Old 04-28-2004, 04:42 PM   #1
freded OP
Wastrel
freded's Avatar
Oddometer: 174
Need your opinion on this piston
I am in the process of rebuilding a KRS. Bought an engine and it wasn't exactly what was represented so took it completely apart and am rebuilding it. This piston was either dropped or something was dropped on it. So question is it good enough to be used or should I buy a new one?
freded is offline   Reply With Quote
Old 04-28-2004, 05:07 PM   #2
Guzz
Gutless wonder
Guzz's Avatar
Oddometer: 4,924
Just follow the basic rule in life when cooking, wrench'n, etc...
"When in doubt... Thow it out"
Unless you're a cheap bastard and then you come here to ask questions
Change must come from a barrel of a gun. -- Mao Tse Tung
When governments fear the people, there is liberty. When the people fear the government, there is tyranny -- Thomas Jefferson
Guzz is offline   Reply With Quote
Old 04-29-2004, 06:12 AM   #3
RikuY
Stuck in the Sandbox
RikuY's Avatar
Oddometer: 736
The nick seems to be below the sealing/oil rings so you should be okay. I wouldn't use it because I am one anal bast---. The little bit of vibration or unbalance would have me regretting the damn piston as soon as I felt something and would crack it open again to rip it out.
So I would get a new one, but only because I only do the same job once!
RikuY
Beer will not solve all of your problems, but neither will milk.
RikuY is offline   Reply With Quote
Old 04-29-2004, 06:17 AM   #4
duc
duc's Avatar
Oddometer: 802
The nick in the body looks acceptanble to me, as long as you remove any sharp edges.
From my screen though, it looks like there is a nick on the upper surface of the top ring groove. If it is in fact a nick, I would reject this piston.
duc is offline   Reply With Quote
Old 04-29-2004, 09:10 AM   #5
kevbo
Rubbery-Lip Flappin' PHI
kevbo's Avatar
Oddometer: 1,478
If it appears to be a ding from handling I'd use it. Make sure there is no raised area around the ding. (like the rim of a crater) Might need a little work with a riffler and some paper to take that off. Only the lower part of the skirt runs on the bore, some fancy pistons have even eliminated the area where your ding is located.
If, on the other hand, it appears to be a void from a casting, I'd be more wary.
When pistons fail, it is usually at the crown, or the ring grooves. Only if they were porly fitted, or EXTRAMLY worn will you ever see a skirt failure.
Sincerity is the most important thing. Once you learn to fake that, the rest is easy.
kevbo is offline   Reply With Quote
Times are GMT -7.   It's 10:49 PM.
