Alpine over the weekend) make up a base foot and about a 10" long 3/4" steel bar with holes drilled. I figure if I need a bit more height on the jack I can get a pin to go through the holes on the 3/4" bar so the 1/2" jack bar slips in and sits a bit off the ground. I gently let my GSA down. The bike is a R1200GS ADV with about 6 or 7 gallons of gas and the cases and top box stuffed full for a week trip, I'm guessing mybe as much as 650 lbs. ![]() ![]() ![]() Here is the jack, actually a snowmobile jack modified with a different foot assy by Don Holms (great welder) at Starsovertexas in Alpine Texas. ![]() The best results were hooking its attaching loop to the cylinder crash bars, which Dean figured out. ![]() ![]() ![]() ![]() After figuring out the best way to place the jack I was able to ratchet the bike up without too much effort. ![]() ![]() ![]() Sucess. ![]() A happy man, able to pick up my loaded ADV by himself. When the bike was laying down in the dirt, I could not even budge it the slightest with any convential method. ![]() The jack worked great using the Adventure tank/engine bar as a lift point. Dean helped me figure out that the best lift point for a GSA is towards the front, and by using the tank bar you get a moment arm off the centerline of the bike. Use the right lift point, use the jack carefully and correctly, and it was pretty easy to get the bike up to a point where I could push the bike the rest of the way up using the butt to seat, hand on bar end and passenger handle (the way the woman rider has people pick up bikes in the video floating around the web). I think even with some injury it would be possible to get the GSA up with this jack. I have not tried it, but the hand grip (handle bar) might also be a good lift point. Also, I did not have to take the cases off the bike to lighten it up. I'm sure I had 100 lbs in cases and contents, and about a half tank of gas. You have to be a stronger than average guy to pick up a GSA single handedly even when pretty empty, much less with a load. The jack inside its cordura case will fit in a GSA top box, although it has to be diagonal in the box. I believe the jack bars are 15 inches. The guy making the jacks is sort of out of the business and is selling off his stock. If this is of an interest I would check it out sooner than later. BTW, I turned down the jack seller's offer for any deals on my jack if others buy, I just wanted to figure something out. The one thing I do not like about the GSA is that I no longer felt comfortable travelling on dirt in back country by myself. This jack cures this problem. For that, its a cheap $150 or so.
Rob '07 White (the coolest color) GSA rider '13 Husky Strada & '05 Honda 400XR
SocalRob screwed with this post 05-23-2010 at 09:41 PM |
10-28-2008, 11:55 PM
#2 |
Tryin Hard
Oddometer: 2,764
cool - great effort and notes. Thanks for taking the time to show us.
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider) |
10-29-2008, 02:14 AM
#3 |
Scratch and Sniff
A little wear and tear is expected. |
10-29-2008, 02:29 AM
#4 |
Oddometer: 278
works well on parking lot... maybe harder in the mud/snow/rocks...
I picked up quite easily my Goldwing fulled up luggages this summer... it does not lean strictly horizontally but it does fall easily ;-))))
GS 06 (sold at 60 000 kms) GS 08, ölhins, HID, TT crash bars and protections, enlarged footpegs, headlights and oil cooler protections, Tomtom Rider 2 |
10-29-2008, 03:25 AM
#5 |
Oddometer: 1,434
Dropped mine twice on Saturday.. Just grabbed the downside handlebar and lifted.
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
10-29-2008, 03:28 AM
#6 |
Adventure Mojo
Oddometer: 2,676
My suggestion is to get rid of all that top heavy luggage and travel light!
Agito ergo sum - I ride therefore I am! http://www.adventuremoto.com.au Your ride.. Your adventure! |
10-29-2008, 03:51 AM
#7 |
Oddometer: 117
Great idea. I remember once I was unable to pick up my bike and I was all alone on a muddy trail. A Park Ranger ended up coming by and giving me a hand. But the jack would have been handy.
2007 White R1200GS Adventure, Ohlins, Remus, Akrapovic, Galfer, PIAA, Zumo 550, BelPro RX65 |
10-29-2008, 05:25 AM
#8 |
KindaWFO
Oddometer: 940
Good idea. The 'low-bar' and 'butt-to-saddle' methods work well for picking the bike up in many cases; however, I've had trouble righting the beast using the approved methods when there's not much traction to be had -- in mud, for example.
Cheers.
TomW '76 R90/6 '93 R100GSPD '99 XR100 '00 Duke II '10 R12GS So many toads; so little rhyme |
10-29-2008, 05:50 AM
#9 |
World's Best Dog
Oddometer: 5,670
Interesting idea, thanks for the post.
I dropped mine downhill on a rainswept night, alone, and really had a tough time righting it. I wound up levering the bike up using an old CCC (Civil Conservation Corps, c. 1930) shovel and stacking firewood under the beast 'til it was at an angle where I could lift it .It sucked. Wish 'd I'd had a snowmobile jack!
Chris Looks like the dingbat army is behaving exactly as expected. tkpinsc |
10-29-2008, 06:22 AM
#10 |
over forty victim of fate
Oddometer: 1,444
ignore the nay say ayers nice find
10-29-2008, 09:16 AM
#11 |
Plan Well...Leave Late :(
Oddometer: 950
Some people travel heavy, they live for it and that is what having the beast can be for...hauling for the long trip. Not everyone is built for lifting that much bike when it's down. And sure, you may lift the bike, but what happens when you hurt yourself doing it? I've seen it and it doesn't exactly make for a comfortable rest of your trip.
Thanks for the post, Rob. Great piece of gear.
"Never before, have so many worked so hard, for so long, to create so little." -Shrine Auditorium wall, Los Angeles, CA. |
10-29-2008, 09:34 AM
#12 |
Oddometer: 9,294
More power to all the folks who can single handedly right a GSA. When I bought my GSA I traded in an R1150R. One reason I thought the GSA would be manageble was that it actually has a dry weight less than my old R1150R, and I very easily picked that bike up off my driveway one day. I was surprised on the snow day when I could not get the beast up, and yes, it may have been due to bad footing. Soft sand was not easy either, especially on the second drop.
For myself, I now know that if conditions are not right, not good footing, maybe a post crash injury, it will be a struggle to get the bike upright. Thats what the jack is for.
10-29-2008, 09:55 AM
#13 |
one really mean cat
Oddometer: 2,674
Great find! I am not able to right my GS by myself because of my knees (osteo sucks big time). In the past, I've used ratcheting tie downs as come-a-longs to raise the bike high enough that I could squat the weight and lift the beast. A properly designed jack, like this, would have helped a lot.
10-29-2008, 10:43 AM
#15 |
Oddometer: 278
After all, is it a good thing to have a bike you can not right alone ?
