Old 04-15-2009, 04:06 PM   #61
GB
Mod Squad
GB's Avatar
Oddometer: 55,994
Originally Posted by rickypanecatyl
I stumbled on a '99 KLX 300 for $1,200. Since I want to replace the carb and pipe as well I just feel better doing it on an older one - thus the question of can you put the 351 kit on the 300.
My guess is yes, because people were using the piston and cylinder from the KLX300 in the KLX250 to bump up the displacement. Keep in mind the KLX300 is a kickstart, no e-start.
In a previous post, Bake said this:
Originally Posted by Bake
On the older 300, I'm not sure about that particular fitment. I'll be in the shop tonite, and I'll check with Bill on that. I'm going to guess if the 300 engine was unchanged through it's production run, it would fit, as the KLX250 and 300 are the same engine in many ways.
Old 04-15-2009, 10:06 PM   #62
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
Originally Posted by Gadget Boy
What's this about a bigger tank? PICS???
ooops
Bake is offline   Reply With Quote
Old 04-18-2009, 03:20 PM   #63
GB
Mod Squad
GB's Avatar
Oddometer: 55,994
Old 04-24-2009, 02:29 PM   #64
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
Tank #2 welded up. Time to start making mounts.
One more clue: 1.1 gal.
Old 04-24-2009, 07:53 PM   #65
GB
Mod Squad
GB's Avatar
Oddometer: 55,994
PICS!!!
Old 04-25-2009, 12:39 PM   #66
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
PICS!!!
It's Bill's gig, and the B and B policy is, nothing is shown for sale until it is tested by us, and ready to ship. He's ok with hints, though.
Hint #3
It does NOT mount to the luggage rack.
Old 04-25-2009, 11:45 PM   #67
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,106
Bake - could I get a confirmation on whether or not the 351 cc kit would fit on a '99 KLX300? Thanks
rickypanecatyl is offline   Reply With Quote
Old 04-26-2009, 04:36 AM   #68
GB
Mod Squad
GB's Avatar
Oddometer: 55,994
Hint #3
How about you show us some spy pics!! We surely understand that if testing proves it's a dud, you at least get kudos for trying. Alright, we'll be patient..
Old 04-28-2009, 01:28 PM   #69
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
Bill's 6'2", and I ain't by a long shot.
Ok, maybe.
A quick mention again about baseline jetting on the KLX351 kit. IF you're using the STOCK CARB AND PIPE, you still must re-jet!
DON"T run stock jetting! This engine loves fuel.
Here's where my bike is at, 1100 feet ASL. If you live in Leadville, at 10,000 ft. ASL, maybe stock jetting will work...
I use the KDX200 airbox snorkle, free carb mods, and the pipe mod.
Baseline:
#40 Pilot
Dyno Jet needle for the stock carb, full lean (bottom notch)
#132.5 Main Jet
Airscrew 1 turn
I do think the full lean on the needle indicates there's something else that should be better, but I've tried a dozen combinations, keeping a log of the changes, and this is the set-up my bike likes the most. Especially the pilot and main. Anything else, and it just doesn't run close to right.
If it starts ok on the enrichening knob, but with one blip can go off it at 10 seconds and idle good, the pilot is correct. You're way lean if it needs one minute warm-up or more before it will idle. Ride it, if it bogs, it's rich. If it surges at steady midrange and up, it's lean on the main.
Ride it, and then check your plug after a 6000 rpm pass and a throttle chop. Get stopped and turn it off as quick as you can. The plug you want is tan, not white. Dark plug means you're rich. Black shiny plug means you are way rich.
Good luck!
Bake screwed with this post 05-18-2009 at 09:41 AM
Old 04-29-2009, 07:05 PM   #70
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
I cannot answer that as a yes or no, I'm sorry. It is marketed for the '06, '07, and '09 carburetor version of the KLX250S.
Bake screwed with this post 04-29-2009 at 07:17 PM
Old 04-29-2009, 07:17 PM   #71
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
Spy Photos, Pat.Pend.
We are developing this auxiliary fuel tank for the KLX250/351. As you can see, it is not yet completed
but we see no major issues. A few weeks at most before we can test ride with 3 of them.
I anticipate more in this line of products. Many things are in development.
All intellectual property is reserved.
Bake screwed with this post 04-29-2009 at 07:29 PM
Old 04-29-2009, 07:28 PM   #72
GB
Mod Squad
GB's Avatar
Oddometer: 55,994
so this will replace the battery cover? How much does it hold? Let's see it mounted and tested.. what's the hold up? It's spring, ain't it?
Old 05-16-2009, 10:56 PM   #73
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
The first tank is mounted and is being ridden. Pics to follow.
Tanks 1 and 2 will be tested on the trails of Colorado the Memorial Day weekend.
Tank 2 and 3 will be tested in Colorado the week of June the 7th.
The tank capacity is 1.1 gallon. This gives 1/3 more range. The stock tank and our tank will be 3 gallons total.
The battery and battery retainer remain stock.
We are very impressed at how strong the mounting system is. The fit is very nice. Provided our test trips go well, this tank can be a production item.
edit: Tank #1 held 1.13 gallons.
Bake screwed with this post 05-18-2009 at 10:57 AM
Old 05-18-2009, 09:06 AM   #74
Big Single
Tejas
Big Single's Avatar
Oddometer: 1,805
I'm always looking for a lighter dual sport. With the 350 kit, what sort of highway cruising speed can you maintain without damage to the motor? Is the general rule 2/3 of max rpms?
Big Single is offline   Reply With Quote
Old 05-18-2009, 09:39 AM   #75
Bake
adventurer
Bake's Avatar
Oddometer: 10,518
I cruise at the torque peak, generally, which on this 351 engine is 6000-7000, so that's about right. The "redline" is 10,000. This big bore engine makes all the power it's going to make at a much lower RPM, at about 8000, you're just making more revolutions. However, it makes close to maximum torque as low as 3500, so it is more of a "tractor" motor than a peak RPM motor. I'm going to gear up a tooth to 15 at the countershaft, because the 351 will pull it at highway speeds. The 250 is just weak, and can't really use the tall 6th gear, in my opinion.
Times are GMT -7.   It's 03:59 AM.
