Old 03-09-2009, 03:17 PM   #166
Lee Keller King
Adventurer Wannabe
Lee Keller King's Avatar
Oddometer: 673
If you disconnect the choke cable in a vain (and unnecessary) attempt to remove the carburators, do not forgot to readjust the choke when you reattach the cable.
Failing to do so will make your mileage and performance suck!
Lee
(If you can't be an example, be a lesson)
Lee Keller King is offline   Reply With Quote
Old 03-09-2009, 07:33 PM   #167
dmack
96 R1100gs
Oddometer: 171
Priming Carb
If you run out of gas in your truck and decide to use the gas from the bike in the back to partially fill the tank - remember that if you are going to prime the carb with a McDonald's cup of gas while your friend cranks the engine, it will backfire through the carb, causing you to spill the aforementioned McD's cup all over. You will catch the truck engine, hood, your arm, and the freeway shoulder on fire. Hopefully your previously mentioned friend will throw you the fire extinguisher so you can put everything out (yes, you should also put the freeway out before speeding away).
Happened 24 years ago, and I still remember it vividly.
dmack is offline   Reply With Quote
Old 03-12-2009, 01:50 PM   #168
Gumbeaux
The Chameleon
Gumbeaux's Avatar
Oddometer: 818
remove electronics
When crossing a deep stream during a spur of the moment "adventure" ride, remove expensive electronics such as laptop, ipod, camera etc. from your tailbag or tankbag....just in case.
Gumbeaux
Gumbeaux is offline   Reply With Quote
Old 03-13-2009, 09:11 AM   #169
lurobi
Oddometer: 4
When changing oil filter on a Hyosung, one of those insertable cylinder oil filters, be sure not to put it in backwards. When you do, don't assume that strange clicking sound can wait another day to fix-- it's probably a scored cylinder. Way to save $15 bucks on an oil change.
lurobi screwed with this post 11-03-2013 at 04:43 PM
lurobi is offline   Reply With Quote
Old 03-24-2009, 03:06 PM   #170
CplRooster
I'm a what?
CplRooster's Avatar
Oddometer: 1,878
When drilling multiple holes in the upper floor of the building you're working on, hitting multiple hat channels(a thin metal stud where the edges are slopes at about 45 degrees) with a 3/4 hole saw, check every hole and verify it is hat channel.
After drilling multiple holes, I drilled through many hat channel edges, the last hole I had to drill, thought I'd hit hat channel one more dang time. I fought to keep it going in straight and then "BANG"!!!! I am an electrician and thought immediately that I had hit energized circuits, then suddenly realized that my face seemed to melting from the "flames" that shot out the hole I had just drilled. A mere moment later I realized to my relief, that it was water. Whew...it was only water on my face. WAIT...there IS electrical stuff all around me and WATER is now shooting all around me. THEY DON'T MIX WELL!!! Grabbed a cinder block that happened to sitting there and put it over the hole to keep the water going to the place it would end up eventually, DOWN. Down to the server room that was below me, CRAP, CRAP, CRAP. Ran down stairs to the server room, through the sprinkler pump room. The water was just pouring out of the ceiling into the pump room and missing the server room. Whew...I thought!!! Now the water was collecting on the floor was starting to rise and going into the foyer of the executives area.
I have never since removed the lower part of an exterior door to let the water, this fast. Oh yea...gotta call the boss and get a plumber in route to shut of the water and fix my F up. All while I was sweeping water out the door.
2000 Honda VFR800
2007 KTM 525 EXC
Semper Fi
CplRooster is offline   Reply With Quote
Old 03-26-2009, 08:09 AM   #171
dfwscotty
dfwscotty's Avatar
Oddometer: 3,361
When adjusting the carbs on your VW engine, make sure the engine is nice and warm so when you chop the throttle, you know it idles instead of dying.
Normally not an issue on the road but this was in a friend's homebuilt airplane on short final to landing. Didn't quite make the runway but made a hell of a splash as he hit the lake right before the threshold. He walked away and the plane flew later with no issues after a little more carb tuning!(and draining).
Traffick911
1999 BMW 1100GS
2012 Kawasaki Concours
dfwscotty is offline   Reply With Quote
Old 03-26-2009, 08:32 AM   #172
Chains45
Wait.... what?
Chains45's Avatar
Oddometer: 487
When installing new jugs on the VW powered dune buggy, understand how the new-fangled "click" torque wrench works.
In other words, do not ignore that subtle little click and keep wrenching on it till you hear/feel that big THUNK as the threads of the aluminum case give it all up... (Why did the dial go to zero?)
