Old 04-25-2004, 08:45 PM   #1
Pinarretta OP
Bus driver
Pinarretta's Avatar
Oddometer: 458
Bluhduh Rust in rear wheel
I decided to change my own tires thanks to this group.
So I remove the rear wheel and see this accumulation of rust.
What's the conventional wisdom on how to handle this?
-Paul
I feel a lot more like I do now than I did when I first got here.
I know you believe you understand what you think I said, but I am not sure you realize what you heard is not what I meant.
Pinarretta is offline   Reply With Quote
Old 04-25-2004, 10:15 PM   #2
BARB
Oddometer: 2,669
Clean it before you put it back together. Barb
BARB is offline   Reply With Quote
Old 04-25-2004, 10:55 PM   #3
Pinarretta OP
Bus driver
Pinarretta's Avatar
Oddometer: 458
Done that. I guess I was looking for any tips on prevention.
Anyone try any coatings? Or do I just keep cleaning it up every tire change?
Oh yeah, the bike's just over 2 years old.
-Paul
Old 04-27-2004, 06:47 AM   #4
Ruskie
Oddometer: 29,237
Go to a West Marine Store or buy on line some "Corrosion Block". Give it a good douche' with the stuff and let set for a few minutes. Then wipe it all off. Be sure to torque the studs to specs. This leaves a fluid film on the metal parts so it will not corrode. When I've removed tires and tubes from my conventional spoked wheels I have always squirted this stuff at each spoke base and I never get the rust problem.
Ruskie is offline   Reply With Quote
Old 04-27-2004, 06:52 AM   #5
Pinarretta OP
Bus driver
Pinarretta's Avatar
Oddometer: 458
Thanks Ruskie. I'll give it a go.
-Paul
Times are GMT -7.   It's 10:43 AM.
