04-20-2009, 11:00 PM
#61 | ||
Curmudgeonly
Oddometer: 8,935
Well, here's the most recent picture I have with my saw ready for some trail cleaning! You can see the pegs and radiator guards in the shot. The cig lighter is mounted to the crossbar of the handlebars using a pair of metal wire looms. I'll take a picture later and post it. It is wired direct to battery through a two wire flat SAE plug that hangs just under the speedometer. This way I can unplug the cig lighter and plug in a battery charger. I just installed a headlight "off" switch using a similar method (metal wire loom to the crossbar, SAE plug); I'll take a picture of that, too. Following a tip on the KLX forum I just ordered a set of 1" raising links to raise the suspension for a taller ride... kind of like hillbillies lift their pickups, I guess. Should be arriving in a day or so. As far as the 351 kit, I'm leaning towards that once I get my V Strom paid off. I think it will be paid off in a few months, and the big bore kit would make a nice winter project (for my mechanic!). ![]() If anyone is interested, here's a few KLX250S videos I put together on Youtube. The first is mostly of my buddy, on a WR450; but if you look closely I'm in there a bit! This one depicts my constant inability to stand up. Lazy, I guess. It bites me in the ass sometimes...
"A man turns his back on the comforts of home... to ride off alone, and when the dust all settles and the story is told, history is made by the side of the road" -DBT, Monument Valley MeefZah screwed with this post 04-20-2009 at 11:07 PM |
04-20-2009, 11:29 PM
#62 |
Oddometer: 67
Dude you gotta stand up and lean forward on a hill like that!! But I'm sure you figured that out pretty quick there!
"wind tunnel cat is watching you reduce drag...." |
04-21-2009, 05:26 AM
#63 | |
Curmudgeonly
Oddometer: 8,935
I know how to go up 'em, I just get lazy.
"A man turns his back on the comforts of home... to ride off alone, and when the dust all settles and the story is told, history is made by the side of the road" -DBT, Monument Valley |
04-21-2009, 06:15 AM
#64 |
Curmudgeonly
Oddometer: 8,935
mscardig and GB, I came home from work and took some pictures just for you guys, before going to bed.
The headlight off switch and cigarette lighter are installed to the crossbar using different sizes of this little guy, a metal wire loom ($5 / multi pack). ![]() The cig lighter is a regular automotive interior model from NAPA ($7), you have to buy one that has a removable chrome mounting bezel and which has both the positive and negative studs on the back of the element (some models look like this but have the negative stud on the mounting bezel). Pitch the bezel in the trash. Using a larger wire loom and the pictured smaller looom bolted together, you can secure the cig lighter to the crossbar. It is very sturdy and a strip of friction tape under it makes sure it doesn't rotate. It is waterproof with the included cap (not shown) on. ![]() The switch is a SPST 15A throw ($4), not waterproof; doesn't need to be. It will eventually go bad, but is cheap and easily available. The mounting plate is a piece of some scrap I had in my nuts and bolts drawer. I used a SAE connector because I made a "jumper" out of another SAE connector that I can plug in if the switch does go bad, so I still have use of my headlight. ![]() Buell blinkers ($15 ea), Enduro Engineering handguards ($50), Spiegler brake line ($70) ![]() Unabiker radiator guards ($100). These are very sturdy, but required a bit of cajoling to get installed. I ended up having to shim the clutch side with nylon washers to get enough clearance around the radiator to mount the guards. ![]() IMS footpegs ($50 used), very nice. I used to think wider footpegs couldn't possibly make a difference; how wrong I was. ![]() Generic (maybe Acerbis, it says "made in Italy", but nothing else) taillight and subfender ($15), Buell blinkers. I like the sideways plate. Very KTM.
04-21-2009, 06:23 AM
#65 | ||
Oddometer: 9
04-21-2009, 08:44 AM
#66 | |
Air cooled
Oddometer: 2,161
-Charles "This is an environment of welcoming, and you should just get the hell out of here" - Michael Scott |
04-21-2009, 10:25 AM
#67 | |
Mmm... mud!
Oddometer: 1,399
'07 Speed Triple 1050 | '08 WR250R "'Course, don't ever tell anybody that they're not free 'cause then they're gonna get real busy killin' and maimin' to prove to you that they are." -George Hanson |
04-21-2009, 10:44 AM
#68 | |
Oddometer: 9
Oh, found the part # for the vortex 1/4 turn throttle tube is #01-0054.
05-21-2009, 06:35 PM
#70 |
Oddometer: 768
Correct pressure for stock tires?
The owner's manual suggests 22 psi for the front and 22 - 25 psi for the rear. When I picked up the bike from the dealer, the pressure in both tires was between 35 and 40 psi -- probably too high.
What do you guys suggest for mostly street use?
A serious side effect of life is death. Ride while you can. |
05-21-2009, 06:37 PM
#71 |
Oddometer: 768
Comment on owner's manual
The owner's manual that came with my 2009 KLX250S is very thorough and well written. I'm sorry to say it puts the manual for my 2007 R1200GS to shame.
05-21-2009, 08:52 PM
#72 | |
Air cooled
Oddometer: 2,161
05-22-2009, 05:51 AM
#73 | |
Oddometer: 2,477
Love the 2nd video, classic
2011 DL650 2009 KLX250S |
05-22-2009, 07:51 AM
#74 |
Lanky, Cranky, and Stanky
Oddometer: 171
Wifey's new scoot
Now the Big Red Pig has a cute little sister...
![]() My wife's first bike and she is loving it. She'll rarely lets me ride it, and that's probably a good thing. It's so much lighter and easier to toss around than the KLR. It's way too much fun!!! I'm seriously considering getting another for me. Non-SM though... I gotta have my dirt.She already picked up the TurboCity rack and ProTaper bars. Looking for a larger tank alternative as fuel range is a problem. She may have farkle-itus worse than I ever did.
06-06-2009, 08:14 AM
#75 |
Oddometer: 768
A bitch to start...
I've got less than 100 miles on my 2009. Starting it in reasonably warm weather, it turns over and starts with the choke all the way out. After 30 - 60 seconds of warm up, fully choked, I push the choke in and it stalls out. It's really hard to start back up--choke or no choke.
Once I do get it started and am on the road for a little while, it runs fine in idle. Any thoughts or suggestions for easier start-ups?
