Old 01-05-2012, 11:50 AM   #1306
markjenn
Oddometer: 10,393
Originally Posted by FiveG View Post
Anyone taken their Feejer out for a track day? I'm considering it for this May.
Not a hard-core track day, but an instructional day at the track. Maybe it was just the change of pace, but it did fantastic - I think I enjoyed riding the FJR more than a sportbike. You do have to stay within the limits of cornering clearance though, so your ultimate pace will be down a bit from what someone competent on on Gixxer can do, but you'll be plenty fast and you can use that gorgeous 125-hp engine to its fullest which is hard to do on the street.
- Mark
Old 01-05-2012, 02:27 PM   #1307
bmwhd
God Bless Texas
bmwhd's Avatar
Oddometer: 1,476
Originally Posted by corndogs View Post
What are you guys doing for the really stiff throttle pull? G2 I read does not change that, unwinding spring is not what I want to do. Nhas anybody added a spring on the end of tb to pull reverse direction, or just use a cramp buster
Unwinding the spring is a very easy and safe mod. I can't imagine riding a Gen II without doing that.
Todd R.
'78 R80/7
'06 FJR1300A
"Gentlemen, gentlemen, be of good cheer, for they are out there and we are in here!" - Robert Culp, attributed by Hugh Hefner as the official slogan of the Playboy Mansion
bmwhd is offline   Reply With Quote
Old 01-05-2012, 04:19 PM   #1308
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,152
Sure have. was plenty surefooted I was actually being held up most of the day by a rider on a CBR1000RR that would haul balls in the straights (could barely keep up let alone pass) and then deploy anchor in the corners forcing me to slow down. I was in the lowest run group so no passing in corners straights only. Which made passing Mr.CBR a difficult task
That's Mr.CBR behind me there just over my shoulder. I managed to beat him to the corner by outbraking him.
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 01-05-2012, 05:00 PM   #1309
FiveG
Oddometer: 150
Very very cool. I'm psyched. Heading to NJMP in May.
I hope you succeed, but no matter what happens, Godzilla will win.
"Steve Martin," Godzilla (1985)
FiveG is offline   Reply With Quote
Old 01-05-2012, 07:34 PM   #1310
Honkey Cat
Tailights Fade!
Oddometer: 1,089
Spring
That's the spring in the middle? I'll have to do it this weekend.
Also not really a complaint, but do the fjr feel heavy when turning, it turns nice to a point then wants to upright itself
Honkey Cat is offline   Reply With Quote
Old 01-05-2012, 08:05 PM   #1311
richarddacat
helmet full of Blues
richarddacat's Avatar
Oddometer: 3,306
Check your front tire pressure. I run mine at 39psi. Next may be the head bearings but wouldn't think that would be a cause as new as your bike is unless the PO screwed with them .....literally.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 01-05-2012, 11:22 PM   #1312
markjenn
Oddometer: 10,393
This is often the symptom of a front tire that has seen better days... having to hold inside bar pressure to keep the bike in the turn.
- Mark
Old 01-06-2012, 04:40 AM   #1313
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 7,994
- Mark
This.
With typical riding you wear arears are in the center of the tire from normal highway riding and on the side from friction in the turns. The transition point does not wear as much and the tire develops a hump.
I wonder where that road goes?
DirtDabber is offline   Reply With Quote
Old 01-06-2012, 06:38 AM   #1314
Honkey Cat
Tailights Fade!
Oddometer: 1,089
tires
Duh, that would totally make sense, I checked pressure but did not think about the wear issue
Old 01-06-2012, 09:43 PM   #1315
markjenn
Oddometer: 10,393
If your riding tends to be more straight-line, you'll often be able to get a front to go 1.5x or 2x longer than a rear, but it is typically false economy as the handling gets pretty awful with the worn front. With the FJR, I always replace in pairs, even if the front looks like it has some mileage to give.
- Mark
Old 01-08-2012, 08:11 AM   #1316
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,885
- Mark
+1 had this same problem with my stock front tire after about 3K on it. Changed it out and noticed a night and day difference in the corners.
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 01-08-2012, 11:33 AM   #1317
ducpilot
ducpilot's Avatar
Oddometer: 125
- Mark
It's no race winner but it can be fun dicing around on the FJR...
Instructor Bret Tkacs at Total Control Training level 2 / Puget Sound Safety
Adventurer Rider Training - www.advcamp.com
ducpilot is offline   Reply With Quote
Old 01-08-2012, 06:30 PM   #1318
CheesyRider2
Oddometer: 45
Looking to replace my V Rod this spring-due to considerations as reliabilty, handling, suspension, brakes and storage the FJR is on a rather short list. Concermed about comfort but have sat on a couple and think they are closer to a Naked Bike then a Sport Bike.
CheesyRider2 is offline   Reply With Quote
Old 01-08-2012, 09:06 PM   #1319
Reverend12
Well there it is..
Reverend12's Avatar
Oddometer: 1,446
I have a goldwing and a FJR, the FJR ergos are actually better than the Wing. You won't regret the FJR.
Reverend12 is offline   Reply With Quote
Old 01-08-2012, 09:15 PM   #1320
Jud
Jud's Avatar
Oddometer: 2,290
The FJR is one of the most comfortable bikes I've had and I've had alot. I'm 5'7 with a 30 inch inseam,,,,, if you have a longer inseam you might want to lower the pegs an inch. If you are shorter your reach to the bars might be a tad long and there are aftermarket solutions to that too. As I said, it's perfect for, even run the stock screen. All I've done for comfort is that I bought a second hand Corbin and it was slightly better than the stocker.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Times are GMT -7.   It's 05:52 AM.
