Old 10-30-2008, 04:58 PM   #31
ubergeek71
ubergeek71's Avatar
Oddometer: 209
Good idea. I one had my KTM 4 stroke DIRT BIKE slip out from under me on some REALLY slick hard pack. I had such a hard time picking up a 250lb bike under those circumstances, and I'm by no means a little guy or a wimp. I can see something like this being extremely valuable under the right (or wrong) circumstances.
ubergeek71 is offline   Reply With Quote
Old 10-30-2008, 05:02 PM   #32
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,584
Originally Posted by Tuff Tunica
Although I support this notion to a certain extent, if you can't lift it loaded like it is, then don't risk dropping it. However I think this is a brilliant idea even if you are completely able to right your bike.
what's wrong with unloading it before you lift it?
I would unload it first. I'm lazy and see no reason why I should lift an extra 30-60 pounds of stuff when I don't have to (even if I can).
// marc
marchyman is offline   Reply With Quote
Old 10-30-2008, 05:13 PM   #33
Deans BMW
Granpa Hoon
Oddometer: 3,517
There are times when a bike goes down in the worst possible situation, This rig could be a definite lifesaver.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 10-30-2008, 05:24 PM   #34
configurationspace
delooper
configurationspace's Avatar
Oddometer: 9,054
And there's other times when the ground is so soft that it might be hard to use. I'm thinking deep gooey mud. Difficult to get any traction with your feet when trying to pick up the bike, and the jack may never hit anything "solid". When I go down in such a situation I try to hook ratcheting straps between the bike and any nearby trees. Either that, or find something that can brace my feet in place.
configurationspace is offline   Reply With Quote
Old 10-30-2008, 05:54 PM   #35
SocalRob OP
SocalRob's Avatar
Oddometer: 14,374
// marc
Of course its easier to lift unloaded, I was seeing if I could lift it loaded, which is the worst case. However, if you are on a truly crappy stretch of road and are dropping the bike multiple times, unloading, lifting, reloading, dropping, repeat, repeat . . . can not only be time consuming and exhausting, it may well push you into bad judgement exhaustion, especially at altitude. I may need to work out my lifting technique, but my original picture in the snow, I did indeed remove the top box and was still not succeeding in getting the bike up prior to the trucker coming along. I had not given up by a long shot, but I was mighty happy to get a helping hand.
If you had to use the jack in mud, I think it would normally be possible to find rocks/plant branches or something solid to put under the jack base to make it workable. If the mud is too loose for that, I'm thinking you have way more problems than standing the bike up (I've been in knee deep soft mud, no fun). Remember too, if you carry a bit of rope you can rig this thing as a come-a-long to drag the bike out.
Rob
'07 White (the coolest color) GSA rider
'13 Husky Strada & '14 KTM 690 Enduro
SocalRob is offline   Reply With Quote
Old 10-30-2008, 07:22 PM   #36
longtallsally
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 4,485
I think it is a great idea, Rob. I'm blessed with being a little larger than the average bear so picking the beast up isn't really an issue for me, but my well documented failing knees may get me to the point of needing this in the future. And considering how much I like dumping it this would be a good solution.
A couple areas of concern:
1) bulk of transport. I'm already not very good at packing light, and this seems like it might add a bit much in the weight department. The come-a-long idea mention earlier seems a bit more viable for the weight/space challenged
2) it seems a bit flimsy as a whole in the bike application. For the snowmobile it just flips it and it lands like a righted Jeep or the like on all fours. As such, I'm not certain in the situation with the snow that would have been particularly safe for you to right it in that manner- if it slides and you are already struggling a bit in the strength/girth department (no offense), there is a possiblity it could get you trapped under the bike or twist something and cause an injury.
However, if you can safety anchor it and get it to where the "squat" isn't as great, it could be a very big help.
[quote=Insert witty comment here]
longtallsally is offline   Reply With Quote
Old 10-31-2008, 11:00 AM   #37
John Harden
Commuting Adventurer
John Harden's Avatar
Oddometer: 1,024
High lift for bike
Originally Posted by SocalRob
I was surprised on the snow day when I could not get the beast up, and yes, it may have been due to bad footing. Soft sand was not easy either, especially on the second drop.
For myself, I now know that if conditions are not right, not good footing, maybe a post crash injury, it will be a struggle to get the bike upright. Thats what the jack is for.
These are excellent points. I've dropped my pig 8-10 times and so far (knock on wood), I've just leaned over and lifted her right up, no problem, even in sand, off camber, etc. Having said that, I've never been hurt, or been in mud, or a similiar situation where it would have been a lot harder. I also like your point about multiple drops during a day wearing you down. You just described my sand riding technique. Ride, drop, lift, repeat as necessary....
Its really no different than 4X4'ing. If you go out alone, you need to bring with you the means to self extract. Here in SoCal, a winch isn't enough. Often, there's no place to attach the line too, particularly in the sand. In those instances, a Pull-Pal device that allows you to make your own hard point to winch out against is a good option. I never go out alone without it, and have had occasion to put it to use.
If I was with buddies for a day of riding, I'd save the 6 pounds and leave it at home. If I was going on a trip by myself, particularly if it was over a good distance and in an isolated area, I'd consider bringing one of those.
It ain't for everyone, but I'm sure some folks will put them to good use.
