Old 05-18-2009, 09:42 AM   #76
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Originally Posted by CMB123
Am seriously thinking of new side panels and rear fender...I really quite like the look of the SMR570 side panels and rear fender anyone know if they fit the TE610E subframe (they look pretty close)
Thanks in advance, it seems Husky advice is quite rare so I appreciate any help.CheersCMB123
Congrats on the bike!
Sorry can't help on the pannels.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 05-18-2009, 07:14 PM   #77
Trang
... 2nd last to the Sweep
Trang's Avatar
Oddometer: 1,093
Probably kind of, but not quite.
The 570 was the halfway model between the earlier model 610 series, and the current models.
The biggest problem you will have is fitting over the airbox on the right hand side. The angle is different and in a different location.
This is mostly to do with the location of the battery.
The 570 had no battery, whilst the 610-e had it beside the airfilter.
The 570 plastics are more similar to that of the current model 610's.
The reason why this works on the current model 610's is because the battery location is behind the rear shock, near the guard.
Probably the shopping list to acheive this would be:
- replace exhaust from 2 outs, to a single.
- relocate the battery to behind the rear shock
- replace airbox - from 2000 era, or 06 on era 610. (late 90's 610 may work also ??)
(Finding a rear subframe from an 06 onwards 610 would make this a lot easier)
... i think then you will be ok.
Dont replace the seat though, it is different at the front to suit the differnent tank.
Hope this helps,
David
"I still haven't worked out why all these people are here, but all I can think is there's a small amount of craziness left in an increasingly sanitised world and they want to be part of it"
Russ Malkin 2006
Trang is offline   Reply With Quote
Old 05-30-2009, 05:15 PM   #78
sTE610vE
sTE610vE's Avatar
Oddometer: 2,067
Just happened to find this thread, I have been the happy owner of a 2003 TE610E since October of 03. I Glad to see a thread just for this era of the 610!
I am interested in some info on the timing chain, expected life and how to go about checking it. The newer TE610 has a lot of info on this but the tensioner is different than ours. Anybody got some advice on the TE610E timing chain?
Here's a pic of mine, complete with the large tank from Aus now in the real OZ (Kansas)
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com
Husqvarna TE630
Cagiva Gran Canyon
sTE610vE is offline   Reply With Quote
Old 07-05-2009, 09:02 AM   #79
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Anybody a filter screen/bag expert?
Originally Posted by huskyte610e
You will also find a lot of inconsistance with bike specs during this time. Man, I'll second that.
Some things that seems to vary include Forks, Graphics etc. oil type, valve adj. clearence to name a few.
I've spoken with husky dealers, and even they dissagree on what model is what.
I have what is titled as a 2000 model. Photo below. During recent oil change and my first filter screen cleaning I could not locate the right side filter screen. The left side is of course a no brainer. I pulled the RH case off.
Surely you dont need to pull the clutch to get to the right side filter screen? And I dont see the screen under the clutch anyway. Do some have the RH screen and some don't? Thanks in advance for any help.
Regards
Fritzcoinc
Old 07-05-2009, 09:15 AM   #80
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Glad this thread is still ALIVE!
Nice bike. I can tell you that as regards the cam chain there is a WORLD of controversy on the subject. Some claim life, as measured by the adjuster position, as short as 2800 miles while others are at 15K and with half to two thirds adjustment used. Some swear by pitching the auto adjuster in place of a manual adjuster. And then there is the oil variable. ( did I say oil, I am sorry ) All I am trying to tell you here is do alot of research. And as is typical, service manual instructions are vauge and the type of adjuster used varies. Photo of the one from my 2000 mod. below. It is fully extended in photo. You remove the screw and retract to install. Then gently release.
Regards
Fritzcoinc
Old 07-08-2009, 05:26 AM   #81
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Thanks to Jellyrug on TT here's the answer. It's a little deal. I looked wright over it:
Regards
Fritzcoinc
Old 09-17-2009, 07:50 PM   #82
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,607
Bump, just picked one up tonight.
B.E. Coyote is offline   Reply With Quote
Old 10-29-2009, 03:40 PM   #83
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Carb. boot to air claener box clamp
Anybody know where to get a stainless steel clamp to hold the carb. boot on to the air cleaner box? The factory one is aluminum and has stripped out. I was able to make a temp. fix by covering the calmp with heat shrink tubing but would like a new, mo better, clamp.
This clamp has a maximum opening of 5 1/2" diameter and a band width of 5/16"
Regards
Fritzcoinc
Old 10-29-2009, 05:43 PM   #84
supergper
Oddometer: 137
Woohoo, glad this thread exits. I'm surprised I haven't found it sooner with all the searching I've been doing. I recently picked up a 2003 TE610e, I got it with only 600KMs on it (~375 miles). This was truly a garage queen Anyways, I've been desperately looking for one of these mythical 17 liter tanks. If anyone find anything, please let me know. I've sent an email to UpTite but haven't heard back yet. I love the bike so far and this thread has been great.
Fritz, for a SS clamp you should be able to check most boat supply places. I know when I was a commercial fisherman, we used SS clamps on everything and 5"+ was not uncommon. If you can't find one, shoot me a PM and I'll pick one up for ya.
supergper screwed with this post 05-25-2010 at 08:10 PM
supergper is offline   Reply With Quote
Old 10-30-2009, 05:57 AM   #85
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Originally Posted by supergper
Woohoo, glad this thread exits. I'm surprised I haven't found it sooner with all the searching I've been doing. I recently picked up a 2003 TE610e, I got it for a steal with only 600KMs on it (~375 miles). This was truly a garage queen Anyways, I've been desperately looking for one of these mythical 17 liter tanks. If anyone find anything, please let me know. I've sent an email to UpTite but haven't heard back yet. I love the bike so far and this thread has been great. It feels good that there are others out there with the exact same issues (aftermarket support ) as me!
Congrats on the bike! But your post is worthless without pics!
Good idea on the clamp, I go wright past US Boats every day.
Regards
Fritzcoinc
Old 10-30-2009, 06:48 AM   #86
supergper
Oddometer: 137
Fair enough.
These pics were from my first ride. It was up a canyon right near my house.
Old 10-30-2009, 08:06 AM   #87
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
Canyon by your house. You lucky shit. Heres the typical teraine by my house:
Regards
Fritzcoinc
Old 11-03-2009, 05:36 PM   #88
ducky950
Gnarly Water Fowl
ducky950's Avatar
Oddometer: 1,642
Updated body work
Been following the thread. Bought a 2000 TE610E this evening.....It is in desperate need of new plastic! Has anyone tried upgrading to the new plastics with any success? I did see there was talk of it, but did anyone actually try it out? If so post a pic or 2!
Nutin like a $30,000 pile up!
ducky950 is offline   Reply With Quote
Old 11-04-2009, 06:14 AM   #89
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,276
EBay for stock used and NOS. Or you could find a graphic dude to make some custom design to cover up the old plastic.
Regards
Fritzcoinc
Old 11-04-2009, 06:29 AM   #90
supergper
Oddometer: 137
New plastics aren't too expensive from the dealer. About $25 for each tank side and $50 for the front fender. You will have to purchase decals separately, but that will get you brand new stuff.
Times are GMT -7.   It's 03:20 AM.
