Old 02-14-2009, 03:26 PM   #76
teti
especie en extincion
teti's Avatar
Oddometer: 143
nonserious so necessary the prolijidad, single more or less with a rule whatever moves forwards and whatever upwards of the axis pivot, I draw my own conclusions.
my idea is to start off http://www.advrider.com/forums/showthread.php?t=400288 like this post, to begin by the tower or has supported of gps and q serves to anchor the fairing (fairing), to take basic ideas from my 990 to dakar, but in other dimensions, I explain myself?
I thank for a pile to all you to pay attention to me to my orders, at some time hope to be able to repay its favors, moan to bother them much but facilitates I the task to a great extent, and a photo always helps but that the texts.
I do not have so many elements by hand as you but I have much conviction of being able to obtain it with my hands and their aid, to leave it is contiguous and to obtain objective, beautiful 530 exc RALLY
thanks, thanks, thanks
teti
teti is offline   Reply With Quote
Old 02-14-2009, 04:04 PM   #77
mookymoo
Mookish Mook
Oddometer: 4,393
este Traduccion de google es terrible
teti
Basically, what he is after is the height & fwd measurement of the nav post, measured relative to the stem.
He'll work it out from there on.
(I would suspect that the height/fwd measurement of the centre attachment point for the fairing is going to be useful too)
Hes going to draw on this and other threads to work out the nav post, fairing etc.
While he doesnt have the resources we might, hes going to build a sweet 530 Rally.
mookymoo is offline   Reply With Quote
Old 02-14-2009, 09:00 PM   #78
teti
teti's Avatar
Oddometer: 143
las lineas en blanco y negro son las medidas que necesito , y si tienen una foto como la amarran al chasis
espero aclarar las medidas que necesito
gracias
teti
Old 02-14-2009, 11:03 PM   #79
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,114
height 275mm
length 290mm
weight 35mm
Mudguts is offline   Reply With Quote
Old 02-16-2009, 05:05 AM   #80
teti
teti's Avatar
Oddometer: 143
Originally Posted by Mudguts
height 275mm
length 290mm
weight 35mm
manos a la obra , algo va a salir , enviare fotos del proceso
gracias
teti
Old 02-16-2009, 06:45 AM   #81
Mezo
Oddometer: 2,129
Talking Mezo translation services via iGoogle
gracias
teti
The lines in black and white are the steps I need, and if you have a photo of how to fix to the the chassis.
I hope to clarify the steps that i need.
Cheers mate.
Mezo is offline   Reply With Quote
Old 02-16-2009, 06:52 AM   #82
Mezo
Oddometer: 2,129
gracias
teti
Then he said (according to iGoogle)
"hands-on, something will come out, send photos of the process"
Your guess is as good as mine
We need LukasM to translate this blokes wishes, im sure he lives in Spain.
Mezo.
Old 02-16-2009, 07:03 AM   #83
LukasM
Oddometer: 5,417
Mezo,
Looks like Teti is all set. He wanted some rough measurements - which he got thanks to you guys translating and Mudguts measuring. He is going to work on it and will send pictures when done.
Teti,
La proxima vez que necesitas ayuda con una traduccion, puedes mandarme un mensaje privado.
Saludos,
Lukas
Old 02-16-2009, 07:10 AM   #84
Mezo
Oddometer: 2,129
Originally Posted by LukasM
Mezo,
Teti,
Saludos,
Lukas
Cheers Lukas,
I know its not a DR650 but a very interesting thread & hopefully we nick some of his ideas for the DR, Mmmwhhooaaaaa
Mezo.
Old 02-16-2009, 07:15 AM   #85
LukasM
Oddometer: 5,417
Absolutely agree Mezo, that's why I was the first to reply to the same thread in the Thumpers forum.
I love rally bikes and especially people posting pictures of their build-ups!
Old 02-21-2009, 07:09 AM   #86
teti
teti's Avatar
Oddometer: 143
Mezo,
Teti,
Saludos,
Lukas
ok muchas gracias
sobre el tema de consumo de corriente, el generador de la 530 tiene 150w y viene con lampara de 35w, se puede llevar a 55w o sobrecargo mucho el alternador y regulador de voltaje ?
la idea es montarle un HID (55w) para la baja, y cambiarle la optica con la futura mascarilla o fairing ( en proceso de fabricacion).
saludos a todos y suerte
teti
Old 02-21-2009, 07:29 AM   #87
teti
teti's Avatar
Oddometer: 143
[quote=Mudguts]
Se me ocurrio una idea , opinen si es mala
en lugar de atornillar en el eje de la direccion el soporte para el gps y road book , sacar con planchuela dobles desde atras del eje una de cada lado y unirlas adelante , agarrado con tornillos de la parte de atras del eje de direccion la parte plana del chasis , ilustre una foto los puntos amarillos seria donde lo amarraria , con esto me evito desarmar la direccion y dejar huecos en el chasis .
que les parece?
saludos
teti
Old 02-21-2009, 01:59 PM   #88
Mudguts OP
Mudguts's Avatar
Oddometer: 2,114
yes you could do it that way ,you will find the there is allready a hole thought the frame neer the head stem you could utillise that , or weld on a boss. i think fabricating a simple boss is far stronger then the bolt on you will find that bolt will come loose after a while .
Old 02-21-2009, 01:59 PM   #89
Mudguts OP
Mudguts's Avatar
Oddometer: 2,114
Old 02-21-2009, 02:23 PM   #90
teti
teti's Avatar
Oddometer: 143
la idea es colocar remaches con rosca y perforar mas abajo de cada lado
buena idea ?
mala idea ?
teti
Times are GMT -7.   It's 11:05 PM.
