Old 11-09-2008, 05:39 PM   #61
KLboxeR
Back in the game again
Oddometer: 3,650
Always wear safety glasses when removing Jesus clips* or Jesus springs from any mechanical part. If you forget that first piece of advise, make sure your hands aren't covered in oil and carb cleaner when they reflexively fly up to extricate said clip or spring from your eyeball
* Jesus clips are those tiny parts that go flying across the shop during disassembly causing you to exclaim Jesus Christ!!!!! in frustration.
Chris
KLboxeR is offline   Reply With Quote
Old 11-09-2008, 05:50 PM   #62
KLboxeR
Oddometer: 3,650
Never, ever look down into the throats of a tri-power carburetor when trying to diagnose an ignition problem on a '64 GTO.
The backfire that results in three pillars of flame spewing out the carb assembly from that 389 V8 will set your entire head ablaze.
I doesn't help if your brother, who was the one cranking the starter, is laughing too hard to get a blanket or fire extinguisher and assist in putting your noggin out
Chris
Old 11-09-2008, 06:30 PM   #63
CplRooster
I'm a what?
CplRooster's Avatar
Oddometer: 1,878
Always put your home phone number in your cell phone, so when you forget to zip up your tank bag, the nice guy that finds your phone in the middle of nowhere, can call you. Oh yeah, don't forget to zip up your tank bag.
2000 Honda VFR800
2007 KTM 525 EXC
Semper Fi
CplRooster is offline   Reply With Quote
Old 11-09-2008, 07:11 PM   #64
Bumblebee-TGL
Nomad
Oddometer: 357
Always put a tie down strap from the center stand through the front tire rim then back to the center stand when removing the rear wheel..or doing maintenance in general. Blundering into the back of the bike, or more to the point, pulling up on the torque wrench is the best way possible to roll the bike off the center stand.
(I didn't roll it completely off however it was -->||<-- that close to going kaboom before I realized what I was doing)
Five Gears, No Reverse, Cruise On...
Bumblebee-TGL is offline   Reply With Quote
Old 11-09-2008, 07:56 PM   #65
MiamiMotorcyclist
used to be -MiamiUly
MiamiMotorcyclist's Avatar
Oddometer: 1,928
NEVER get really annoyed and use channel locks to remove a stubbornly stuck socket from a ratchet while at the same time gritting your teeth and pulling towards your self in Charlie Brown like fashion.
I swear I realized what a bad idea that was exactly 1 nanosecond before that socket let go and the wrench powdered half of a central incisor.
Left a white mark on the channel locks and me with a tooth like Jim Carey in Dumb and Dumber or hockey tooth.
Love that dental Bondo.
Okay it's a sportbike... but riding is not a sport, it's a necessity. Same goes for the Dual Sport.
MiamiMotorcyclist screwed with this post 11-09-2008 at 09:03 PM
MiamiMotorcyclist is online now   Reply With Quote
Old 11-09-2008, 08:30 PM   #66
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 798
If you take the full gas tank off your bike in the garage, please make sure you place the gas tank on something STABLE so you don't have to smell what four gallons of gasoline smells like in a confined space.
Also, when you hear the gas tank hit the ground while watching TV, it's not the wind, and it demands your attention NOW instead of 30 petroleum-soaked minutes later. I'm just sayin'...
baldwithglasses is offline   Reply With Quote
Old 11-09-2008, 11:22 PM   #67
murgatroid42
Great Adventurer
Oddometer: 4,185
Oh, yeah, ouch. My version is when changing a tire by hand, NEVER, EVER pull a stuck tire iron directly towards you. It can hit you directly, squarely, on one's front tooth. I thought I knocked it out. My tooth, lips, and mouth were sore for over a week.
I change tires to save money, but spending $150 on an emergency dentist visit doesn't balance the budget. My tooth is OK, luckily, but the dentist said this was not the first time he saw someone who whacked a tooth while changing a tire.
"We hang around people who think these activities are normal."
"Me and gravity, we are really, really good friends." - Streetbike Tommy, Nitro Circus
"I'm a dude in his mid-40s, who acts likes he's in his 20's. But I don't plan on stopping any time soon." - Ken Block
murgatroid42 is offline   Reply With Quote
Old 11-10-2008, 04:27 PM   #68
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,113
When you carry extra fuel in your back pack, be sure to use a suitable contianer.
I used an old Colmen camp stove fuel can. No problems on the first trip. Different story on the second trip. And of course I found the damm thing leaking AFTER I filled up the bike.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 11-10-2008, 04:28 PM   #69
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,113
Same goes for a four barrel!!!!
Regards
Fritzcoinc
Old 11-10-2008, 04:52 PM   #70
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,536
Move the pads of your finger tip away from the cable tie holding a bundle of wires before you clip off the tie with your side cutter.
// marc
marchyman is offline   Reply With Quote
Old 11-10-2008, 05:03 PM   #71
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,383
// marc
Jim
JimVonBaden is online now   Reply With Quote
Old 11-11-2008, 11:40 AM   #72
Flood
F5lood.
Flood's Avatar
Oddometer: 10,161
Originally Posted by Frank Warner
Before puting in fresh oil .. put drain plug
That one's easy. I can do that. That one ain't:
1. put bike on stand.
2. disassemble various bits&pieces, including front wheel.
3. remove forks.
4. remove fork oil drain screws, drain fork oil.
5. disassemble forks, clean, inspect and measure various bits&pieces of machinery.
6. re-assemble.
7. reach for the 2 containers of fork oil that contain exactly the amount you'll need.
8. remember to reinstall those little drain screws from 4) before emptying one container of precious oil all over the shop floor, cleaning up all the mess, fill forks with 1/2 the amount of fork oil necessary, put everything back together, ride around like that for 2 days before you can get new oil and have to start at 1) again!
TEAM F5
RallyRAIDio on Twitter
RallyRAIDio on Facebook
Flood is offline   Reply With Quote
Old 11-12-2008, 11:54 AM   #73
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,319
If you have a hairy chest, don't let the rotary wire brush hop back from the spokes you're polishing and catch the front of your shirt.... Well, Ok, if you intend to remove a LOT of chest hair very quickly/painfully it's a damn near unbeatable way of doing it.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 11-13-2008, 03:42 PM   #74
tulebox
tulebox's Avatar
Oddometer: 1
Ok, i got a couple.
1. Engine oil goes in the engine oil fill spout, not the transmission one.
2. When welding in short sleeves, put down the mig gun before reaching for your other arm where the slag just landed. (think 1/2" deep bloodless, cauterized gouge in your arm.)
I am the right tool for the job.
tulebox is offline   Reply With Quote
Old 11-13-2008, 05:42 PM   #75
KLboxeR
Oddometer: 3,650
Youch! Then you get to deal with a sunburn when you're done welding in short sleeves
That reminds me of one that happened a couple of months ago:
If you are using a plasma torch, be sure and take your finger off the trigger when you lean against the welding table to adjust the workpiece.........otherwise one's pants zipper might ground against the table while you inadvertantly press the torches trigger resulting in , what I like to call, the "molten yyk zipper against my pubes and holy shit I almost burned my junk off with a plasma torch" dance
Chris
Times are GMT -7.   It's 06:38 PM.
