05-10-2010, 06:31 PM
#61 | |
Oddometer: 161
Thanks - I actually took care of that already - got the 50
05-10-2010, 09:26 PM
#62 | |
Almost Lifelike
Oddometer: 1,151
The fuel screw should be between 1 and 3 turns out. Any more or less and means you've got the wrong pilot jet. You are doing this with the pump disconnected right? Also, you said the carb came off a Harley, are you sure it's not an HSR42 or 45? I'm really surprised that the #20 pilot was too lean. I've done quite a few of these and always had the #20 or a #17.5 work.
XR650R Plated Supermoto XR628R Plated and highly modified CR500R Still rips after all these beers RZ350L Kenny Roberts Special "If it's hard to do, you're probably doing it wrong." |
05-10-2010, 10:23 PM
#63 |
I see dumb people!
Oddometer: 1,129
Actually Vrider the company sets them at 3.5 turns out and recommends this,not normal i know but it's their show.
These things can run a big main and a small pilot,hear me out dude. Say normally a 20 pilot and a 135 main a 140 main will run a smaller pilot say 17.5.For real not making this up. You don't have to believe me,but it's true. Also with this carb when you do a main plug chop ya gotta stay flat for a bit longer than other carbs for some reason,till it clears out. Weird but true dudes..
The mighty XR650R. The old trail bike that all modern trail bikes are judged by. It's funny cause it's true!. |
05-11-2010, 02:39 AM
#64 |
Almost Lifelike
Oddometer: 1,151
Running a smaller pilot with a bigger main makes perfect sence, I was just surprised that with a 140 main the 20 was too lean. About the fuel screw my information is different. I have the Mikuni Tunning Manual 4th edition and the section on tuning the TM40 says the fuel screw should be 1 to 3 turns out, less than 1 or more than 3 means you have the wrong pilot jet. However, I realize that these are just guide lines and not carved in stone. My hard and fast rule when it comes to tuning carbs is "what ever works".
05-11-2010, 05:17 AM
#65 |
Oddometer: 161
Appreciate the input guys.
Xrider, I have the vacuum spigot on the side capped with a new tight cap. TM40 - no doubt about that. I connected the accel pump up to aim it at the needle last night and it is still connected. Of course it doesn't come into play at closed throttle and that is where my problem is.
I'm wondering about the condition of this used "Harley" carb... Maybe the slide is too worn and causing me problems at idle? I guess I'll try the smaller pilot air jet or pilot jet tonight after work. There is no way I'll let it run this lean at idle. It WILL run - but it's not happy. V-rider screwed with this post 05-11-2010 at 07:04 AM |
05-11-2010, 05:37 AM
#66 |
Torque Junkie
Oddometer: 3,565
V-rider - the 1.2 pilot air jet should be right on the money unless you got some other mods, what does your airfilter look like (condition-wise)? What type filter are you running? I stick with stock filters (they're good), mine will pull enough of the airfilter oil out of it after a couple days of riding so it will get a little lean. I'm running a #20 at 5500' and it could probably stand to go a touch leaner but the fuel mixture screw is 2.5 turns out. Slight popping on decel and no popping back through the carb at idle which it did with too lean of a pilot jet.
05-11-2010, 08:02 AM
#67 |
Oddometer: 161
Yes, I guess I should share a little more info to help figure this out.
My bike has the "un-corked" intake manifold boot, K&N filter, plug out of the airbox, and two small triangles cut out of the cover with screen covering them. The exhaust is stock except for the insert - which I only "half" cut out to keep my neighbors happy. The bike probably doesn't even have 500mi on it yet so it is basically new.
Here is the carb rundown: TM40 N100.604 #140 Main Jet 9DJY01 Jet Needle 568 Y-4 Needle Jet VM28/486 #22.5 Pilot Jet BS30/97 1.2 Air Jet TM36/43-0.3 Accel pump nozzle (Sudco told me this was about the same as a #50 - it was the only one they had for the TM40) I "glued" the intake and airbox adapters on with hardening brown silicone stuff and put a little set screw in each to make sure they didn't come loose, rotate, etc. I would be very surprised if I had a vacuum leak thru the intake adapter. (I did spray that also while it was idling and there was no change.) And I also put a rebuild kit in it so I have all new soft parts. I was disappointed about two things in the rebuild kit. One was the fit of the top cover gasket. I had to hold it in place to keep it straight while I tightened the screws because the little hole for the A/P stop screw was punched wrong. I wonder if the top cover isn't sealing well? Could I get a little extra air thru there if my slide is too worn? However, I did spray all around it while it was idling and nothing changed. The other thing was no tiny o-ring for the idle mixture screw - dang! I had to squeeze a replacement that was a little too fat up in there. Hopefully that isn't causing me a problem. Maybe I better check the pilot circuit again - maybe some crap broke loose and is plugging it up... |
05-11-2010, 12:47 PM
#68 |
Almost Lifelike
Oddometer: 1,151
Having a slightly too large o-ring on the fuel screw shouldn't be a problem so long as it's tight around the screw. But I wouldn't make any assumptions until you pull the plug and see how she's burning.
05-11-2010, 02:52 PM
#69 | |
Oddometer: 1,435
V Rider,
How did the 0.3 pump nozzle work out for you? I've always wanted a smaller nozzle and Sudco told me the 0.5 was the smallest available. Was the 0.3 a special order? Quote:
05-11-2010, 03:40 PM
#70 | |
Oddometer: 161
Haven't been able to ride it more than a minute yet.
I don't think it was special order... This is what is listed in their latest price sheet: 007.165 TM36/43-0.3 NOZ 5.51 I e-mailed Sudco and asked them about it (almost ordered the nozzle for the HSR42). Chad at Sudco said this is the one you want. |
05-11-2010, 05:52 PM
#71 |
Oddometer: 161
Ok - I think I'm getting closer
The rain stopped for a minute so I went for a spin down the street after I put in the 25 pilot jet. Idles better now. I think it still could use more fuel so I will put in my 1.1 air jet some time and see how it runs. It is cold today so I need to run on a warmer day and see how good the idle gets.
I experienced the "pumper" effect - she just needed a extra squirt and the front wheel pops right up - even with my 15 tooth front sprocket. Woo hoo! ![]() After I ride it more I will post again with more results. |
05-12-2010, 04:48 AM
#72 |
Oddometer: 1,435
V Rider,
Thanks for the part number
05-12-2010, 05:56 AM
#73 | |
Oddometer: 423
Just trying to keep the rubber side down |
05-12-2010, 05:43 PM
#74 |
I see dumb people!
Oddometer: 1,129
The joys of a pumper carb.
05-13-2010, 06:30 AM
#75 |
Oddometer: 161
Vacuum leak - I finally found it.
So I figured out why my idle was so lean - the intake adapter was leaking. I had to strategically spray one little spot until - vroomm - idled up smooth.
I thought that my permatex glue job (even heating it for a few hours in an oven until it was hard) would have been good. No luck. So I did the J-B weld thing. Should be good now. I wonder what everyone else uses to seal those adapters with? I hoping for a smooth idle now. |
