03-18-2013, 08:28 PM
#29056 | ||
Easily trainable
![]() Can I get an AMEN?!
03-18-2013, 08:35 PM
#29057 |
Pumpkin Rider
Oddometer: 13,207
Pretty gun.
I just can't bring myself to drop the big bucks for a gun and more expensive ammo.
Don't trust links? Google ADVFilmer for videos. ![]() http://www.youtube.com/user/advfilmer |
03-18-2013, 08:40 PM
#29058 |
Back at last
Oddometer: 9,896
JOOC, how can you carry such a nice looking pistol in a plastic holster?
And looking at the prices for them, I get the vapors.
"More than any time in history, mankind now faces a crossroads. One path leads to despair and utter hopelessness, the other to total extinction. Let us pray that we have the wisdom to choose correctly." Woody Allen "*enhance* not enjoy, gramps mcbuzzkill" - Lemon G.
03-18-2013, 11:17 PM
#29059 |
Oddometer: 2,801
I'm a gunsmith, firearms trainer and USPSA A class shooter. I know I am supposed to love 1911's and hate Glocks... but I can't. I have owned over a dozen 1911's and worked on dozens of others. 1911's work "IF".... If you use GI spec ball ammo, if you make sure the springs are matched and changed every 2500 rounds, if you use Wilson mags, if you clean them regularly and lube them sparingly, if you have John Browning come out of the grave and tune the fucking extractor every 1500 rounds, if you have a firm grip, if the ejector is perfectly staked, if your support hand doesn't drag the slide or catch the slide release, if your shooting thumb doesn't bump the safety, if.....
I work on a lot of Glocks too... usually to improve the plastic POS sights and slick up the triggers. The ones that don't work are almost always due to someone farkling them without a clue. Take a bone stock Glock 21 for $500 or so. Put a set of $60 steel sights on it and clean up the trigger a bit and you are done(.) 14 rounds of .45ACP on tap- no questions asked. 185 gr Semi wadcutters at 800fps- no problem. 230 gr +P at 1000fps- okay. Clean it every few years- sounds good. Hot and dusty desert conditions- cool. Super cold- wipe the oil off and shoot away. Offhand grip- it'll work just fine. Change the mag springs every 500 loadings, the trigger springs every 10,000 rounds and the recoil spring every 20,000. I carry a crash kit at the range to help out other shooters. 1911's typically take a trip home to fix anything. Almost everything to rebuild a Glock can be done on my tailgate using an Altoids can of parts. At this point I am still maintaining and shooting a Gen 1, G17 with over 175,000 rounds through it. 50,000 from the 2nd owner between 1995 and 2001- 100,000 from me between 2001 and 2007 and 25,000 rounds from the 4th owner from 2007 to now. I got it for free with the instructions to shoot it as much as possible and track the round count and I passed it on with the same instructions.
I was born... I shall die... but the time in between is mine. WWJWD? What Would John Wayne Do? Southwest Riders visit www.my2wheels.com. |
03-18-2013, 11:19 PM
#29060 |
Oddometer: 2,801
That was my first centerfire pistol- a Duo Tone version actually. I still own it.
03-19-2013, 01:45 AM
#29061 | ||
Oddometer: 808
As far as I know, the 4th gen Glocks were designed around .40. So, of course, 9mm shooters then had problems with them. Me? I like 3rd gen 9mms. Pull trigger = BANG! Quote:
The M&Ps are proving to be Glock-like in their function as well. So, for "it's a tool in the toolbox" shooters, Glocks and M&Ps. As for Glock triggers, the $.25 trigger job NOT overdone and wow, what a difference. If people insist on changing parts, I personally recommend OEM replacement parts so that it's still "all Glock OEM," even if not stock. An exception, I do have a titanium drop safety plunger and lighter spring in my Glock. I suggest getting the spring first and seeing if that helps enough as I think it provides 90% of the value of modding those parts. For a eye-opening (range or dryfire only), try taking the drop safety out of the Glock and try the trigger pull. WOW! It's amazing how much difference that makes. However, on a carry gun, removing a safety is begging for potential trouble *if* it's used in a shoot and/or a questionable discharge occurs. But for a range or target-only Glock? Hmmm. ![]() Oh, BTW, I love 1911s and nothing I said should be taken as anti-1911. I got a 9mm back in the day because it was cheaper to shoot. I got a Glock because I shot it better than the typical DA/SA 9mm of the day. That's it. My heart is with 1911s, but they DO take commitment that is NOT required in today's modern arms.
