Old 12-02-2012, 03:38 PM   #2116
1greenmachine
Oddometer: 321
Originally Posted by bungie4 View Post
The FJR masks its weight exceptionally well. Anything above a walking speed and the weight disappears. It's probably the easiest bike I've ever owned to ride slow. But make no mistake, if you tip it over a little to far and think your just gonna dab a foot to save it; Well, enjoy your new knee!
I figured its probaly heavy, my sv after so much lean is a struggle to get back up. I would just like a bike i can hop on set the cruise and go without eating the wind the whole time like my bike. I jokeingly mentioned getting a harley but the girlfriend said no i wanna go fast.
1greenmachine is offline   Reply With Quote
Old 12-02-2012, 04:53 PM   #2117
smoker2
smoker2's Avatar
Oddometer: 19
Originally Posted by 1greenmachine View Post
So comeing from a sv how big of a jump was it, i love my sv650 but it sucks for 2-up and an fjr is kinda the direction i'd like to go. I know its alot bigger size and weight but once moving is it that noticable, and how tippy is it in low speed manuevering?
I didn't go directly from the SV to the FJR, had a number of bikes in between. As far as low speed manuevering, once you learn how to ride it it's really not a problem. I wouldn't say it's "tippy" per se, but it does take a little more throttle/clutch control to ride it well at lower speeds. You'll definitely notice the weight at anything below 10mph (figure 8 type manuevers). I'd recommend taking some sort of control class if/when you get it. Practice, practice, practice.
smoker2 is offline   Reply With Quote
Old 12-02-2012, 05:29 PM   #2118
1greenmachine
Oddometer: 321
I'm really likeing the new fjr but its a long time out before i could swing it, and yeah i'd put some time on it before takeing a passenger, I'm not really one that will get into really tight spots but is good to have the experience. The thing l like is that is bigger but not to big to control for someone my size.
Old 12-02-2012, 05:43 PM   #2119
FJracer
FJracer's Avatar
Oddometer: 50
Originally Posted by BruceWA View Post
The FJR fits me better and I have a hsitory with Yamaha that is positive, not so with Kawasaki.
Same here! 6 years + with an 04. Will replace with same at some point.
FJracer is offline   Reply With Quote
Old 12-03-2012, 02:25 PM   #2120
jules083
Oddometer: 1,140
Yep. I've dropped mine twice, both times I was stopped and it was my own fault. Once when a passenger got on before I was ready, once when I forgot to put the sidestand down. However, once she starts to go there's no catching it. The first time I was in pain for about a week or so from trying to catch. Second time I learned when to get out of the way.
Sent from my Desire HD using Tapatalk 2
Ninja 250 for sale cheap:
http://www.advrider.com/forums/showthread.php?t=854880
jules083 is online now   Reply With Quote
Old 12-05-2012, 09:01 AM   #2121
WAH III
Oddometer: 51
Hate to admit it but twice for me too. Both times sitting still. The difference was the frame sliders. First time, $450 worth of plastic damage. Installed frame sliders and narry a scratch on the second drop. On the topic of weight, my front end seem to feel heavier after a new front tire has about 3,000 miles on it. Requires more steering input.
You've come far pilgrim, were it worth the trouble?
Eh? What trouble? - Jeremiah Johnson
WAH III is offline   Reply With Quote
Old 12-05-2012, 04:48 PM   #2122
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: Bristol Hills in the Fingerlakes region of NY
Oddometer: 2,269
I usually run a larger windshield on the bike. I thought the stocker was near worthless so I cut it down. It only takes a few minutes to change so I now have an option if I'm going to ride on a very hot day. Compared to stock, the wind around my helmet is much cleaner with this setup.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
madeouttaglass is offline   Reply With Quote
Old 12-05-2012, 05:00 PM   #2123
SlowRoll
Oddometer: 1,124
Yeah, I also run a cut down summer shield. It works but am thinking of cutting another 2" off it.
SlowRoll is offline   Reply With Quote
Old 12-06-2012, 04:30 AM   #2124
jules083
Oddometer: 1,140
You just talked me into frame sliders. Thanks. I never fixed mine, but to do it right would be a lot of money. Small scuffs on a lot of plastic, and a dent in the tank that you can't really see unless you are looking for it.
Old 12-07-2012, 06:19 PM   #2125
Reverend12
Well there it is..
Reverend12's Avatar
Oddometer: 1,133
I bought these for a tipover they'll work..
Logos
Color
$54.99
This high quality set of OES frame sliders
fits the 2006-2012 Yamaha FJR-1300
(both A & AE models). These sliders have
high impact strength and use 6061T6
aluminum inserts which are pressed in.
Without the inserts, the engine mount
screws would need to be tightened on a
regular basis. High strength, rust-resistant
mounting screws are included with this
set. Absolutely no fairing modifications
are required to install. Complete
instructions are available on this site. This
set can be installed in under ten minutes.
More info on OES Frame Sliders
Side
Color
Logo
$27.49
If a frame slider is damaged
in a crash or by a tip-over,
you can replace the side you
need by ordering here. Side
is as viewed from sitting on
the bike.
Extended 06-12 FJR-1300 Frame Sliders
Our 06-12 FJR-1300 frame sliders
can also be purchased as an
extended version. We make the
sliders 1/2 of an inch longer for
customers wanting a slightly longer
slider set. This is the only extended
FJR slider that we offer and is
offered in black only. All mounting
hardware is included.
Logos
$64.99
Reverend12 is offline   Reply With Quote
Old 12-07-2012, 08:01 PM   #2126
BkerChuck
Oddometer: 6
First thing I did when I picked up my '07 this year was those exact frame sliders. One of the easiest installs ever and look really good as well.
BkerChuck is offline   Reply With Quote
Old 12-10-2012, 09:44 PM   #2127
jules083
Oddometer: 1,140
Thanks, ill order those sliders tomorrow. I need to get 2 sets, my ninja needs them also. Should have done both bikes as soon as I got them anyways.
Old 12-18-2012, 11:57 AM   #2128
DiasDePlaya
DiasDePlaya's Avatar
Oddometer: 599
Send a message via Skype™ to DiasDePlaya
My FJR 1300 AE is doing exactly this:
http://www.youtube.com/watch?feature...&v=EpTgqjcLT9o
How to fix it? Is enough to change the clutch fluid? Maybe to soak the clutch?
DiasDePlaya
"Ya veras como quieren en Chile al amigo cuando es forastero"
Traditional song
DiasDePlaya is offline   Reply With Quote
Old 12-18-2012, 12:16 PM   #2129
JimNtexas
Oddometer: 239
By any chance has someone put regular car motor oil into your bike? Most automotive motor oils have additives that will cause excessive slipping when used with motorcycle wet clutches. The AE computer goes nuts if there is excessive clutch slip.
Are you getting an error code on the instrument panel?
Ninja 250 - Yamaha FJR1300AE
Chandelle Flying Club
You can only be young once. But you can always be immature.
- Dave Barry
JimNtexas is offline   Reply With Quote
Old 12-18-2012, 12:18 PM   #2130
DiasDePlaya
Oddometer: 599
No error code. Is probable that someone put car oil. Next time I will change the oil by my self as usual!
DiasDePlaya
Traditional song
Times are GMT -7.   It's 03:45 AM.
