Old 03-29-2012, 11:25 AM   #781
thelen60
Oddometer: 12
Notes to self:
1. When siphoning gas out of a lawn mower to put my four-wheeler, take my mouth off the hose before the gas gets there. (I was 13 and burped the taste of gasoline for 48 hours)
2. When taking the transmission of my truck, put something underneath to catch it other than your testicles. (Watched my dad do that one)
3. General rule: Don't wear cut-off T-shirts when working on cars; even if it is 90* in the garage. (Bolted in sheet metal to repair rotted floorboards. Cutting off bolts with a Dremel can make them red hot and drop into your shirt. I have the scar to prove it.)
4. Don't wear hooded sweatshirt with strings while using an industrial size LeBlond lathe. After watching my strings bounce off the chuck, I had to go sit down trembling. If you don't understand this look up pictures of people getting caught up in lathes....
5. Don't have bottle rocket fights without a shirt on.
6. If you are on your motorcycle and see a woman on a cell phone, drive away from her!
thelen60 is offline   Reply With Quote
Old 03-30-2012, 06:26 AM   #782
EastEnd
EastEnd's Avatar
Oddometer: 205
Originally Posted by thelen60 View Post
Notes to self:
this is precisely why i pull the strings out of every hooded sweatshirt i buy, got one end caught in the fan belt of my old truck, it yanked out smoothly, but the pucker factor was still a 4.0
EastEnd is offline   Reply With Quote
Old 03-30-2012, 10:31 AM   #783
42
Bokononist
42's Avatar
Oddometer: 17,545
When changing the timing belt on your Pathfinder, make sure you put the shortest bolt in the bottom of the lower belt cover. Unless you like ripping the whole thing apart again.
Crawling from the wreckage
42 is online now   Reply With Quote
Old 03-30-2012, 10:43 AM   #784
ADVMindset
Americana Adventurer
ADVMindset's Avatar
Oddometer: 1,161
"When welding the frame of your bike, remember the rod will strike an arc on ANY metal part of the bike directly connected to the frame.
Including the inner tube of your front fork, leaving a nice little crater!
Changing fork seals are now a part of every 5000 km service"
That's one HELLUVA of a first post !
Now be ready to have some ornery comments made ! But it's all fun !
Sorry to hear about your tube....
Welcome to the asylum !!!
ADVMindset is offline   Reply With Quote
Old 03-30-2012, 04:58 PM   #785
jcmcc
jcmcc's Avatar
Oddometer: 162
Originally Posted by FixerDave View Post
.......and had gas pouring down my leg after I remembered to turn the petcock on....
David...
Had a similar experience but with oil.. Forgot to put the oil cap back on after filling and was on the interstate before I realized what happened. What tipped me off was the difference in the way my jeans were flapping in the wind
jcmcc is offline   Reply With Quote
Old 03-30-2012, 05:25 PM   #786
ibafran
villagidiot
Oddometer: 1,289
I am surprised that the inmates have not advised this guy how to save his fork seals?
Here's my suggestion: Get a hard and very fine stone to hand work over the fork tube nick and knock off all the high spots. Fill the crater with epoxy and stone that down flush. Now the fork seal has something to glide over without getting nicked up. If the tube still pushes a lot of oil, the bushing is probably scratched/gouged. Hope that helps. Others can chime in with better stuff.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 03-30-2012, 05:26 PM   #787
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,390
Learned this one from 100 yards away today.
Note to self;
Do not take an old single axle pop-up camper and convert it into a flat bed trailer. Do not place two garbage dumpsters on trailer. Do not fill dumpsters with scrap iron. And most definitely do not pull the whole works behind your mid-90's Toyota 4Runner at 65 mph down a counrty highway!!!!
I tried to get a picture after I made sure he was OK, but it didn't turn out.
Let's just say; High speed wobble, near roll over, jack-knife, 3 or 4 broken windows, ditch, bent to hell front suspension and a shit ton of iron tossed into the ditch.
WARNING: Most things posted above contain sarcasm.
Daamud is online now   Reply With Quote
Old 03-30-2012, 05:44 PM   #788
troidus
Oddometer: 15,716
Note to self;
And this is why there should be a requirement for a towing endorsement on one's license, as well as inspections for trailers.
troidus is online now   Reply With Quote
Old 03-31-2012, 03:47 PM   #789
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,965
Note to self;
I got the picture, I can see it now, WOW would you look at that. I can't believe the mess. He appears alright, OK. WOW would you look at that...
---Albert Einstein
disston is online now   Reply With Quote
Old 04-02-2012, 05:41 PM   #790
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,740
When you are packing up your gear for a nice 3 day get away with 150 other inmates, make sure to check your gear bag to verify that your riding boots are in there. You can skip this step if you wear a size 9 - 12 siz shoe. 13+ Not so good.
Thankfully the store in town 70 miles away had 1 pair. So now I have a spare pair of boots (Tech 3's). I will have to say that the Honda shop in Ridgecrest CA (I don't remember the name) didn't bend me over when he heard I forgot the boots. He was actually simpathetic that he didn't have anything cheaper.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 04-02-2012, 08:06 PM   #791
MiteyF
MiteyF's Avatar
Oddometer: 2,052
Note to self: be careful when waxing horizontal band saw blades. I did this today at work. Cut straight through one tendon, mostly through another. It'll be a badass scar/story though
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 04-02-2012, 08:09 PM   #792
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,390
Old 04-02-2012, 08:22 PM   #793
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,916
Originally Posted by MiteyF View Post
Note to self: be careful when waxing horizontal band saw blades. I did this today at work. Cut straight through one tendon, mostly through another. It'll be a badass dumbass scar/story though
Fixt!
Jim
Old 04-03-2012, 12:18 PM   #794
MiteyF
MiteyF's Avatar
Oddometer: 2,052
OK, badass scar, dumbass story
Old 04-04-2012, 08:22 PM   #795
blakey
Oddometer: 11
When putting the cylinder head back on a Yamaha 100 trail bike, make sure you know the difference between inch pounds and foot pounds.
When replacing fork oil in the above mentioned bike, make sure you know the difference between ATF and brake fluid.
blakey is offline   Reply With Quote
Times are GMT -7.   It's 12:20 PM.