Rights are Rights, erode one, erode them all. Civil libertarians need to stop taking a fractured look at Rights, defending only those they, personally use, and allowing others to be attacked. All Rights have benefits, all Rights have costs. That's part of living in the society of the United States. --Me (Does it need to be a famous person's quote to be valid?) Tripl Nikl screwed with this post 03-19-2013 at 01:52 AM |
03-19-2013, 04:26 AM
#29062 | |
The Man.
Oddometer: 5,417
03-19-2013, 05:07 AM
#29063 | |
Oddometer: 4,597
But I do love my pajama holster and shower holsters.
'01 Kawasaki W650 '05 Yamaha XT225 |
03-19-2013, 05:09 AM
#29064 | |
Oddometer: 808
"'Now, I shoot a Glock,' Vickers tells me. 'Make sure you tell guys that the 1911 is a pain in the ass. If they don’t like messing around with the pistol and spending a grand to really get it tuned, then they should forget it.'” http://militarytimes.com/blogs/gears...ur-first-1911/ " I am a big fan of both the G17 and G19 in 9mm and that is what I use." http://vickerstactical.com/tactical-...larry-vickers/ "... I feel most people are best served NOT using a 1911 as a primary sidearm... If however you treat your pistols like we all treat our lawnmowers then don’t get a 1911 – use a Glock." http://vickerstactical.com/tactical-...larry-vickers/ Um, nope. I'm fully aware that Larry Vickers is a god among men in 1911 circles. And the LAV's words--not mine--are that the Glock is the "universal service pistol" that serves most peoples' needs the best.
Rights are Rights, erode one, erode them all. Civil libertarians need to stop taking a fractured look at Rights, defending only those they, personally use, and allowing others to be attacked. All Rights have benefits, all Rights have costs. That's part of living in the society of the United States. --Me (Does it need to be a famous person's quote to be valid?) Tripl Nikl screwed with this post 03-19-2013 at 05:16 AM |
03-19-2013, 06:15 AM
#29065 | |
Easily trainable
Glock: The Toyota Corolla of the gun world
![]() NTTAWWT ![]() ![]() I'm sure they're a fine firearm. Just not for me.
03-19-2013, 06:19 AM
#29066 |
Formerly FlagGS
Oddometer: 1,042
I've been putting out fire with gasoline. |
03-19-2013, 10:41 AM
#29067 | |
Purveyor of Awesome
Oddometer: 3,385
I just got mine last week. I was on the waiting list almost 2 years. Kel-tec is way behind on production of this gun, largely due to design changes early in the game. My local gun store still sold it to me for $100 below MSRP, despite the apocalyptic prices at other stores. It is hard to imagine one of these just sitting in a store. Most of these were sold before they were even made. Due to the low production though, many gun stores wouldn't do prepaid orders on it. Sent from the voices in my head and transcribed by their drinking buddy...
'67 Bonnie, '68 Tiger, (position vacant), '07 Bonnie/Cargo Hack, '11 Ural Gear-Up, '13 Husqvarna TR650 and a deep lust for more |
03-19-2013, 01:41 PM
#29068 |
Oddometer: 4,597
Have you seen what used plain-jane Kel-Tec Sub2000's are going for?
I've seen them sold recently for $600-900, this for a gun that normally retails for $300 new. We are indeed living in interesting times.
03-19-2013, 02:23 PM
#29069 |
Back at last
Oddometer: 9,896
Walmart has plenty of rifles and shotguns but today, well, someone must have had a party, all the 100 round packs of 12 ga Trap? There were dozens of boxes, all gone today.
I found 9 mm HP's, .40 FMJ and HP's, but only at one out of six shops. No .22 to be had. BUT, one store, the clerk was kind enough to tell me that they do get a delivery every Thursday - and it's gone by 10:30, so maybe day after tommorrow I'll be there when door opens.
03-19-2013, 02:57 PM
#29070 | ||
adventure imposter
Oddometer: 14,843
ImaPoser Save $5 when you open your own smugmug account. Use code: DeAGMxYPTdjUA Quote:
| Thread Tools | |
