Old 09-08-2009, 09:16 PM   #436
Steve G.
Steve G.'s Avatar
Oddometer: 7,137
Originally Posted by sagedrifter
I also have the Givi 52 but, I would go with the new slightly taller 55 liter top case. It has better looks to me. There is a pre-installed light kit with a key less lock too, pricey but very nice. The Givi mount is nice and sturdy on the Gen II FJR's.
I was thinking of getting a smaller top box, maybe a factory Yamaha one for my Gen 1. Everywhere I see one advertised, there are specific warnings not to have panniers and top box together, worries of overloading the bike. Is this really an issue, or just the lawyers keeping clear of any kind of distant liability?
Steve
Steve G. is offline   Reply With Quote
Old 09-09-2009, 08:41 AM   #437
Fundamental
Fundamental's Avatar
Oddometer: 229
Steve
It's CYA
Fundamental is offline   Reply With Quote
Old 09-09-2009, 09:17 AM   #438
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,447
Talking
There is also a 11 pound rear rack limit....
That pic above in CO was with at least 30 lbs back there, one reason to use the Givi mounting system. I went with Givi since I needed a top box for more than light clothes and a map or a bottle of water...
Look inside the Yamaha top case and make sure you want to spend all that money on something that can't hold all that much. Don't go by the 50 liter description.
I wanted the factory top case untill I saw it... The main reason I use mine is to carry my laptop and cameras along with rain gear and helmet shields, cleaning supplies etc.. The Givi can hold two helmets. Function over form, my 52 is three years old and has about 30K on it, nothing has broken, no issues at all. I had a Shad before and would not go back to it.
I did like the factory pan top case on the Honda ST, the suspension is a nice feature and the build quality was great. I saw a pan top case fitted to a FJR a while back, it looked better than the Yamaha one... Go figure. Its smaller like the Yamaha case but, it does work well with some custom fitting, another option if you can find a used one..
sagedrifter screwed with this post 09-09-2009 at 09:23 AM
sagedrifter is offline   Reply With Quote
Old 09-09-2009, 11:59 AM   #439
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,065
As somewhat new to Yamaha ownership, I was surprised to learn of Yamaha's 'habit' of introducing new models just after Labour Day each yr.
Steve
a good bit of the mfg introduce new models in the fall/sept.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 09-09-2009, 04:50 PM   #440
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,448
Going off the theme a bit here but I just double stacked my bar risers and I would have to say that this addition along with my existing Russell seat is the perfect set up for me.
I'm using Heli risers with D&D's 10 degrees on top.
I just had to share
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 09-11-2009, 08:43 PM   #441
kwugtt
Oddometer: 1
bag covers
[quote=sagedrifter]I did a round trip from Florida to Alabama last week end. 1,366 miles, tried out my new sargent seat and camera mount.
I've added just about everything I want to. Throttlemeister, grip puppies, throttle rocker, big screen, bag covers, wild bills pegs, givi top box, ram mounts, reflective decals, FZ1 mirrors, GPS, head light guards, tank protector........
And more I can't remember
where did you get those bag covers, they're hot
kwugtt is offline   Reply With Quote
Old 09-12-2009, 06:14 AM   #442
Putts OP
Gettin' there.
Putts's Avatar
Oddometer: 11,390
I just had to share
Say, I been thinking of doing just that. Would you be so kind as to post a picture? Thanks.
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is online now   Reply With Quote
Old 09-12-2009, 07:48 AM   #443
sagedrifter
Southern Explorer
Oddometer: 1,447
[quote=kwugtt]
They were made by Sargent and the last time I checked they stopped making them.
Old 09-12-2009, 08:44 AM   #444
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 495
Steve
The 2010 Yamahas are on their website now.
'08 Suzuki DR650
'15 Yamaha FZ 07
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 09-12-2009, 01:35 PM   #445
richarddacat
abnormal character
Oddometer: 3,448
Dare ya go..
Mid-TN Tag Riders
Old 09-12-2009, 01:39 PM   #446
richarddacat
abnormal character
Oddometer: 3,448
If you can make anything useful out of these measurements, here they are,
43" from end of bar end to ground
34.5" " " pegs
27" " " center of seat.
I'm happy
No problem with the cables except taking the bolt out of the hose clamp on the clutch hyd. hose that's mounts to the frame.
Mid-TN Tag Riders
Old 09-13-2009, 06:40 AM   #447
Putts OP
Gettin' there.
Putts's Avatar
Oddometer: 11,390
Dare ya go..
Thanks mang! I think I'm gonna do dat.
Old 09-13-2009, 07:28 AM   #448
OnOff
OnOff's Avatar
Oddometer: 1,646
Love this bike...
Sooo different from my XR650
Fresh Avons, forks GP Suspension tweaked, Penske rear shock...
MMMMM time for a ride.
OnOff is offline   Reply With Quote
Old 09-16-2009, 07:08 PM   #449
Powerslave
n00by tires that would be
Oddometer: 316
2003 Yamaha FJR
I know the main model upgrade was in 2006 and the 2003 have shorter wheelbase and direct more heat at the rider - anything else I should look for? I'm thinking about getting a low mile 2003 well farkled - everything i've read in the past made me think that I'd want a 2006 or newer but not looking to spend alot and this one has presented itself....oh the dilemas in life.
I'll check out the fjr sites too but thought I'd brain drain here too.
thanks in advance
Edit:
brake rotors are smaller - can they be swapped out easily for the 04 ones? (320mm rotors, versus the '03's undersized 298mm rotors)
Powerslave screwed with this post 09-16-2009 at 07:24 PM
Powerslave is offline   Reply With Quote
Old 09-16-2009, 07:34 PM   #450
sagedrifter
Southern Explorer
Oddometer: 1,447
thanks in advance
If it has some miles on it and its running smooth... and its cheap! Maybe yes if the money is the issue. If it has 50K on it its probably fine if it is quiet, smooth and strong.
The 06 and later had a revised nose and wind screen to relieve back pressure, the later dash is nice and the GEN 2 heat revisions make the bike much cooler. There was a valve train revision in 06 that changed the valve guides I think... aka GEN 1 tickers were an issue to be aware of.
I would go with an 06 or later.
The FJRforum and FJRriders are two forums that can answere any question in detail
Start here:
http://www.fjrforum.com/forum/index.php?showtopic=3945
FJR Model Comparison pdf with 8 pages of info:
http://www.fjrforum.com/files/fjrcomparo.pdf
Times are GMT -7.   It's 12:12 AM.
