Old 01-11-2009, 08:05 PM   #61
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,123
Stage Two
Stage 2 525-540 kit rebuild by a noob
, I have had the 540 kit sitting in my bedroom for few weeks now
And it time to install having never done a top end on 4\St just want to know the tricks of the trade as some you seem to pull you bike down because you think it is funn
1) I have the thumper 540 kit with gaskets
2) I have the cam chain tool
3) Have all new cam chain & guides
4) Head will been sent out for new valve and seats
5) I have check ring gaps) all good
6) I have the service manual .
7) Have a 3 torque wrenches 3/8 inch.
What other things do I need to know , tip and tricks
My plan is get the head & barrel off tonight , drop the head off tomorrow
Pick up head and cam chain & guides weds and reassemble.
Disassembling is the easy part , putting back together is tricky bit ,
Ill need to check the deck hight , dont know how to change it if I needed to thou
I think Ill be fine up until the cam and TDC I know the theory just need the practice. I suppose it is just a matter of lining up all the indicators and going for it . and to double checking my work.
Mudguts is offline   Reply With Quote
Old 01-12-2009, 01:16 AM   #62
Mudguts OP
Mudguts's Avatar
Oddometer: 2,123
So i got home and got right to it
a quick pressure wash before pulling the motor down
start stripping parts off
some springy bits that go up and down
and a shiny new thing that goes up and down
and this it where it stops for tonight, gotta drop the head off in the morning for new valves
old V New
Old 01-16-2009, 05:43 PM   #63
Mudguts OP
Mudguts's Avatar
Oddometer: 2,123
Well got pick the head up last night then hurried home , to start reassembling , 3 hours later she was together , after checking and double check valve gap , & cranking the motor by hand , i felt it was time to drop the spark plug in , and her a kick ( battery is rooted )
so wheeler outside flip out the kick starter , and give a boot full
the first thing i thought was ......SHIT this has compression
forgetting to turn the fuel on and 10 kicks later ,
i turn the fuel on two kicks and she fired up Oh what a lovely sound
of HI-comp 540 KTM EXC , big and meaty but sharp and crisp
I excitited , I have to take her around the block
Old 01-16-2009, 06:01 PM   #64
OldDog
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,697
Well done Mudguts, there are few things sweeter than the first bark out of a newly rebuilt motor, hope you enjoyed the ride.
Oh and don't worry about the fuel thing, we all do that
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 02-09-2009, 04:40 PM   #65
vallarian
Position doubtful
Oddometer: 55
Running in
Well done with kit install Mudguts. Must be satisfying seeing it come together. Can't remember which thread I read, but there is some good info around on running-in theory if u can find it (basically slowpoke vs WFO) J
vallarian is offline   Reply With Quote
Old 02-12-2009, 09:16 PM   #66
macuser
macuser's Avatar
Oddometer: 448
next time u buy wheel bearings just get them from a bearing shop rather than a bike shop and you'll save lots of $.
2003 KTM 640 Adventure I made from an enduro model
2000 KTM 50 Pro Senior air-cooled
1998 KX 100; had(2007 KTM 450EXC, 2003 KTM 450SX 6sp, electric start, 18";1999 WR400 Baja Designs)
macuser is offline   Reply With Quote
Old 02-14-2009, 04:16 AM   #67
teti
especie en extincion
teti's Avatar
Oddometer: 143
Originally Posted by Mudguts
the nab bracket mounted ( with new bracket on trilpe clamp )
road book mounted
All finsished stage one
mugguts buen dia, serias tan amable de pasarme las medidas del soporte de road book ?
cuantos centimetros desarrolla hacia adelante , hacia arriba , siempre tomando como referencia el pivote de la direccion , estoy por copiar el anclaje q tenes puesto en tu moto , y si tenes una foto de como lo anclaste en el chasis
saludos atte
y gracias
teti
teti is offline   Reply With Quote
Old 02-14-2009, 04:22 AM   #68
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,433
saludos atte
y gracias
teti
So what`s your reply to this one Mudguts??
nevgriff64 is offline   Reply With Quote
Old 02-14-2009, 04:36 AM   #69
teti
teti's Avatar
Oddometer: 143
perdon pero no entiendo , yo uso google para traducir y algunas cosas las traduce mal,
el q tenga las medidas si le las puede pasar
gracias
teti
Old 02-14-2009, 04:43 AM   #70
Sylvia
vir sapit qui pauca loqui
Sylvia's Avatar
Oddometer: 3,635
gracias
teti
pardon but I do not understand, I use google to translate and some things translate them bad,
the q has the measures if him teti can
pass
thanks
Slightly Orange
Sylvia
Sylvia is offline   Reply With Quote
Old 02-14-2009, 04:45 AM   #71
Sylvia
Sylvia's Avatar
Oddometer: 3,635
saludos atte
y gracias
teti
mugguts good day, serious so amiable to pass the measures to me of the support of road book?
whichever centimeters develop forwards, upwards, always taking like reference the pivot from the direction, I am about to to copy anchorage q tenes put in your moto, and if tenes a photo of how you anchored in the chassis
greetings atte
and thanks
teti
Slightly Orange
Sylvia
Old 02-14-2009, 04:51 AM   #72
Mezo
Oddometer: 2,129
saludos atte
y gracias
teti
I think he`s saying,
Hello Mudguts,
Would you please pass the measurements of the support for road book.
how many centimeters develops forward, upward, against the direction of the pivot, I am copying the anchor post in your bike, and if you got a photo as anclaste in the chassis.
greetings and thanks atte Teti.
Well thats how Google translates it, he basically wants to do the same as you i think, spanish is the language.
Mezo.
Mezo is offline   Reply With Quote
Old 02-14-2009, 05:50 AM   #73
mookymoo
Mookish Mook
Oddometer: 4,396
Correct.
Hes after the measurements of the nav post, to copy it. (Teti is argentinian and imported stuff there is very expensive - so hes trying to do a DYI job)
Mudguts, how did you get on with a possible clone of the fairing?
mookymoo is offline   Reply With Quote
Old 02-14-2009, 12:50 PM   #74
Mudguts OP
Mudguts's Avatar
Oddometer: 2,123
Yeah cool I'll get the basics .If any one has a CAD program they can lend me
Old 02-14-2009, 03:25 PM   #75
teti
teti's Avatar
Oddometer: 143
no seria tan necesario la prolijidad , solo mas o menos con una regla cuanto desplaza hacia adelante y cuanto hacia arriba del eje pivote , yo saco mis propias conclusiones .
mi idea es partir http://www.advrider.com/forums/showthread.php?t=400288 como este post , empezar por la torre o soporte de gps y q sirva para anclar el carenado ( fairing ) , tomar basicas ideas de mi 990 dakar , pero en otras dimensiones , me explico?
agradezco un monton a todos ustedes por prestarme atencion a mis pedidos , espero en algun momento poder retribuir sus favores , lamento mucho molestarlos pero me facilitan en gran parte la tarea , y siempre una foto ayuda mas que los textos .
no tengo a mano tantos elementos como ustedes pero tengo mucha conviccion de poder lograrlo con mis manos y su ayuda , de dejarla linda y conseguir el objetivo , una hermosa 530 exc RALLY
gracias , gracias , gracias
teti
Times are GMT -7.   It's 09:17 AM.
