Thread Tools Rating: Thread Rating: 1091 votes, 4.97 average. Display Modes
Old 12-17-2009, 10:58 AM   #4426
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,121
Originally Posted by UPSam
I have shot deer with that round and a full power 357. The wimpy 44mag load is better
It kills 'em deader?
Old 12-17-2009, 11:34 AM   #4427
McNeal
Oddometer: 1,741
Originally Posted by Aurelius
I've read that. I've also read reports from reloaders who routinely do it and say its just an old wive's tale.
I have some lead bullets for the 9mm so I decide to load up a few for my Glock 19. I shot five rounds and those will be the last five lead bullets to ever go through that gun. I swear I scrubbed that barrel down for a full hour to get the lead out. I knew the bullets would leave deposits, but damn I didn't think they would leave that much.
My Glock is my only 9mm and I don't shoot it that much. If I did I would probably invest in an additional barrel which has the normal rifling that can handle lead rounds. The break even point for purchasing a new barrel isn't worth it to me for the amount that I shoot that gun. For some reason I can barely hit the broad side of a barn with the Glock. It's not the gun, but me since I've had someone else shoot the pistol and they did just fine. I'm not a bad shot, not a great one either, and have no problem hitting what I aim at with my 1911.
McNeal is offline   Reply With Quote
Old 12-17-2009, 11:48 AM   #4428
Aurelius
Aurelius's Avatar
Oddometer: 22,527
Odd that you should mention the Glock. That's the very gun another reloader claimed he regularly fires cast lead bullets through without any problems. Perhaps it has something to do with composition of the lead alloy he uses.
Its more likely a combination of you and the gun. Some guns shoot impressive groups at the factory when clamped in a vice, but something about their ergonomics and balance is detrimental to accuracy when fired freehand. I've owned a number of 1911's, and I've always been able to shoot better with them than with other pistols.
Dizave opined: Why do you care where the premises come from? They are above reproach. For all intents and purposes, you can just make up all your premises, since they can't be proven anyway. That's why we need premises.
Aurelius is offline   Reply With Quote
Old 12-17-2009, 11:54 AM   #4429
garandman
Oddometer: 6,163
Just because.....
garandman is offline   Reply With Quote
Old 12-17-2009, 11:56 AM   #4430
The_Commander
The Man.
The_Commander's Avatar
Oddometer: 6,255
I wouldn't shoot lead bullets in any "modern" auto pistol.
The_Commander is offline   Reply With Quote
Old 12-17-2009, 12:01 PM   #4431
Aurelius
Aurelius's Avatar
Oddometer: 22,527
What qualifies as "modern"?
Old 12-17-2009, 12:08 PM   #4432
mtguy
mtguy's Avatar
Oddometer: 416
If loading your own lead bullets to shoot out of a Glock, tumble lube them first with liquid alox or other type of bullet lube. YMMV.
I cast and load my own and have noticed a significant decrease in barrel leading out of my 1911 with the alox tumble lube.
mtguy is offline   Reply With Quote
Old 12-17-2009, 12:11 PM   #4433
DireWolf
Knees in the Breeze
DireWolf's Avatar
Oddometer: 13,264
Originally Posted by Alejo
The stock grips are ok, but the bantam are fantastic.
Mine came with those, but a friend just gave me some pachmyars I'm gonna try. The bantams have the backstrap exposed, which lends to slight palm bruising after 50 rounds. Probably won't make much difference - I do like the feel/grip on the bantam.
DireWolf is offline   Reply With Quote
Old 12-17-2009, 12:28 PM   #4434
UPSam
All jacked up on Dew
UPSam's Avatar
Oddometer: 16,370
better hole more bleeding
the 357 really sucks in my experience on even dinky deer. won't be repeating it.
"There was a lot of talk last year about how Barack Obama would be a “transformational” president — but true transformation, it turns out, requires a lot more than electing one telegenic leader." -Paul Krugman 8/30/09
UPSam is offline   Reply With Quote
Old 12-17-2009, 12:45 PM   #4435
UPSam
UPSam's Avatar
Oddometer: 16,370
My experience with excessive headspace is based on the series of WWI & WWII SMLE surplus military rifles, all of which had notorious head spacing issues. Typically I'd see signs of incipient case head separation after only 6 reloads - in one rifle as little as 2.
The 303 is a rimmed cartridge . It headspaces on the rim. You change out the bolt heads(they are numbered) to fix headspace Head seperation isn't caused by headspace in a rimmed cartridge. I would guess the chamber is generous and you are overworking the brass. Did you try a neck sizing die?
Headspace can cause head separation in a rimless cartridge but overworking brass is also a cause.
Possible the dies you are using aren't correct for the British military spec but for a sporting specification.
I did find quite a few`Indian enfields with excess headspace. Probably bolts were swapped before they were sold or they swapped bolt heads for spare parts. I think the only symptoms would be primers backing out or maybe punctured primers. 7.62x51 Indian enfields do have issues..not a rimmed case.
Old 12-17-2009, 12:51 PM   #4436
UPSam
UPSam's Avatar
Oddometer: 16,370
I asked a group of action pistol shooters that use Glocks about buying after market barrels for lead cast bullets. They all shot stock barrels and lots.
Glock definitely had warnings on doing it and so did shooting publications. Could be that swagged bullets, soft, bullet or too high velocity was the problem or just idiots?
I have never had problem with leading except with swagged bullets or ported guns.
I would like to know so I can use cast bullets in my 23
Old 12-17-2009, 12:52 PM   #4437
UPSam
UPSam's Avatar
Oddometer: 16,370
Swagged or cast?
Old 12-17-2009, 12:53 PM   #4438
UPSam
UPSam's Avatar
Oddometer: 16,370
Originally Posted by koifarm
Any constraints about advertising a firearm for sale on this forum?
Yes. No ads here and no guns in the flea market
Old 12-17-2009, 01:03 PM   #4439
clevishook
stevedore
clevishook's Avatar
Oddometer: 1,625
Someone mentioned earlier Gunbroker. Thanks I just wasted the best part of the day staring at the candy.
Does anyone remember the Savage over and under shotgun with a .22 on top and a 20ga for the lower barrel. Could have bought one for about 100 bucks back in the day.
In Fl they say that is really all you need to hunt in this state.
clevishook is offline   Reply With Quote
Old 12-17-2009, 01:03 PM   #4440
Aurelius
Aurelius's Avatar
Oddometer: 22,527
I've done that, but the improvement is slight. And if you go up more than one size, the bolt won't close.
I shoot very mild loads - nowhere near factory specs (my favorite load is 19gr of SR4758, w/ 150gr SP). And yes, I always neck size until I feel the cases beginning to stick in the action. A couple of my 303's come with a broken case extractor - something I've never seen supplied with any other gun. It proved quite handy on several occasions while out plinking in the woods.
Thread Tools
Times are GMT -7.   It's 04:16 AM.
