Old 11-05-2008, 02:12 PM   #1
mookymoo OP
Mookish Mook
Oddometer: 4,396
Everything you wanted to know about what you can and cant do with the std toolkit
Ive long been impressed with :
a) the quality of the std toolkit.
b) the attention to detail on the bike such that it requires so few tools
Everyone wants to travel light and compact (at least I strive to), so carrying as few tools as possible saves weight and space.
The std toolkit is my starting point. Having done a bunch of different work on my 950 Adv(s) now, in usually less-than-ideal conditions (ie outside my flat, by the side of the road ), I have built up a bit of a list of what you can and cant do with the standard toolkit - and what 'missing' tools you need to complete a given task. The idea being people can make an informed decision on what tools they might supplement their std toolkit with for that minimalist approach.
The point of this thread is not a "toolkit thread" (theres already a very good one of those).
The point of this thread is to detail what you can do with the standard toolkit - and what extra tool(s) you might need for certain tasks.
I will endevour to update this first post with the details as they come to hand (via my own experience or via feedback)
Assumed:
Obviously, all tanks, panels, ktm crashbars, ktm luggage racks & wheels can be removed with the standard toolkit.
Remove, service Carburettors
All this can be done with the standard toolkit.
Except for:
  • a 7mm spanner/socket required for the carb heater earth
  • a 3mm hex/allen key for the horn adapters and drains
I found the stock screwdriver to be a good fit for the jets.
You need to be careful with the phillips screwdriver though - the fit is ok, but not perfect.
Remove Forks
No additional tools needed
Remove Shock
Except for:
  • a 12mm hex/Allen key for the shock mounting bolts (950 toolkit owners). The 990 toolkit contains it.
All bets are off though, if you drop that bolt inside the swingarm.
Changing/Replacing Brake lines
This requires a 14mm spanner/socket for the banjo bolts
Also see Brake Bleeding
Brake Bleeding
This requires an 11mm open-ended spanner for the bleed nipple
Remove Triple Clamps
Except for:
  • a motocross boot as a soft hammer to encourage the top triple back on at the end
  • some kind of strap or rope to prevent the bottom triple and/or forks falling out when you take the top off. I wonder if the Aurel cable is long enough for this?
The steering stem nut requires the use of the largest of the large spanners - and the handle of one of the smallest of large spanners. Place the handle end-in to make the bolt-head larger so the larger fits tightly.
Replace Front Brake Pads
My technique might be shite here - but I am sure you need a fine pin-punch to get the pins out.
Remove Handlebars, guards and all hand controls
Remove/Change Drive Sprocket
All this can be done with the standard toolkit. BUT you might well need some instruments of persuasion (hammers & levers) if its stuck on.
You can loosen the nut if you keep the rear wheel & chain on - one of the tricks I learned of here (but not yet practised). If you place the large spanner on the nut with the stubby handle resting on the swingarm, then rotate the tyre to raise the handle and SLAM it back down. Effectively using the swingarm to hammer the spanner and loosen the nut. Dont forget the locking plate first ...
Rear Shock Compression/Rebound adjustment
The 950 toolkit is missing a 17mm socket for high-speed adjustment
The 990 toolkit has one!
Fork Preload Adjustmen
Can be done with the smaller of the large spanners - but only if you dont have bleed valves.
Side Stand Removal
Requires a 14mm Ring or open-ended spanner
Centre Stand Removal
Requires a 17mm socket/spanner.
Oil Change
A 19mm socket (or ring spanner) is needed for the sump plug. At a pinch, you can use the larger of the spanners in the toolkit, and the handle of the smaller spanner (much the same trick as the steering stem nut) - but you will be hard pressed to crack the seal with this combination.
Water Pump Seal Replacement
If youre just replacing the seal & shaft, and not the bearings, this can easily be done on the roadside.
Requires a 13mm socket for the exhaust header nuts.
Requires circlip pliers
Use the plastic handle of the T-handle to gently tap at the outer clutch cover to remove it without breaking the gasket.
Touratech Parts
... are a pain in the ass! They usually always introduce a new tool size requirement. That said, I think they boil down to:
GPS Bracket: 3mm Hex/Allen & 4mm Hex/Allen
High Fender Kit: Forget about it. All sorts of microscopic shite. But 4mm Hex/Allen is your main one.
And here is the std 950 Adventure Toolkit (everything within that red box)
And here is the std 990 Adventure Toolkit
AFAIK: The 990 toolkit is missing the spark plug wrench, but has a 17mm socket (for the shocks) and has a 14mm open-ended spanner
The 950 Toolkit contains:
Sockets: 6, 8, 10mm
Open-ended spanners: 8/10mm and 10/13mm
Ring Spanners: 24mm, 32mm
Hex/Allen: 5mm, 6mm (by way of T-handle), 8mm (for subframe bolts)
Phillips/Flat screwdriver
The 990 Toolkit contains:
Sockets: 6, 8, 10, 17mm
Open-ended spanners: 8/10mm, 10/14mm & ??
Hex/Allen: 5mm, 6mm (by way of T-handle), 8mm (for subframe bolts), 12mm for rear shock
Torqz: ??
Extra tools you might need:
3mm Hex / Allen key - for carb drains & carb horn adapters
4mm Hex / Allen key - to remove the seat lock so you can get all the panels off!