Regards,
John
09 BMW RT
"You never see a motorcycle parked outside a psychiatrist's office"
US Navy Veteran
John Harden is offline   Reply With Quote
Old 10-31-2008, 04:45 PM   #38
Tasy's BIGJIM
CornerGrinner
Oddometer: 489
Thumb The New Gs Riders Important Equipment...
To Exsplore out of ones Driveway and Past the Cafe Latte. One Must have... ?
Hi Lift Jack'
Base Plate for prementioned Device.
Bull Bar...to...mount the...
Electric Winch. 8000Lb should do?
12v Petrol Powered Genset for said Winch.
Jerry Can of Spare Fuel.
100 mtrs Aircraft Cable'
'D' Shackles.
Tree Protector.
"Men" at Work Warning Signs?
Flares.
Reflective 'Fold-up' Safety Triangles.
Riggers Gloves.
P.P.E. Gear to suit Rigerous Persuits!
Coat Hanger to Hang-up "Airo-Stitch" Type Jacket so it won't get Dirty.
Air Bag Jack.
Plastic "Ktm Coloured" De-Bogger Mats for soft Ground.
Hand Winch to Exstract the Bogged Trailer you need to carry all the Gear!
My Father ...and MOTHER could lift 100kilos at 84yo. ?
You not picking it up off the ground! Don't you know how to lift your Bike?
Ok Pre School for all you Newbees....Gear Romoved. Bars straight. Bum Backed against seat and Lift the Barstard! With your Legs!!
Practise at Home. Have a mate on Standby. But you will find you CAN do it! ....
Battery Acid? You DON'T have a Gell Cell? Get one is a good idea.
For all the Fems. You put a Tree Branch under your seat over the Lower Muffler Mount/ Swing Arm...what ever and lift it that way!! Piss easy. You'r in sand? Pull the Bike Sideways onto new Ground Jacket under wheel and go again. Done it solo for about 20 Pluss years! Reg stuff Down here! There have you learnt anything? I Bloodywell Doubt it! Practise. BIGJim.
"Every Day, is a great Day on A Motor Cycle" ! -Quote Marty Shields.
Tasy's BIGJIM is offline   Reply With Quote
Old 02-14-2009, 07:17 AM   #39
vincentb
Oddometer: 5
Hi, you guys, why bother, the bike it just so tired so sleepy...
vincentb is offline   Reply With Quote
Old 02-14-2009, 10:02 AM   #40
LoCat
Time it's a bitch
LoCat's Avatar
Oddometer: 324
Air Bag
How about a low pressure air bag?
http://www.ok4wd.com/index.php/catal...ranger_x_jack/
Wouldn't take much and you could use exhaust or your tire pump (electric).
I just did some searching and most of the stuff I found online is overkill. I'm guessing you may be able to get by with some kind of beach ball. Not for the total lift but in conjunction with manual lift.
Discuss
LoCat screwed with this post 02-14-2009 at 10:11 AM
LoCat is offline   Reply With Quote
Old 02-14-2009, 11:00 AM   #41
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 12,048
Thanks for posting Rob. Nice little tool at 6 pounds/15" and could be used for multiple jobs on a trip and around a camp site.
Some of these posters crying too much weight have never been on a long trip is my guess. It gets old after a while when your're nearing age 60 to 'rough it.' I'd take along the jack. We take two folding arm chairs, two cook stoves, two sleeping pads, a set of sheets, a down comforter, a king pillow, a gas light, a few pans and plates, tent, food, tools and a WHOLE bunch of stuff not mentioned! Of course we have two bikes. After about your 8th week on the road and in the middle of Labrador it's nice to have all your 'stuff,' especially if you are with the Mrs and she is carrying her half! On one of our trips I laughed at a guys 'folding saw' he proudly produced from his panniers. That night we had a really nice fire and I thought about getting a folding saw. Pedro laughed at Colleen's 'French press', but he was first in line for a cup of coffee in the morning! Sitting on a rock or damp ground is fine I guess, but my arm chair is better. I weighed all of my 'stuff' including the panniers...72 pounds...that's less than half the weight of most passengers. Good idea Rob.
the famous james and the fabulous colleen
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 02-14-2009, 04:14 PM   #42
WillieJ
MotorMan
WillieJ's Avatar
Oddometer: 147
If Skert can do it-----
http://www.pinkribbonrides.com/Videos/drop05.mpg
02 R1150 GS, 79 R100RS
WillieJ is offline   Reply With Quote
Old 02-15-2009, 04:41 PM   #43
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,708
+1
Discuss
If this was just a bit cheaper i would order one right now. I think this is a good idea. This would be great for my Ural too.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 02-15-2009, 06:35 PM   #44
110Defender
Oddometer: 41
As a dedicated 4 x 4 explorer, and camper, I think the high lift jack would also make a good come along type puller. I can see lots of uses for this, such as stuck in the mud, just pull out backwards. Pull out of ditch. I have an electric winch on my Defender, and it has many uses. Thanks for the post.
Cheers,
Ken
110Defender is offline   Reply With Quote
Old 02-15-2009, 06:49 PM   #45
Makalu
Makalu's Avatar
Oddometer: 2,849
Thanks for taking the time to address a problem that many have had, and posting photos of how you solved it. While some of those here can bench press 600 pounds, there are many here that can't. Your solution may be a real trip saver for some.
Makalu is offline   Reply With Quote
Times are GMT -7.   It's 02:46 AM.