Do not do it twice. (hey, I was 18!)
If it's tourist season, why can't we shoot them?
Life is too short for regrets, I want to come to the end of this life bruised, battered, scratched and bleeding, holding a broken bone or two, and yelling "WOW WHAT A RIDE!! LETS DO IT AGAIN!!!!!"
Chains45 is offline   Reply With Quote
Old 03-31-2009, 01:43 AM   #173
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,684
I am in the middle of one now, still learning the lesson. Will get back here once I know what I've learned, if that makes any sense .
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 03-31-2009, 06:11 AM   #174
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
Lesson
Now you have us all waiting with anticipation. I hope it's more funny than serious. Good luck!
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 04-14-2009, 11:06 PM   #175
p_s
Nerdly Adventurer
p_s's Avatar
Oddometer: 204
I put my Vespa engine back together. It looks exactly like a 2-stroke thumper--vertically split crankcase that takes some violence to coax back together.
I had the right crankcase half in the electric smoker with the seal & bearing inside. I get the engine back together without any trouble. Later I find a bearing in the smoker. I thought my friend who'd been helping was just playing a joke on me and threw it in the trash--after all, the crank rotated very smoothly.
Life intervenes and two weeks later I find massive play in the crank bearings. Turns out that $40 bearing in the smoker that I threw away was not in the engine.
p_s is offline   Reply With Quote
Old 04-16-2009, 09:36 AM   #176
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
Originally Posted by KLboxeR
Youch! Then you get to deal with a sunburn when you're done welding in short sleeves
That reminds me of one that happened a couple of months ago:
If you are using a plasma torch, be sure and take your finger off the trigger when you lean against the welding table to adjust the workpiece.........otherwise one's pants zipper might ground against the table while you inadvertantly press the torches trigger resulting in , what I like to call, the "molten yyk zipper against my pubes and holy shit I almost burned my junk off with a plasma torch" dance
You win Chris.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 04-22-2009, 06:54 AM   #177
spqr
spqr's Avatar
Oddometer: 146
Pissed
Always check the lug nuts. Especially if you got the work done for free. It can be a tad annoying to have the right rear wheel of your first car come off, while passing a tanker truck, on a mountain road, at 70mph.
Replace the oil filler cap when adding oil to a leaky engine.
Coke can be an effective engine fire suppressant.
LEDs should not be put into wall sockets.
Disconnect the 220 wall heater, and check the capped wires before removing, or you get curly hair.
[IMG]images/icons/eek.gif[/IMG]
And my personal favorite. When burning the garbage at the end of the day with JP8, ensure some one has not filled the clearly marked 'JP8' can with regular gasoline.
It can take weeks for your facial hair to grow back.
Subscribe to me, it helps me buy beer and keep the bike running. Comments make me even better money.
My ride Report, I will finish it some day.
You pay your money, and you take your chances.
1983 R65 (sold to good home)
2001 Kawasaki Concours (Stacked and totaled)
1997 BMW F650 (Still rolling)
1987 kawasaki EX 500
2009 BMW F800 GS ('nough said)
2006 Kawasaki KLR 650 (The Mule)
spqr is offline   Reply With Quote
Old 04-22-2009, 01:43 PM   #178
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,684
Well, doing a clutch job on an airhead three times to find out that the piston that holds the throughout bearing has a problem is not really funny. I was relieved to find that it probably wasn't my fault after all.
I then decided to change the fork oil. Which is also a pretty straight forward job. As I watched the quite a bit of fork oil shoot (mostly) past my face, I immediately realized that it probably was not a good idea to push the bike of the main stand with the fork caps still off.
I can file this one right next to when I learned that the gearbox will leak oil when you have the input shaft facing up on your work bench and the sump plug incident....
Some years ago I also found out that it's not a good idea to skimp on the fork drain plug washers. They are somehow connected to poor brake performance.
As a self-taught mechanic I can only conclude that my teacher was an idiot.
R1150GS
R80GS Basic
Old 04-22-2009, 02:03 PM   #179
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,746
Sig line for sure!
EvilClown is offline   Reply With Quote
Old 04-23-2009, 04:43 AM   #180
SpitfireTriple
Seek Truth
SpitfireTriple's Avatar
Oddometer: 876
When you know you've got a slow puncture, be sure you do not park the bike leaning into a slope.
SpitfireTriple is offline   Reply With Quote
Times are GMT -7.   It's 03:49 AM.
