Thread Tools Rating: Thread Rating: 969 votes, 4.97 average. Display Modes
Old 02-25-2013, 05:58 AM   #28801
HardCase
winter is coming
HardCase's Avatar
Oddometer: 10,265
Sweet handguns there, 390beretta! Thanks for sharing.
Μολών λαβέ
Hard cases make bad law.
HardCase is offline   Reply With Quote
Old 02-25-2013, 08:10 AM   #28802
ig_88e
Oddometer: 133
Originally Posted by Off the grid View Post
2. The sight is zeroed for 100 and 25yds, but the iron sights are off, it shoots high and to the right. This is concerning, to say the least, as they are fixed to the gun. I checked it a few times from a gun rest to be sure. It's off.
Thoughts?
The iron sights are adjustable. At least they are on my 10/22. The rear has an elevation adjustment. Left/right is more difficult, but I recall you can drift the rear sight side-side?
ig_88e is online now   Reply With Quote
Old 02-25-2013, 08:21 AM   #28803
tommyg
Oddometer: 1,345
I bought a remington 597 back in dec and the iron sights were so far off I returned the gun, I got it back and they saiid it was fixed, been super cold so I havent had a chance to shoot it. I feel like the barrel was crooked when it was drilled. I have a feeling I got a lemon.
tommyg is offline   Reply With Quote
Old 02-25-2013, 09:52 AM   #28804
doc_ricketts
Thumper jockey
doc_ricketts's Avatar
Oddometer: 5,259
Almost done with my 10/22 build, took it to the range today to run a few hundred rounds through it...fun gun, love how cheap it is to shoot.
I'm going to add a bipod and call it done for a while, might do some trigger work in the future, the stock trigger is stiff....stiffer than my 870!
Blackhawk R/F Axiom stock
Sweet 22 scope (which lives up to its name....very nice for the $$)
Stock clear mags with Shadyrascals tri-mag adapers...very cool!
Weaver shoot-through 1" rings
Minor rant....much as I like the tri-mags, the reason I have to run them is the hi-cap restriction in CA. All it does in this case is costing me major $$. Those tri-mags (I have 2) costs a total of about 120$ and holds 30rds each.
So 2 30rd mags (essentially) for about 230 bucks.
At least the gunrest was cheap, found the design idea on Google, 5 bucks in supplies later.....
Few questions:
1: Got the scope sighted in pretty well, but I have problems with eye relief/deflection/distortion. (not sure if that's the term I'm looking for) Basically, the distortions your eye creates by looking into the scope...does this get better with practice? I noticed if I am really disciplined and stay still, control my breathing it's not an issue.
Thoughts?
My thoughts are: WHy would you pay $230 for two magazines???? Would have been much better to spend the money on an aftermarket trigger group or better scope.
"Get yourself to the hills and be uplifted, assuming you got some good knobbies"
doc_ricketts is offline   Reply With Quote
Old 02-25-2013, 11:42 AM   #28805
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 10,693
It's 2 "groups" of 3 mags.
6 Factory mags total=60 rounds=2 tri-mags.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is online now   Reply With Quote
Old 02-25-2013, 09:09 PM   #28806
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,492
The Ruger 10 round rotary mags are about $15 each... $90 for 6. How much are the tri mag hubs?????
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 02-25-2013, 09:20 PM   #28807
Off the grid
Chaotic Good
Oddometer: 10,693
With the current insanity, the clear ones were about 30 bucks each on fleabay and Shadyrascals tri-mag runs 12 bucks.
I'm sure if I drove around I might have found some, but I'm an impatient bastard.
5 for 150
1 more to make 6, 30 bucks
2 tri-mag adapters= 23 bucks shipped.
So 203 dollars exactly.
I stand corrected. Still, too friggin much but I hate reloading.
Old 02-25-2013, 10:55 PM   #28808
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Picked up this phaser lookin thing today.
*PEWPEWPEW*
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 02-26-2013, 12:14 AM   #28809
RonS
Out there...
