10-23-2012, 07:15 PM
#676 |
mike
Oddometer: 75
dunlop 606's
Did the Dunlop 606's increase the height of your bike? If so how much? Thanks....
Size 120/90/18 and 90/90/21 |
10-23-2012, 07:46 PM
#677 | |
Oddometer: 2,533
![]() ![]() My DR650 is a 'bit' heavier than an XT.
10-24-2012, 05:17 AM
#678 | |
Oddometer: 93
Tubeless XT250
Maybe slower deflate when picking up a puncture on the road. Tube might tear and decompress quickly. Tubeless maybe a little slower allowing a controlled stop. Any ideas why Yamaha put a tubeless on the back? |
10-24-2012, 06:55 AM
#679 |
Oddometer: 5
Hi, I put 606's on my '09 and I noticed the added height right away. I measured from the center of each axle to the ground with 18psi (on road pressure (I run 10psi off road)) front axle to ground=334mm rear axle to ground=229mm. Maybe you can measure yours and let us know what the difference in ground clearance/ride height works out to. The tires have some wear, maybe 600 miles now so maybe -3mm?. The tires were the first thing I swapped on my bike and it was one of the best moves I made IMO.
10-24-2012, 03:23 PM
#680 | |
Oddometer: 285
However, have you considered that in many cases a tubeless tire is not repairable with a plug, rendering the tire useless? Also, a plug is not a permanent solution and the tire would have to be replaced whereas a tubed tire simply requires a new tube... Additionally, it's been suggested that since tubeless tires generally have lower sidewalls, you are at greater risk of damaging the rim as most off road rides include lowering tire pressure. Fortunately your scoot has wire rims and wouldn't be as expensive to replace as cast wheels. I'd think twice about tubeless wheels but of course, it's your bike. |
10-25-2012, 04:02 AM
#681 |
Oddometer: 44
Tubeless tires generally carry more load and as mentioned previously, can be repaired in some cases without removing the tire from the rim. Also, there's no need for a rim lock devise for running low pressures while off road.
For Town: Monster S2R800 ![]() For Country: 2012 XT 250 Wolfman bags/TurboCit Brake Guard/Yamaha Skid Plate/FMF Powercore 4/Barkbusters/Trail Tech Gauges>Baseball, Basketball, & Football all require one ball, Motocross requires two. Hong Kong |
10-25-2012, 03:22 PM
#682 |
Have you guys seen this?
http://advrider.com/forums/showthread.php?t=822894 I am getting one, but does anybody know what the axle size is on the 08 XT? I am mostly getting one for the KLX tho. I tend to go though more tubes & tires on it. Kent |
10-25-2012, 04:16 PM
#683 |
blah blah blah
Oddometer: 1,365
There is actually a guy from New Zealand that makes these for about $80. He is getting together a group of people together in the Minimalist Touring thread to do a group buy. Should be less than $100 shipped to the US.
10-26-2012, 09:45 AM
#684 |
Foamy
Oddometer: 42
dunlop 606's
I noticed a bit more height, but not much. I run 130/90 18's on the rear and 90/90 21's on the front. I never measured how much it raised it......
Foamy.. 2009 XT250 |
10-26-2012, 01:25 PM
#685 |
mike
Oddometer: 75
I ended up getting Michelin T63's so I can keep the normal 120/80/18 in the rear, and 90/90/21 front.Its at the perfect height I didn't want to screw it up like I did with my WRR.
10-26-2012, 07:37 PM
#686 |
Anybody know the bolt pattern for the skid plate? I have an extra drz skid plate and was hoping to modify it to fit. I can figure it out if nobody knows it.
Thanks Kent |
10-28-2012, 08:05 AM
#687 |
Oddometer: 811
If anybody is interested i have the following things for sale, for a 2008 and later XT250
trail tech temperature meter, the kind that goes around the spark plug and displays engine temps while riding 16 tooth front sprocket in excelent condition, with a new OEM yamaha locking tab for it. coleman/stearns atv seat cover, with the bungee mod allready done to it, so it just slides on the seat, super easy to put on and take off, like new, no fade, stains or tears, used for a bit, but always garaged. 2 stock front turn signals, and 1 rear turn signal, will like to sell it all in package for $65 shipped, thanks.
Just some dude... |
10-28-2012, 01:46 PM
#688 | |
Oddometer: 345
10-28-2012, 05:12 PM
#689 | |
Oddometer: 811
pm me if you are interested in the sprocket.
Just some dude... |
10-28-2012, 08:56 PM
#690 |
Alpha Nerd
Oddometer: 90
Started out with 08 XT250 and 08 KLR 650. Went on a trading frenzy, lost a wad of cash, and ended right back where I started, minus 1 year and 10,000 miles. Moral: if you're on the fence about trading up, jump off and think some more.
![]() Kdtrull |
