Old 11-13-2008, 06:47 PM   #76
Dieselboy
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,148
Originally Posted by KLboxeR
Youch! Then you get to deal with a sunburn when you're done welding in short sleeves
That reminds me of one that happened a couple of months ago:
If you are using a plasma torch, be sure and take your finger off the trigger when you lean against the welding table to adjust the workpiece.........otherwise one's pants zipper might ground against the table while you inadvertantly press the torches trigger resulting in , what I like to call, the "molten yyk zipper against my pubes and holy shit I almost burned my junk off with a plasma torch" dance
Dieselboy
The Adventure Continues
Dieselboy is offline   Reply With Quote
Old 11-14-2008, 02:11 AM   #77
schultzy
schultzy's Avatar
Oddometer: 154
Dont leave your dirtbike helmet at home!
schultzy is offline   Reply With Quote
Old 11-14-2008, 03:23 AM   #78
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,665
Don't get distracted while releasing the last tie-down strap on your receiver hitch bike carrier. Use the handy, dandy ramp to unload bike instead.
"Well...the bike's unloaded."
Like a catapult.
Perhaps the silver lining is the rear window was not smashed out as it would have been if the other strap was released last. The dirt bike was going to fall down eventually that day anyway.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 11-15-2008, 07:51 AM   #79
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
How to make holy pants
When leaning over to pull the tarp off a Ural sidecar don't rest your leg against the exhaust and melt a hole in your pant leg. Also don't do it again and certainly not a third time. I have a lot of short pants now.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 11-16-2008, 03:28 PM   #80
Chains45
Wait.... what?
Chains45's Avatar
Oddometer: 487
Do NOT put the bike up on the center stand, start it up, 1st gear, oil the chain, then use a rag wrapped around your fingers to makes sure the oil is well spread. When the rag gets caught in the chain and pulls your fingers in-between the chain and rear sprocket the pain is immediate and intense.
I was lucky the chain was tight enough that my fingers in the mix killed the bike halfway around - the supports of the chain guard would have amputated them. As it was i just mangled the first 1/2 inch.
That afternoon my rugby name became Chains.
If it's tourist season, why can't we shoot them?
Life is too short for regrets, I want to come to the end of this life bruised, battered, scratched and bleeding, holding a broken bone or two, and yelling "WOW WHAT A RIDE!! LETS DO IT AGAIN!!!!!"
Chains45 is offline   Reply With Quote
Old 11-19-2008, 11:10 AM   #81
Blinkerfluid
Blinkerfluid's Avatar
Oddometer: 1,173
When using a grinder, the shower of sparks will set your clothes on fire.
Blinkerfluid is offline   Reply With Quote
Old 11-19-2008, 11:29 AM   #82
MiamiMotorcyclist
used to be -MiamiUly
MiamiMotorcyclist's Avatar
Oddometer: 1,918
Wish I had thought of that name.
Do tell your kids not to be so anal about chain tension on their BMX bikes as to attempt to check said tension, while coasting down the road with feet on pedals. When they lean over and lift the chain with a finger, their foot will press down on the pedal and reel their finger into the chain ring.
(Okay it was me around 10 yrs old. I was stuck with a bike on my finger at the chain's tight spot or just before it. No free wheel, bendix brake on mags, so no backing it out. A neighbor decided to try to pry the chain off with a shovel, thereby tightening the chain on my finger.
I sent my friend back the two blocks home to get my parents and some tools to get the master link off. Actually don't remember getting out of it but needed lots of stitches and my right index fingernail still grows kind of odd towards the tip.
I spent more teacher work days getting stitches than I care to remember)
Okay it's a sportbike... but riding is not a sport, it's a necessity. Same goes for the Dual Sport.
MiamiMotorcyclist is offline   Reply With Quote
Old 11-19-2008, 02:01 PM   #83
Wreck™
Wreck™
Wreck™'s Avatar
Oddometer: 358
Remove drawbar wrench before turning on vertical milling machine spindle.
Wreck™ is offline   Reply With Quote
Old 11-19-2008, 03:08 PM   #84
Chains45
Wait.... what?
Chains45's Avatar
Oddometer: 487
ouch... at least i got mine out...
Memories - that was 27 years ago for me, still remember it clearly.
Old 11-19-2008, 04:41 PM   #85
PaulRS
Dutch fool
Oddometer: 790
So will sparks from cutting iron beams with gas/Ox.
Paul.
PaulRS is offline   Reply With Quote
Old 11-19-2008, 05:01 PM   #86
AnnieGS
Namasté, bitches!
Oddometer: 29,540
Check that your vintage beetle is in neutral before casually reaching in the driver's window and hitting the ignition button. Even at a mere 40hp, that freshly-rebuilt engine is torquey enough to break the back tires loose, and you're bound to startle the cat.
AnnieGS is offline   Reply With Quote
Old 11-19-2008, 05:35 PM   #87
GaelicDog
Lesser of Two Weasels
GaelicDog's Avatar
Oddometer: 7,322
1) When working under a car ALWAYS disconnect the battery.
Had a friend working on his 69 Camaro and crossed the starter connections
and it lurched forward falling off the ramps. It pinned his head between the
frame and ramp. He was there for over an hour before his parents returned.
The wall was covered in blood where he was screaming for help. He
survived. He has a nice plate in his head. He is now nicknamed lumpy.
Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
GaelicDog is offline   Reply With Quote
Old 11-19-2008, 05:44 PM   #88
Wreck™
Wreck™
Wreck™'s Avatar
Oddometer: 358
Less damaging but far more humorus, had a job setting up computer furniture in hospitals, office buildings Etc., allways during business hours. Myself and a helper get on an elevator, (empty thankfully) on the 7th floor, I have a toolbox, he has a 50' extension cord.
He's dragging several feet of said cord behind him, door closes on cord, elevator decends and the cord begins to run out like a lure hit by a Blue Marlin.
Floor 6
Floor 5
Floor 4
Him "what should I do?"
Me "let go of the cord".
Him "then what?"
Me "act like nothing happened."
Old 11-19-2008, 07:45 PM   #89
dvgonzo
dvgonzo's Avatar
Oddometer: 329
Holy Crap Shrimper THAT was funny....and about the drawbar wrench....did it turn it into a flinger across the shop?
dvgonzo is offline   Reply With Quote
Old 11-20-2008, 06:36 AM   #90
Wreck™
Wreck™
Wreck™'s Avatar
Oddometer: 358
When running the spindle clockwise the wrench hits the motor housing and unscrews the draw bar, thank you Bridgeport!
Had it been a left handed tool there would have been much
Times are GMT -7.   It's 10:00 PM.
