Old 01-12-2012, 10:45 AM   #751
sean.flynn
Oddometer: 6
Note to self: Union bolts attaching brake lines to calipers get torqued at approximately 18.8 ft-lbs. Failing to double-check your swiss-cheese memory and torquing them to 40 ft-lbs will shear the bolt off in your brake caliper.
'06 Suzuki DL650
'82 Yamaha XJ750RJ Seca
Buried under sheet of ice; is it spring yet?
sean.flynn is offline   Reply With Quote
Old 01-12-2012, 09:00 PM   #752
mike-s
2 squeaky wheels
Oddometer: 609
Yeah I've come close to being caught out by that. It's even more hazardous with the caps and spacers themselves if there is a fair bit of preload that you aren't aware of the first time you pop them open. That time it took me ten minutes to find where the hell the right fork cap shot off to.
mike-s is offline   Reply With Quote
Old 01-13-2012, 09:23 AM   #753
tgeliot
Topher
Oddometer: 1,354
Originally Posted by Pugsley/Hobbfather View Post
Always use a shotgun shell for earplugs, as it is plastic... and soft
Shouldn't this go in the "Best use of an inappropriate object" thread?
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 01-13-2012, 12:53 PM   #754
Pugsley/Hobbfather
Oddometer: 415
and everything in it's place
There's a thread for that?
...must....
...re...sist...
...tem...tempt...tation
Pugsley/Hobbfather is offline   Reply With Quote
Old 01-13-2012, 07:05 PM   #755
some kid
on a motorbike
some kid's Avatar
Oddometer: 182
If your tube of valve lapping compound gets clogged, never point it at your eye and squeaze it. ("May cause eye irritant" is an under statement)
(Blank)
some kid is offline   Reply With Quote
Old 01-14-2012, 02:29 PM   #756
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,370
I'm sorry. Blindness is not funny. I hope you only squirted the stuff in one eye at least. You can learn to work
with one eye. You still have the good eye don't you?
Old 01-14-2012, 06:05 PM   #757
some kid
on a motorbike
some kid's Avatar
Oddometer: 182
No lasting affects, it just added about 45 minutes to reinstalling my valves, and the insueing trauma of trying to scramble over to the sink really made a mess of the place . I normally wear safety glasses when working in the garage, but since this was on the kitchen table I thought I was safe.
(Blank)
Old 01-19-2012, 05:59 PM   #758
jcmcc
jcmcc's Avatar
Oddometer: 155
chlorinated brake clean is more painful to the eyes than non-chlorinated
ugh my poor eyes
jcmcc is offline   Reply With Quote
Old 01-25-2012, 08:56 AM   #759
Iron Dingo
Iron Dingo's Avatar
Oddometer: 291
when spraying break cleaner on your engine to get the tough grime off make sure it is not the Carb Cleaner you are spraying...
related..
before bead blasting the paint off your engine cases spray it with Carb Cleaner to soften the paint a little.
Iron Dingo is offline   Reply With Quote
Old 01-25-2012, 09:02 AM   #760
Iron Dingo
Iron Dingo's Avatar
Oddometer: 291
after practicing all morning on the track Do NOT let your buddy bleed that air bubble out of your front break....
Old 01-27-2012, 11:15 PM   #761
lemieuxmc
lemieuxmc's Avatar
Oddometer: 3,360
When you have removed the in-line fuel pump and want to check the voltage at the leads, put a plug of some sort in the line from the tank before you turn the key on because that opens the solenoid controlled fuel tap "Hey, where's all this gas comin from!"
lemieuxmc is offline   Reply With Quote
Old 02-20-2012, 04:23 PM   #762
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 748
comparison testing ?
ugh my poor eyes
I've done both and could not detect a difference !
pennswoodsed is offline   Reply With Quote
Old 02-22-2012, 07:26 PM   #763
jcmcc
jcmcc's Avatar
Oddometer: 155
interesting... perhaps further testing is necessary
Old 02-24-2012, 11:45 PM   #764
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,789
When you decide to insert a 6MM t-handled hex wrench, in-between your brake pads, to push the pistons in (because you did not wish to remove the caliper, to facilitate an easier re-install of the tire...as was suggested on every forum in North America), perhaps you should not approach your first red light at 60mph.
Pressure, in the system, takes a surprisingly long time to rebuild. Or, at least, it seems like an eternity (when you're measuring in feet per second)...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 02-25-2012, 11:19 AM   #765
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,883
Pump faster!!!
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Times are GMT -7.   It's 04:24 AM.