7mm open-ended spanner - for carb heater earth connection
11mm open-ended spanner - for brake bleed nipple
12mm Hex/Allen key (950 toolkit owners) - for Shock mounting bolts
13mm socket - for exhaust header nuts (required for access to water pump seal)
14mm open-ended or ring spanner (950 toolkit owners) - for brake banjo bolts, sidestand removal
17mm Socket/Ring spanner (950 toolkit owners) - for shock high speed adjustment, centre stand removal
19mm Socket/Ring spanner - for engine oil drain plug
mookymoo screwed with this post 01-02-2010 at 10:58 PM
mookymoo is offline   Reply With Quote
Old 11-05-2008, 04:39 PM   #2
pilesofmiles
Life is an Adventure
pilesofmiles's Avatar
Oddometer: 735
Awesome write up!
standing ovation! We need more posts like this....
"Life is no dress rehearsal"
pilesofmiles is offline   Reply With Quote
Old 11-05-2008, 04:56 PM   #3
MY ADV
"ZERO.. POINT.. ZERO"
MY ADV's Avatar
Oddometer: 496
950 tool kit extras
Great write-up Mookymoo:
So here are the extra tools needed to add to your standard 950 Kit:
Sockets:
1- Mini socket wrench.
1 - 7mm Socket
1 14mm Socket
Wrenches:
1 3mm Hex / Allen key.
1 - 7mm Spanner
1 11 mm Spanner
1 14mm Spanner
You can't make dirt clean, so well just lemon scent it. (Modest Mouse)
2012 KTM 990R ADV (20.0K Miles and growing)
2005.5 KTM 950A ADV (106K Miles to its death by way of truck)
2005 KTM 450 EX-G (Plate)
MY ADV is offline   Reply With Quote
Old 11-05-2008, 05:09 PM   #4
mookymoo OP
Mookish Mook
Oddometer: 4,396
Sockets:
1 - 7mm Socket
1 – 14mm Socket
Wrenches:
1 – 3mm Hex / Allen key.
1 - 7mm Spanner
1 – 11 mm Spanner
1 – 14mm Spanner
Might be useful to list them like this too - with their corresponding uses.
Old 11-05-2008, 05:31 PM   #5
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Nice post. PM a mod and they'll change the title for you.
jamesbrown is offline   Reply With Quote
Old 11-05-2008, 05:45 PM   #6
Dru
Hardly an Adventurer
Dru's Avatar
Oddometer: 569
Hey Mookymoo!
Here's the 990 toolkit... a few more gizmos. Two 14mm ends on separate box wrenches?
Dru is offline   Reply With Quote
Old 11-05-2008, 05:45 PM   #7
mookymoo OP
Mookish Mook
Oddometer: 4,396
Done.
Old 11-05-2008, 06:30 PM   #8
mookymoo OP
Mookish Mook
Oddometer: 4,396
Ta.
Added
What are the open-ender sizes?
8-10
10-14
12-14
mookymoo screwed with this post 11-05-2008 at 06:39 PM
Old 11-05-2008, 07:19 PM   #9
hilslamer
2XRedheadedstepchild
hilslamer's Avatar
Oddometer: 1,786
Amen. Will post more when I'm keyboard-enabled.(No bluetooth keyboard for the BlackBerry yet...)
hilslamer is offline   Reply With Quote
Old 11-05-2008, 07:30 PM   #10
Rabid Dog
Rabid Dog's Avatar
Oddometer: 354
How about open a bottle of beer? Should be number one on the list.
Rabid
2007 KTM 990 Adventure (Black)
Rabid Dog is offline   Reply With Quote
Old 11-05-2008, 07:36 PM   #11
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Thumb
Definitely the most useful/used tool in my kit.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 11-05-2008, 07:42 PM   #12
Krust
Krust's Avatar
Oddometer: 63
Don't forget the jumper cables!
2007 990 Adventure
2008 YZ250F
2003 YZ250
1999 WR400
Krust is offline   Reply With Quote
Old 11-05-2008, 11:11 PM   #13
w72315
woody
w72315's Avatar
Oddometer: 113
Quote "Ive long been impressed with :
b) the attention to detail on the bike such that it requires so few tools"
I'm not quite so sure about the quality. My extension for the sockets snapped the 2nd time I used it. Wasn't really over-doing it when it snapped.
The plug socket I have has split and the allen keys a pretty soft!
The quantity of bits I find impressive (compared to a few other brands of bikes I've owned. (read this Mr Kawasaki!!))
I've already gone out and replaced most of the kit with proper forged items that won't snap, break or bend when I need them most. I certainly wouldn't want to cross some the deserts in my back-yard with the standard kit.
w72315 is offline   Reply With Quote
Old 11-06-2008, 01:19 AM   #14
HappyGoLucky
Goeie Grys Giftige Gert!
HappyGoLucky's Avatar
Oddometer: 4,311
You must be really rough on your toolkit, or else every second piece is a dud, which just cant be.
I have stripped bolts with the standard tool kit, and used it intensively for 3 years now, with nary a problem. Even bolts that were rusted shut (exhaust clamp bolts) were removed with the standard tool kit. Flexed, and held. Fantastic!
Be true....to yourself
HappyGoLucky is offline   Reply With Quote
Old 11-06-2008, 05:21 AM   #15
Dru
Dru's Avatar
Oddometer: 569
Originally Posted by mookymoo
Ta.
Added
8-10
10-14
12-14
I'll get back to you on that. I'm at work today... can't always be playing right!
Times are GMT -7.   It's 02:21 AM.
