Old 08-08-2011, 05:59 AM   #706
Thinc2
Paciugo
Thinc2's Avatar
Oddometer: 4,584
After doing general maintenance, make sure to put the tank back on before getting all geared up to go for a test ride
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 is offline   Reply With Quote
Old 08-08-2011, 01:51 PM   #707
C8Chris
Motard!
C8Chris's Avatar
Oddometer: 131
Key Issues
If you make a habit of putting your keys in your helmet, remember to put them in the ignition BEFORE putting the helmet on your bald head.
Ah! There they are!
C8Chris is offline   Reply With Quote
Old 08-08-2011, 02:15 PM   #708
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,047
Ah! There they are!
As a person that is follically challenged I would say, "I bet that left a mark".
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 08-10-2011, 09:31 AM   #709
duck
duck's Avatar
Oddometer: 10,403
When you buy a new soldering iron with a trigger don't plug it in assuming that it's only on when the trigger is pulled. Otherwise, when you throw it across the garage to someone else after it's been plugged in for a couple of hours their hands might get a little burned when they attempt to catch it.
(I was only a witness to this, not a participant.)
duck is offline   Reply With Quote
Old 08-11-2011, 08:45 AM   #710
tgeliot
Topher
Oddometer: 1,352
So I guess when the trigger isn't pulled it's at some reduced "keep warm" setting or something?
I was surprised when I read the manual for my pistol-shaped soldering gun and found that as you pull the trigger, it goes first to full power, and then as you pull the trigger further, drops down to low power. That totally violated my expectations.
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 08-12-2011, 09:00 AM   #711
duck
duck's Avatar
Oddometer: 10,403
Nope. When you plug it in it goes to full heat and is ready to solder. The trigger is for "Therma-Boost" to make it even hotter.
http://www.cooperhandtools.com/brand...c=037103211330
Old 08-14-2011, 10:45 AM   #712
mike-s
2 squeaky wheels
Oddometer: 609
Oh, when i was a kid i borrowed my neighbours soldering iron, it had a trigger on it, but the difference was, it was used to pull a thin spool of solder through the internals of the iron and deposit it right against the top face of the chisel tip.
The solder that my neighbour bought with thing had was particularly nasty & corrodded the hell out of the tip, even after minimal use and cleaning-retinning religeously :-\.
mike-s is offline   Reply With Quote
Old 09-04-2011, 04:27 PM   #713
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,234
Before you spend a couple hours measuring and making wheel spacers to fit an old rim to newer bike. Make sure the rim is not cracked.
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 09-04-2011, 08:45 PM   #714
xymotic
xymotic's Avatar
Oddometer: 8,367
Before you make a new inner spacer because the bearing doesn't seat down all the way, make sure there isn't 1/2 a race left from the last bearing
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 09-14-2011, 07:04 PM   #715
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,360
When the drivers side power window motor in a mid 90's truck dies, know that the plastic connectors will crumble and crack apart in your hands as you try to take them apart. Your wife will have thrown away your Hanes manual because it was dirty, and be prepared for the exciting lack of hardware that you probably won't notice until you dump out the supplied hard ware that has bolts but no nuts cause who needs those damn things right? Kinda like I still got two hours of work a hungry as hell cloud of mosquitoes and no light. F@#$ it, the door's still in pieces, it's beer thirty and I'm riding tomorrow.
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 09-14-2011, 09:05 PM   #716
Taranis
Oddometer: 363
Another one. When cutting or welding on a car or truck's chassis, don't put the ground clamp on a suspension control arm. The rubber bushings are insulators compared to the stainless steel sheathed brake line that is now your ground cable. If it doesn't burn apart immediately, the steel braid will get hot enough to compromise the inner PTFE liner, leading to brake failure.
Taranis is offline   Reply With Quote
Old 09-29-2011, 08:14 PM   #717
West Isles
West Isles's Avatar
Oddometer: 112
Note to self::
When installing new stator in DR-Z400, fully tighten all three (not just two) of the bolts that attach the stator to the side cover of the motor. And also, upon hearing awful swaking sound come from left side of engine while rideing three weeks later, shut off engine ASAP....before the swaking sound becomes a grinding noise !
West Isles is offline   Reply With Quote
Old 09-30-2011, 05:42 PM   #718
xymotic
xymotic's Avatar
Oddometer: 8,367
when you take off your jacket after a long ride to load the bike, make sure you don't lock the van with the bike, jacket AND keys inside
Albert Einstein
6:10 to Yuma
Old 10-24-2011, 09:19 PM   #719
simestd
simestd's Avatar
Oddometer: 268
Note to self, axle grease != assembly lube!
From ADV
If you're assembling an engine and can't find your assembly lube (Lubriplate 105), DO NOT substitute bearing grease. Sure, it provides great lubrication, that is right up until the globs make it to the oil intake screen and PLUG IT
Miraculously no actual engine parts were harmed in this experiment....
Tom
'82 XV750, '82 GL500, '02 DR650, '07 XT225
simestd is online now   Reply With Quote
Old 11-01-2011, 03:58 PM   #720
GreaseGorilla
GreaseGorilla's Avatar
Oddometer: 415
Originally Posted by simestd View Post
From ADV
for years i used a mix of 30w Oil and Marvel Mystery oil, and 90 w gear oil in equal parts shaken in a bottle and dispensed from a mustard squirty bottle........ works good, never had a prob.
GreaseGorilla is offline   Reply With Quote
Times are GMT -7.   It's 05:01 PM.
