10-08-2012, 08:45 AM
#27031 | |
"Whitebread"
Oddometer: 9,327
![]() I love it! |
10-08-2012, 10:09 AM
#27032 |
winter is coming
Oddometer: 9,153
The 66-2 was made between 1982 and 1985. S&W went to frame-mounted/floating firing pins circa 1998. So in that respect it is a thing of the past.
Μολών λαβέ Hard cases make bad law. |
10-08-2012, 10:17 AM
#27033 |
1.5 Finger Discount
Oddometer: 20,073
Ah...
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
10-08-2012, 10:43 AM
#27034 |
Oddometer: 2,515
finding out all sorts of history of S&W 66-2 .. first of the crush fit barrels. so no more pinned barrel and recessed cylinder.
K frame revolvers have a milled flat at 6 oclock on forcing cone. 19 series had problems with forcing cones splitting when shot with under 125gr .357. No documented cases of any stainless forcing cones on 66 series split. Stainless is harder to machine and tougher. early 66 had a reputation of being let out of S&W too tight. my 66-2 had less than 100rds shot and was only used to qualify by a reserve Deputy Sheriff. first trip to gun range, after about 100rds... 66-2 cylinder jammed tight.... bummer, would not go back into frame. sat 66-2 down to let cool down, but it didn't make any difference. hence why picture of 66-2 torn completely down. problem ended up being powder traces under ejector plate. cleaned area and 66-2 went back to normal. side to side was almost zero to .01in. tolerances was so tight, least little bit of trash under ejector place would lock up 66-2. after doing a trigger job to smooth out double action. loaded up 200rds and headed for the range. after 12 rounds... 66-2 locked up again ... bummer... cleaned under ejector, back to normal. did this for the next 100 rds. 66-2 slowly improved. shot another 100 rounds... things improved to where ejector plate didn't need cleaning between loads. after 200rds of hammering. side to side improved to .02in. cylinder quite jamming. problem of too tight solved. stoning all internal parts that rubs against metal ![]() ![]() ![]()
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
10-08-2012, 12:36 PM
#27035 |
Exorbitant Tax Payer
Location: People's Republic of the United States of America
Oddometer: 7,194
Really? I saw them on Amazon.com but I am not familiar with them. They seen to wrap all around and form the backstrap. Do they interfere with the beaver tail?
"We blew it." -- Wyatt in Easy Rider My Riding Blog My Travel Blog Kurt Nugent Photography My Adventure Page |
10-08-2012, 12:55 PM
#27036 | |
Oddometer: 1,222
My K-Frames one a K22 and the 66-2 ![]() ![]() New Hogue grips
10-08-2012, 01:25 PM
#27037 |
Rectum Non Bustibus
Oddometer: 3,514
I have a K-22 Outdoorsman of 1933 vintage, and a pre-Model 18 Combat Masterpiece, which is essentially a 4 inch K-22.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
10-08-2012, 01:39 PM
#27038 | |
Oddometer: 2,515
my 66-2 with 4in barrel hits a bottle cap at 20yds with no problems. that's unsupported single action mode.
10-08-2012, 02:03 PM
#27039 | |
Oddometer: 1,124
Thanks....I think
Way to make me feel old! My 'newest' S&W revolver, a 696 has the hammer mounted pin so I had to look and see when I bought it - January 1997. That would probably make it a '96 production run and fit with your circa '98 change date. Hard to believe that it was bought 15 years ago, it's one of my 'new' ones! Bruce
No one calls the Fire Department because they did something smart! 06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225 |
10-08-2012, 02:22 PM
#27040 |
Oddometer: 1,222
I want a .357 with a 4 inch barrel but these were at a local dealer and the price was right. A GP100 or older 686 with a 4 inch barrel will be next or a S&W Model 27 or a ..........
10-08-2012, 04:29 PM
#27041 |
winter is coming
Oddometer: 9,153
Sweet 66. I love 6" 66s and 19s. I have a 66-1 2.5" and a 66-7 4", but definitely am looking for a 6", think those are among the most nicely balanced and accurate revolvers on the planet. I passed on one at a gun show a while back, thinking I could find one for less $, but no luck. Inherited a 6" 19 from my dad a few years ago, but my sister wanted it and I was happy to let her take it. Guess I'll just keep looking, the 6" guns seem generally less popular than the 4" and 2.5"s, but there don't seem to be all that many of them around either, making them a little tough to find.
10-08-2012, 05:30 PM
#27042 | |
Oddometer: 668
Those are the grips I have on my PPK/S also. No problems whatsoevern no interference. Does make it 'fatter', but it fits my hand better. Not so slim anymore for concealed carry though, so bear that in mind. Had no choice back in 1993 when the factory plastic grips crumbled after two boxes of ammo
10-08-2012, 05:41 PM
#27043 |
Oddometer: 9,779
Thought I would ask the inmates...
Is $880 a good price for a numbers matching 1941 Luger in good condition? |
10-08-2012, 06:29 PM
#27044 | |
Rectum Non Bustibus
Oddometer: 3,514
10-08-2012, 07:50 PM
#27045 |
Oddometer: 111
Springfield XDM 9mm, competition model (5.25" barrel with fiber optic front sights.)
Doug |
| Thread Tools | |
