Old 01-09-2010, 10:07 PM   #211
SMJM
Oddometer: 1
Good Read
I,m planning to buy in the spring so i have been doing a little research. Lots of good stuff here. If I choose the KLX250 I'll be back for some direction for mods etc. Thanks everyone.
SMJM is offline   Reply With Quote
Old 01-10-2010, 10:51 AM   #212
Trueweltall
Backyard Bike Mechanic
Oddometer: 14
I have a 2009 KLX250SF and recently just took leave for 20 days came back wheeled it inside to warm up for about two days and noticed when I went to take it out and start it that it is leaking coolant! I can not really tell where it is coming from but it seems to be around the radiator cap area and then drips down off the frame. I have no idea why it would be leaking coolant now that I wheeled it in to warm up? I just bought it in July 2009 kinda upsetting it is leaking anything...
Trueweltall is offline   Reply With Quote
Old 01-18-2010, 11:43 AM   #213
Trueweltall
Oddometer: 14
Nice day out today, no coolant leaking bike starts up fine and warms up. I go to take off and it shuts off when I put it in gear. Ugh. I know its that kick stand switch too. What a headache.
Old 01-18-2010, 07:18 PM   #214
redpillar
redpillar's Avatar
Oddometer: 877
do yourself a favour and remove the switch. It will fail when you are out in the tullies.
redpillar is offline   Reply With Quote
Old 01-19-2010, 10:05 AM   #215
Trueweltall
Oddometer: 14
How do I go about removing it?
Edit: Just undo the bolt and unplug it from where ever it plugs into?
Old 01-19-2010, 07:13 PM   #216
redpillar
redpillar's Avatar
Oddometer: 877
Just follow the wiring up the frame rail and you will come to the connectors.
Unplug the wires from the switch and plug the connectors on the bike together to remake the circuit.
You just need to get into the habit of lifting your stand every time you sit on your bike, if it isn't second nature already.
Old 01-19-2010, 07:18 PM   #217
mike1952
Oddometer: 1,114
Originally Posted by kmbelt
I have found a dealership here in Kentucky that will sell me an 09' for $4295 + TTL.
Their websites states the following
"No hidden fees,no freight, no setup, no dealer prep, no doc fees. Only add tax & license."
I have not bit the bullet yet, but am saving up to. I don't want to finance it, so it might take a little while.
down to $3799 now in MI or 0hio
mike1952 is offline   Reply With Quote
Old 01-19-2010, 08:57 PM   #218
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
On my DR-Z, I just put a tie-wrap around the the switch so it's always 'on'. No problem starting, but before I did this my boot would hit the sidestand on whoops and kill the motor for second or two. You do have to be careful not to ride off with the sidestand down with any fix you do...but that's just common sense.
Bucko is offline   Reply With Quote
Old 01-23-2010, 11:02 AM   #219
Trueweltall
Oddometer: 14
The switch is broken, even if it(the lever on the switch itself) is up or down it will not keep running when I put it in gear.
Old 01-23-2010, 04:32 PM   #220
redpillar
redpillar's Avatar
Oddometer: 877
Is that thing still on your bike?
Old 01-30-2010, 06:14 PM   #221
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
How tall of a bar can you put on the bike with stock cables and brake lines? The CR High bend seem to tighten everything up and they are not much over stock. The switchgear is all the way into the radius, so I can't really narrow them any either.
What is everyone doing to get taller bars on the '09s?
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 01-31-2010, 07:44 PM   #222
redpillar
redpillar's Avatar
Oddometer: 877
Not too much, there is NO slack in the cables or wiring harnesses.
Old 02-09-2010, 10:31 PM   #223
rallyman
Oddometer: 79
Originally Posted by punkenduro
i get a lot of people i see on trails that think its a dirt bike till they see a plate. blah blah blah, WAIT, THATS PLATED? yes, in fact is it .
Big tank on the 250 is the go!!!
rallyman is offline   Reply With Quote
Old 02-14-2010, 03:02 PM   #224
punkenduro
now in a cage...
punkenduro's Avatar
Oddometer: 738
if you go with a longer clutch cable, i got tusk atv bend bars and some big bar risers (like a half inch), works great for me.
the bike, the ride reports, and what ive riden this week:ymca, da cage?
“There is no flag large enough to cover the shame of killing innocent people.”
howard zinn
punkenduro is offline   Reply With Quote
Old 02-14-2010, 06:02 PM   #225
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Got any detailed pics of tht set-up?
My bad
Times are GMT -7.   It's 05:01 AM.
