Old 12-23-2011, 08:35 PM   #736
ParrotheadJeff
Guest
Oddometer: n/a
Originally Posted by JimVonBaden View Post
Jeff,
You are relatively new at riding. This will very likely NOT be the last time you do this! Don't ask me how I know!
Jim
You're probably right, but at least I can't lock my keys in my bike
Old 12-24-2011, 04:13 AM   #737
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,511
Originally Posted by ParrotheadJeff View Post
...I killed the engine with the kill switch...
Oh, now I get it. For some reason I was thinkin’ this was in a car.
... very likely NOT be the last time ....Don't ask me how I know!
Yeah, seen guys do this all to often. The simple cure for this is to always use the key to kill the bike. I tell new riders to never use the kill switch except in certain circumstances. Just use the key, save the battery.
Never figured out why some people use the kill switch. The rare times that I do I sometimes forget to flip it back, then wonder why it won’t start.
Tom S is offline   Reply With Quote
Old 12-24-2011, 05:10 AM   #738
Rottweiler
I'm a Believer
Rottweiler's Avatar
Oddometer: 363
I have an equally bad habit of using the sidestand to kill the engine. Leads to the same sorts of problems.
2002 Suzuki DL1000 V-Strom - blue
2001 Honda Reflex NSS250 scooter - silver
Real men wear boots. God is good.
"Liberalism is a philosophy of consolation for Western Civilization as it commits suicide." - Dr. Jerry Pournelle http://jerrypournelle.com
Rottweiler is offline   Reply With Quote
Old 12-26-2011, 12:52 AM   #739
duck
duck's Avatar
Oddometer: 10,403
a) It's the quickest, most convenient way to turn off a motorcycle.
b) If you ever have a getoff or drop then it's built into your "muscle memory" and second nature to shut things down quickly.
c) If you're too complacent/ignorant to remove the key afterwards then you deserve a dead battery.
duck is offline   Reply With Quote
Old 12-26-2011, 01:11 AM   #740
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,511
And apparently the quickest most convenient way to forget the key.
b) If you ever have a getoff or drop then ...
Then it’s a different story & not a normal ‘turn off the bike’.
I still advise to make it a habit to use the key under normal circumstances. It’s still plenty quick & convenient & could save a lot of trouble.
Old 12-26-2011, 05:06 AM   #741
ibafran
villagidiot
Oddometer: 1,289
On some bikes, you can. Sigh, don't ask how I know. Always a challenge when on extended tour.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 12-26-2011, 05:45 AM   #742
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
Do you not know what muscle memory is? It is when you do something enough so that you can do it without thinking about it. While I don't always use the kill switch, I frequently use it to kill the engine as I roll into a slot. When I've dropped my current bike, I've flipped the kill switch as my left hand unwillingly departed the handlebar.
As for forgetting the key, I won't say I'll never forget it, but so far I've not left it on. I've left the key in the ignition, and left it in the seat lock, but I've made a pretty good habit of locking the steering after setting the bike on the stand. So, 1)Kill switch 2)side-stand 3) lock steering and pull key.
1) key to off 2)side-stand 3) lock steering and pull key
Either way I do it, I wiggle my bars to double-check I've finished, and so far it's worked pretty well for me.
Do you talk to people you meet on the road?
Home is where the skid lid sits.
xcgates is offline   Reply With Quote
Old 12-26-2011, 06:37 AM   #743
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,511
Sure I do. Maybe that’s why I don’t use that kill switch all the time.
Old 12-26-2011, 06:57 AM   #744
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,511
...I've left the key in the ignition, and left it in the seat lock...
Well, don’t come ridin’ after me when your bike get ripped off.
(Didn’t you mom ever say ‘Don’t come runnin’ to me when you break your leg'? Or ‘Shut your mouth & eat your dinner’?)
Even with using the key all the time, I have still left it in the bike too many times. Bugs the hell out of me.
But I have been making it a habit now to pull the key immediately after shutting it off. Then I am still checkin’ my pocket for the key. I hardly ever lock the forks.
Old 12-26-2011, 07:00 AM   #745
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
Ehh, where I work everyone known everyone, including the armed guards. Heck, I grabbed my suit and helmet off the bike one time when I was leaving in a truck for a couple hours, and had someone come out to stop me before recognizing me.
Old 12-30-2011, 07:42 PM   #746
duck
duck's Avatar
Oddometer: 10,403
End of year confessions so that I have a clean slate for 2012:
I spent a little over a couple of hours last summer trying to figure out why my damned K75 wouldn't start. Then I found the solution: It was out of gas. (Yes, it has a fuel gauge which I obviously didn't pay attention to.)
Changed the oil on my K1100RS. It was kind of a bitch to get the old (wet/submerged) filter out which distracted me. Finally succeeded in getting it out and refilled the bike with fresh oil. Finished the oil change and topping it off only to look up by the front wheel to see the new oil filter (which I should've installed before refilling it) sitting there on the ground in it's box.
Old 12-31-2011, 11:41 PM   #747
arcanum
Oddometer: 316
If you are gonna use a .22 caliber shell casing as a temporary fuse, make sure you have shot the bullet out of there first.
Even I am not that stupid,but i heard about a guy who was...
arcanum is offline   Reply With Quote
Old 01-03-2012, 04:06 PM   #748
troidus
Oddometer: 15,083
If you're going to use .22s for makeshift earplugs, put them in backwards or make sure they've been fired.
troidus is online now   Reply With Quote
Old 01-04-2012, 02:01 PM   #749
Pugsley/Hobbfather
Oddometer: 415
Bulletheads and Ear Protection
Define 'backwards'.
If the primer end is out, you'd still have to get shot in the head to set it off.
If somehow there was any way to set the thing off, the brass would explode and rupture, and be moving much faster than the lead, by the very same physics that make a bullet travel much faster than the gun.
Also, the only way to wear it 'comfortably' would be bullet end in.
The lip on the brass would give you a way to pull it out (fingernail extractor...)
If it were fired, you'd have a somewhat sharp brass edge either inside or outside of your ear, and whatever collected or remained in the case could work its way to your ear canal.
Always use a shotgun shell for earplugs, as it is plastic... and soft
Pugsley/Hobbfather is offline   Reply With Quote
Old 01-07-2012, 10:41 AM   #750
troidus
Oddometer: 15,083
How big are your ear canals?
Times are GMT -7.   It's 04:10 PM.
