Thread Tools Rating: Thread Rating: 952 votes, 4.97 average. Display Modes
Old 05-10-2013, 02:36 PM   #29641
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
This is just a guess, I am not a gunsmith.
But is it possible that with a tight, non-fitted (yet) slide you could get some valve lapping compound (like for a car engine) and put that on the rails and slide then spend an hour (or a few) running it back and fourth?
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 05-10-2013, 02:47 PM   #29642
TexBiker
TexBiker's Avatar
Oddometer: 815
Originally Posted by 00SS View Post
I did a bit of research as the slide fits 'very' tight.. any thoughts on the best way to 'lap' it in?
Garnet lapping compound works well. I attended a 1911 build class with Bob Rodgers a few years back and that's what we used on our customs.
Get it here: Garnet Lapping Compound - Brownells
Ended up with this Dan Wesson CBOB homage when we were done:
Fun little 10mm beast.
Suppose you were an idiot...And suppose you were a member of Congress...But I repeat myself.
-Mark Twain
TexBiker is offline   Reply With Quote
Old 05-10-2013, 02:51 PM   #29643
00SS
Always a vicious cycle
00SS's Avatar
Oddometer: 1,696
Kind of what i was thinking, maybe some lithium grease. I was also thinking no harm in putting a box through it and see if it'll lighten up a bit. I guess the worse that will happen is it won't cycle if it's to tight?
If you choose not to decide, you still have made a choice
00SS is offline   Reply With Quote
Old 05-10-2013, 02:54 PM   #29644
00SS
00SS's Avatar
Oddometer: 1,696
Nice piece - i'll have a look at that compound.. thanks for the tip.
Old 05-10-2013, 02:55 PM   #29645
TexBiker
TexBiker's Avatar
Oddometer: 815
No, you could end up galling the frame/slide together and ending with a very expensive issue. Best to use a non-embedding lapping compound as mentioned in my previous post to prevent this issue.
-Mark Twain
Old 05-10-2013, 03:32 PM   #29646
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Location: NC, DC, and various other places around the world
Oddometer: 8,474
Beautiful!
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 05-10-2013, 04:00 PM   #29647
00SS
00SS's Avatar
Oddometer: 1,696
duly noted - thanks again for your help.
Old 05-10-2013, 10:02 PM   #29648
Speedo66
Transient
Oddometer: 6,681
I use anti-seize compound on my Glock slide rails. They come from the factory with a copper paste on them, which I've been told is a form of anti-seize.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 05-11-2013, 12:02 PM   #29649
Motor31
Motor31's Avatar
Oddometer: 1,948
Something to consider is that if you wear down the rails on the frame the original slide may become rather looser than you want. You should look at working the new slide and make it fit the frame rather than modify a frame that already has a good fit with the original slide. Using valve grinding paste will work both the slide and frame rails, not just the slide. What is the part that is hanging up? Is it the thickness of the slide rail, shallowness of the female cut or is the cut too narrow? Is it because of binding at the breach end of the barrel or is the barrel binding on the locking lugs in the frame? Is it possible that the new slide and frame are the same grade of steel meaning they are galling together rather than sliding? You should identify what the binding is from before you start taking away metal.
I like home gunsmithing but only when there is a knowledge basis to work from. Experimentation can get rather costly if you make a mistake. I might be a bit overly cautious but for me I'd rather pay a 'smith who know what he's doing rather than kludge up a perfectly functional gun. Even if he just gives advice on how I should handle the issue.
Wherever we go, there we are.
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
Author Unknown
Motor31 is offline   Reply With Quote
Old 05-11-2013, 12:28 PM   #29650
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
I don't disagree with you and it's not my gun, but I think he's intending for this to be the new permanent slide for the gun. If that's the case, then it should be fine for the frame rails to wear a bit.
Old 05-11-2013, 03:41 PM   #29651
goodburbon
Oddometer: 111
Last 3 gun match
Bushmaster xm-15
Remington 870 20ga
Springfield XD-40
Last tactical rifle match,
RRA elite operator.
Next one...I dunno, depends what ammo I can round up. I have plenty, but won't shoot it unless I can replace it.
Sent from my iPad using Tapatalk HD
06' Buell Ulysses...gone
13' BMW F700GS factory low.
07 XT225
00' TTR125L
09' Buell Ulysses
goodburbon is offline   Reply With Quote
Old 05-12-2013, 05:31 AM   #29652
pilot
Slacker Moderator
pilot's Avatar
Oddometer: 31,363
Then you don't have "plenty".
The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them.
-Furious D
pilot is offline   Reply With Quote
Old 05-12-2013, 05:43 AM   #29653
sieg
sieg's Avatar
Oddometer: 2,788
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 05-12-2013, 07:32 AM   #29654
00SS
00SS's Avatar
Oddometer: 1,696
Yep - i planned on it being the permanent slide.. so not overly concerned on a bit of frame wear.
motor31 - yes, i agree 100% as well, but as i said it will be perm. I have been working the slide quite a bit and it feels like it's 'loosened' up a bit from where it was. It seems with the hammer down it is much harder to cycle.. however, if i pull the hammer back and rack it.. it's seems almost perfect (albeit just a tad tighter than the stock slide). I'm going to use a bit of that Brownells lapping compound and take it to the range next week. I'll post up some results afterward, hope it holds at least the same grouping as before (if not better).
Old 05-12-2013, 11:46 AM   #29655
Callahan
Callahan's Avatar
Oddometer: 1,181
Guns for sale ?
Hi Guys and Gals,
Is there a Gun For Sale section anywhere here on ADV ?
Thank you in advance.
Callahan is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 12:14 PM.
