Old 02-21-2009, 03:43 PM   #91
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,106
Threaded rivets ( cative nuts, nut serts) tend to come loose unless welded
good thinking thou, there is alot of stress where the Nav mounts to the frame with all the pounding the bike gets bolts can come loose , if you work out the leaverage ratio for 1lb onthw top of the nav bracket to where it mount to the frame you be suprised, the most common weld on mount look like the letter B thats welded on to head stem , that what 99% of the dakar bikes use because it works
veru east to make , you can do it will hand tools and a block of chro'mo steel ( same as bike frame
Mudguts is offline   Reply With Quote
Old 02-21-2009, 03:49 PM   #92
teti
especie en extincion
teti's Avatar
Oddometer: 143
usted lo tiene con tornillos o soldado ?
saludos teti
teti is offline   Reply With Quote
Old 02-21-2009, 04:02 PM   #93
Mudguts OP
Mudguts's Avatar
Oddometer: 2,106
welded on to frame ( sorry can't access smugmug ) but go throu my photos and have a look i should have a photo in there
http://mudgutts.smugmug.com/gallery/2073911_7zf93
Old 02-21-2009, 06:37 PM   #94
mookymoo
Mookish Mook
Oddometer: 4,391
Originally Posted by teti
Se me ocurrio una idea , opinen si es mala
en lugar de atornillar en el eje de la direccion el soporte para el gps y road book , sacar con planchuela dobles desde atras del eje una de cada lado y unirlas adelante , agarrado con tornillos de la parte de atras del eje de direccion la parte plana del chasis , ilustre una foto los puntos amarillos seria donde lo amarraria , con esto me evito desarmar la direccion y dejar huecos en el chasis .
que les parece?
saludos
teti
For what its worth, thats how MecaSystem seem to mount it. (ie bolted to the frame - with a bigger contact surface area - rather than the RSConcept which is meant to bolt to the stem.
mookymoo screwed with this post 02-21-2009 at 06:50 PM
mookymoo is offline   Reply With Quote
Old 02-21-2009, 06:44 PM   #95
Mudguts OP
Mudguts's Avatar
Oddometer: 2,106
mook the boss is welded to the frame . the boss is a solid block compared to 2.5 chro-mo plate where teti want to bolt it , i beieve the Mecca boss is weld on as well.
Old 02-21-2009, 06:54 PM   #96
mookymoo
Mookish Mook
Oddometer: 4,391
Id agree - welding would be strongest.
The bike in the pics is a Patsy Quick / Meca-built bike - nothing welded that I saw (but maybe they do now..)
From pics I had seen posted, I thought the RSConcept was also bolted (but bolted to the stem) - maybe no-one does that anymore...
Old 02-21-2009, 07:09 PM   #97
mookymoo
Mookish Mook
Oddometer: 4,391
By the way, mudders, what step-up in fork springs have you gone for to handle the extra fuel? (before and after spring weights)
Old 02-21-2009, 07:13 PM   #98
teti
teti's Avatar
Oddometer: 143
esta foto lo explica claro lo que yo pretendia , atornillar en lugar de soldar o perforar la direccion , ahora la pregunta funciona bien, aguanta ?
saludos y gracias
atte teti
Old 02-21-2009, 09:00 PM   #99
Mudguts OP
Mudguts's Avatar
Oddometer: 2,106
Fork spring .48 115 oil height,18clicks back from full F,ing perfect
Old 02-22-2009, 02:02 AM   #100
mookymoo
Mookish Mook
Oddometer: 4,391
Did you have suspension set up before you added the tank? What was it then?
Im trying to get a feel for the suspension change the tank requires.
Old 02-24-2009, 02:36 AM   #101
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,738
rallye build
So hows the progress/finished product going mudguts???
...and a couple of pics would be nice. Also interested in the fairing - how does it go redirecting the wind at speed from your helmet? I ask as I notice it doesn't have a forward return (curve profile) and was wondering if its height or profile make a significant difference?
Cheers Pete.
Pete640 is offline   Reply With Quote
Old 03-01-2009, 02:37 PM   #102
Mudguts OP
Mudguts's Avatar
Oddometer: 2,106
And some updated photo's
Old Paint sceme
New paint
Old 03-01-2009, 08:28 PM   #103
guymcfly
guymcfly's Avatar
Oddometer: 953
Thats coming along very nicely...good job!
guymcfly is offline   Reply With Quote
Old 03-09-2009, 05:27 PM   #104
teti
teti's Avatar
Oddometer: 143
Old Paint sceme
New paint
muy bonita , mas fotos de todos los angulos , desde arriba conduciendo
saludos y suerte
teti
Old 03-09-2009, 07:03 PM   #105
Bigem
Bigem's Avatar
Oddometer: 2,550
saludos y suerte
teti
Translation:very nice, but photos from all angles, from the top leading??
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Times are GMT -7.   It's 12:41 PM.
