Thread Tools Rating: Thread Rating: 36 votes, 4.39 average. Display Modes
Old 12-13-2011, 07:37 AM   #22486
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 1,648
Originally Posted by HardCase View Post
And I'd also point out that there is absolutely no interrelationship between a tight upper and lower and accuracy on an AR. None.
Well, there is some. If the upper and lower aren't consistently aligned, since your cheekweld is on the lower and your sight picture is through the upper, accuracy can suffer. Which is why Service Rifle shooters use Accuwedges, the JP threaded takedown pins, or something to hold the two halves in consistent alignment.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 12-13-2011, 09:17 AM   #22487
The_Commander
The Man.
The_Commander's Avatar
Oddometer: 5,417
Originally Posted by Redne Dab View Post
Thanks everyone for your thoughts. I hadn't thought of just changing the upper receiver or the potential benefit of having a pre-ban.
I'll post pics when I decide.
The benefits of having a "pre-ban" rifle went out the window in September of 2004, unless you live in one of those God forsaken areas that still denies their citizens the option of being free.
Keep your Bushy, anything you might replace it with is most likely from the same exact forge. If you want a flat-top then scoot over to Core 15 and pick up one of theirs for low dough.
The_Commander is offline   Reply With Quote
Old 12-13-2011, 10:10 AM   #22488
HardCase
winter is coming
HardCase's Avatar
Oddometer: 9,153
1911fan
Okay, I see your point, but as a practical matter the amount of play between a fairly loose upper/lower as it might remotely affect cheek-weld would be about 1/4 of a millimeter! I think that guys use Accuwedges and JP takedown pins to make themselves feel better, if the gun feels solid rather than rattles a little it makes them think it might shoot better. I don't believe those things make a whit of difference, except that they make money for Accuwedge and John Paul.
Having said that, I have a JP takedown pin on one of my ARs!
Μολών λαβέ
Hard cases make bad law.
HardCase is offline   Reply With Quote
Old 12-13-2011, 10:33 AM   #22489
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 4,083
This goofy question might fit in this thread...
In '93 or so a friend talked me into buying a Bushmaster AR15 kit and assembling it. It was a great, no frills rifle.
Flash forward (feeling kind of old here) eighteen years. After a long family-related hiatus from guns, I have dived back into it... My no frills carbine (It has a carry handle. How embarassing is that?) with a 1/9 barrel is like a Model T! Plus the once renowned Bushmaster name has become known for garbage /budget guns.
Here are some options I would appreciate input on:
1. Sell it (I think a pre-ban is worth around six or seven hundred) and buy a Spikes or PSA 14 inch with a pinned flashhider, flat top and mid length gas system.
2. Just get a new upper like what I described above and live with a mismatched rifle. Bushmaster and.,.
3. Forget the new stuff and enjoy my classic rifle. The new ones will always be available.
Thanks for your input. I can't promise I'll follow it but I hope to find something insightful.
Redne
Is there anything wrong with it? If not then I'd keep it. A carry handle upper isn't really an issue and are coming back.. If you don't like the A2 stock you can replace it. The only other thing is the lack of a muzzle device. You'd have to get the barrel threaded or replaced if you wanted one. Otherwise, just leave it. You can always buy an additional complete upper or just a barrel and upper receiver, if you want to invest in all the tools. I'd consider buying a complete upper though. http://palmettostatearmory.com/ does have some good deals. But I'd check LMT and BCM as well.
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson
Jeffy is offline   Reply With Quote
Old 12-13-2011, 10:43 AM   #22490
doc_ricketts
Thumper jockey
doc_ricketts's Avatar
Oddometer: 4,021
By the way, I caught the newest episode of 'American Guns' last night (after visiting their shop last week). The part about building a Yellow Boy was pretty interesting but the bimbos shooting with the local firemen was really dumb. I guess I have to visit the shop again and give the guys some advice on how to make the show better for an intellectual audience like us guys.
