11-14-2012, 02:07 PM
#2086 | |
God Bless Texas
Oddometer: 1,470
If I was going to go back to serious LD riding, I'd get a custom but for my 1-3 day trips, it's perfect.
Todd R. '78 R80/7 '06 FJR1300A "Gentlemen, gentlemen, be of good cheer, for they are out there and we are in here!" - Robert Culp, attributed by Hugh Hefner as the official slogan of the Playboy Mansion |
11-15-2012, 06:39 AM
#2087 | |
Oddometer: 629
2007 FJR1300 2007 FZ6 (Dirt bike) |
11-15-2012, 08:53 AM
#2088 |
Oddometer: 1,104
I'm not tempted by the new '13. My old '04 runs strong, has MCcruise, and is paid for. The only thing I want is to upgrade the suspension.
11-16-2012, 10:27 AM
#2089 |
Screaming Banshee
Oddometer: 272
My new '09 AE is just fine... but I wouldn't mind the cruise control. I can buy a lot of farkles for the difference in price. If they bring in the AE/AS model... then I'll reconsider.
Everything is on its way to somewhere... |
11-18-2012, 03:50 PM
#2090 |
Oddometer: 319
PCIII + cat simulator
Does anyone here run a PCIII on their FJR, and if you do, do you also run the cat eliminator plug? I have been running a PCIII for years with no other mods, with the O2 sensor disconnected (this was the recommended configuration from Dynojet). However recently I became aware that they came out with an O2 sensor plug that is nothing but two resistors across the 4 wires. Some have said the adaptation in the FJR ECU does weird things if it senses a sensor missing, even if no code is thrown. The plug does something and fools the ECU into thinking an O2 sensor is there but doing nothing I guess. This was not apparent or known 5 years ago when I fitted the PCIII and I have lost touch with the cranky old hardcore FJR folks since.
The PCIII improved things a lot at the time but lately I've been wondering just what its tiny little brain is doing about the open O2 sensor socket. Any feedback rumor innuendo or just plain SWAG appreciated. I have a 2007 with the altitude fix updated ECU. |
11-18-2012, 04:25 PM
#2091 | |
Oddometer: 4
Hi fred. Mine is also a 2007 with the altitude fix. I dont run a PCIII, I have considered it a while ago but it was too expensive (here in Europe at least..), I didn't want any performance improvement only a fix to the lean surge. This summer I got that O2 sensor plug and yes it's basically a plug with two resistors, but it did make a very significant improvement!! if you disconnect the sensor, the bike will give a error because it cannot read any value, mind you the ECU doesn't connect with the sensor in any tecno-USB-like system! it merely reads resistance values which is what the O2 sensor outputs. With the plug the bike doesn't give you the error because it can now read something, only catch is the reading for the sensor is always the same, the ECU is sufficiently idiot not to understand something is out of the ordinary... :-)
What I was told from a friend that recommended it to me, is that the plug resistance values "fool" the ECU in delivering more fuel to the engine in a closed throttle. This has the huge advantage that when opening the throttle the bike will now be much smoother, because there is not an abrupt fuel flow increase. You also notice the bike has less engine braking. In my case it also improved fuel mileage slightly! It's cheap, so no big risk in trying. But I cannot say how it will work with a PCIII. Cheers. V. Quote:
11-18-2012, 07:16 PM
#2092 |
Oddometer: 242
Pdm60
Have any of you tried or are using the Rowe Electronics PDM60 power controller? If so I'm interested in your opinion and mounting options.
![]() http://www.rowe-electronics.com/modules
Figures don't lie, but liars can figure BruceWA screwed with this post 11-19-2012 at 01:39 PM |
11-19-2012, 02:54 AM
#2093 | |
Oddometer: 319
Yes that lean surge is one of the issues I'd like to fix, it is still there but not as bad with the PCIII. It is interesting that on the Dynojet website they have a map specifically for the euro version with O2 plug and O2 sensor disconnected, the other maps do not mention O2 plug at all but do mention disconnected O2 sensor. I may try the euro map too. That era Yamaha seemed to really not pay a lot of attention to ECU and software very much. I have had several of their bikes 06-08 and the fuel mapping was not so good. Motors themselves (the metal bits) are brilliant. Also were some final assembly issues but that was not design per se. The altitude problem drove me crazy but they eventually fixed it. Maybe an issue WRT labor vs too many varying emissions regs worldwide who knows. Thanks for the info. |
11-19-2012, 06:28 AM
#2094 | |
Yamaholic
Oddometer: 319
'06 R1 LE, '13 FJR, '12 XTZ12, '09 T Max |
11-19-2012, 06:46 AM
#2095 | |
Oddometer: 319
About a year later after a lot of back and forth with Yamaha, I got a letter about an updated ECU. Fixed the problem and has not come back. |
11-19-2012, 02:31 PM
#2096 | ||
Mod Squad
Oddometer: 53,463
http://www.advrider.com/forums/showthread.php?t=638076
ADV decals, patches & flag? Here GB screwed with this post 11-19-2012 at 02:40 PM |
11-19-2012, 04:03 PM
#2097 | |
Oddometer: 242
![]() Thanks I'll take a look here
Figures don't lie, but liars can figure |
11-30-2012, 03:41 AM
#2098 |
(Super-Genius)
Oddometer: 4,640
Anybody know what is going on with the fjrforum?
11-30-2012, 03:49 AM
#2099 |
FJR1300 / FLHX
Oddometer: 263
Looks like they might be in the middle of a forum upgrade. (Do forum upgrades ever go smoothly??)
'fooz
'05 Yamaha FJR1300 '09 Harley-Davidson FLHX Street Glide |
11-30-2012, 06:16 AM
#2100 |
Muchacho mui loco
Oddometer: 2,297