RonS's Avatar
Oddometer: 19,443
Few questions:
Could be a couple of things. If the scope is mounted outside the eye relief range you won't see a full view and it will change as you move side to side and up and down. Move the scope forward and back in the rings until you get a full view in the position you like to shoot. Could also be the focus. That ring at the back should be focus ring. Look into the scope for a second then look away and turn it one or two full turns. Look through the scope again and see if it the view is better or worse. If better, keep going in that direction. If worse, go the other way.
Thoughts?
Drift the rear sight the direction that it needs to shoot. Get a nylon drift punch so you don't mar the finish and use a hammer of an appropriate size. For vertical I think that sight has a small screw on the rear face that lets you move the center part of it up and down. If not, you can change the front sight to a higher or lower as appropriate.
RonS is offline   Reply With Quote
Old 02-26-2013, 12:15 AM   #28810
RonS
Out there...
RonS's Avatar
Oddometer: 19,443
Originally Posted by 390beretta View Post
OK, the first one is an HKP7...
Love those P7's. I've always wanted one.
Old 02-26-2013, 03:11 AM   #28811
GoGo Gadget
GoGo Gadget's Avatar
Oddometer: 1,275
Originally Posted by EvilGenius View Post
What are your opinions on the federal #1 buck with the flight control wad?
That is what we use. I love it. All 9 pellets will easily stay on the silhouette at 25 yards.
I don't know how or when I'll die, but I know someone will be holding my beer for me when I do.
I have been told I have the body of a God. What does this Buddha guy look like?
GoGo Gadget is offline   Reply With Quote
Old 02-26-2013, 05:59 AM   #28812
MrFurious
MrFurious's Avatar
Oddometer: 704
My latest addition - a LH Savage Axis in .25-06 that's going to be the focus of several project build articles on my website site this year.
Modifications will include:
Timney Trigger (done)
True & Time Action
Flute the Bolt Body
Customize Bolt Knob
Shilen 7mm 1-9 twist barrel in .284 Win - medium sporter contour
Custom Stock (either laminate or walnut - haven't decided yet)
DNZ GameReaper Scope Mount/Rings
THe plan is to keep the total cost of the build under $1300 (what a Surgeon action runs) just to show once again you don't have to spend $3,000 plus to have a tack driving, full custom rifle. That price includes the price of the donor rifle, but not the scope. I should come in about $150 under my target price - but I do still have to get an actual price on the bluing or parkerizing work as right now I just have a rough guess-timate.
Jim B.
MrFurious is offline   Reply With Quote
Old 02-26-2013, 10:00 AM   #28813
garandman
garandman's Avatar
Oddometer: 6,118
Just passed the NRA Basic Pistol Instructor's Course after three days in the classroom and on the range. Nine guys, including four Army vets of various vintage and two LEO.
After the last range session for the course we got to bring out all our POW. Wow, what an impromptu gun show! But the winner was a broomhandle Mauser. Similar to this one.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 02-26-2013, 03:52 PM   #28814
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 12,867
*PEWPEWPEW*
Does the front end look extra chunky because it's got a laser built in?
I like the sight - that's an interesting variation.
Hope you can find 9MM for it. I was at two gun stores today, found .40 but not a round of 9 to be had.
Nice case.
Never ascribe to Evil that which is more resonably explained by Ignorance and Stupidity
There's casting, then there's running into the stream with a baseball bat trying to club the fish to death. - Jim Moore
Manuel Garcia O'Kely is offline   Reply With Quote
Old 02-26-2013, 04:35 PM   #28815
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Nice case.
Nah, it's just thick down on the front to accommodate the rail.
The barrel also sits down lower than most pistols so the frame needed to be deeper to fit all the mechanics down lower, which is the reason for the weird grip angle. All to lower the bore axis.
The only 9mm they had was blazer Al case, so I grabbed a couple of boxes.
EvilGenius screwed with this post 02-26-2013 at 04:55 PM
Thread Tools
Times are GMT -7.   It's 01:12 PM.