"Get yourself to the hills and be uplifted, assuming you got some good knobbies"
doc_ricketts is offline   Reply With Quote
Old 12-13-2011, 10:50 AM   #22491
gofast1320
gofast1320's Avatar
Oddometer: 489
Hear Hear! 99.9% of most accuracy problems or inaccuracy from a gun are caused by that loose nut on the stock. A good solid position, good sight picture and trigger squeeze are worth 3 clicks of windage any day.
gofast1320 is offline   Reply With Quote
Old 12-13-2011, 11:02 AM   #22492
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 4,740
Where's a good place for AR parts? I need a pivot pin spring.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker screwed with this post 12-13-2011 at 11:14 AM
RedRocker is online now   Reply With Quote
Old 12-13-2011, 11:12 AM   #22493
McNeal
Oddometer: 1,378
Originally Posted by RedRocker View Post
Where's a good place for AR parts? I need the little spring gizmo that holds the pin in place allowing the upper to separate from the lower.
I like MidwayUSA and have ordered some really small AR parts from them.
McNeal is offline   Reply With Quote
Old 12-13-2011, 11:25 AM   #22494
El Guero
V4 Whore
El Guero's Avatar
Oddometer: 9,549
Send a message via Skype™ to El Guero
Been reading a little bit about the .327 Fed Magnum this morning and I think I might want one. Anybody have one? I am hoping they release the SP101 with the 4" barrel in .327, might be perfect for my wife and not so expensive to reload for either.
El Guero is online now   Reply With Quote
Old 12-13-2011, 11:28 AM   #22495
Uncle Pollo
Von Hochstaden's son
Uncle Pollo's Avatar
Oddometer: 44,977
Next is bobbing the frame, Kev!
mikuni vm32-33 both sides :\ 5000 feet altitude/
140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide
35 mpg around town riding like a asno
Uncle Pollo is offline   Reply With Quote
Old 12-13-2011, 11:34 AM   #22496
The_Commander
The Man.
Oddometer: 5,417
In addition to Midway, Brownells carries just about everything you could ever need or want. It's where most professional gunsmiths get theirs.
Old 12-13-2011, 11:37 AM   #22497
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 574
I agree. There's nothing wrong with old Bushmaster. And I'd also point out that there is absolutely no interrelationship between a tight upper and lower and accuracy on an AR. None. It can be so loose a goose could fly through there and still shoot if the trigger is decent. Only thing that needs to be done to make an accurate AR is float a good barrel and have a decent trigger, period, end-of-story. All else is window-dressing.
It is pretty annoying to have a loose upper lower fit. Your cheek weld is on the stock, which is attached to the lower, and your sights are on the upper, if its loose your sight picture can cange a bit, not huge, but it annoys me. Some might not find it a problem.
Definitely somthing that can be fixed if it is bothersome
Ryan
XOVERLAND.COM Our vendor thread HERE
Season 1 Done!! HERE 6 Full Episodes Free on our website!!!
If you like it, "Like" us on FaceBook
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 12-13-2011, 11:47 AM   #22498
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 4,740
Thanks guys, I found them on Brownell's site, is there a little piece
that goes in the end of the spring that fits in the slot on the takedown
pin? OK, never mind, watched the video and figgered it out.
N. Texas
RedRocker screwed with this post 12-13-2011 at 11:58 AM
Old 12-13-2011, 11:54 AM   #22499
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 574
pin?
Yep, I believe its a little brass pin.
Ryan
Found one..
http://www.brownells.com/.aspx/pid=1...ke-Down-Detent
Old 12-13-2011, 11:59 AM   #22500
Jeffy
Hmm...
Jeffy's Avatar
Oddometer: 4,083
pin?
It's called detent. It's those two shiny pins at the upper left. They tend to go shooting off if you're not careful.
Thread Tools
Times are GMT -7.   It's 09:13 AM.
