12-15-2010, 02:54 PM
#12811 | |
Oddometer: 2,794
I was born... I shall die... but the time in between is mine. WWJWD? What Would John Wayne Do? Southwest Riders visit www.my2wheels.com. |
12-15-2010, 03:50 PM
#12812 |
Von Hochstaden's son
Oddometer: 44,967
Cheaper than a 1911 and easier to conceal.
No ... is not going to shoot or be fidgeted with as easily as a 1911.
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
12-15-2010, 04:39 PM
#12813 |
Oddometer: 384
Updated post with actual pics. Baby Eagle 9mm Love it never sell it. Most accurate non target I've ever shot.
![]() Ruger MKIII Target this one is sweet and lethal to all varmints.
BigSingle screwed with this post 12-19-2010 at 08:30 AM |
12-15-2010, 04:44 PM
#12814 |
Fattest thin man
Oddometer: 3,461
Well, it is only a .22.
Az
"Write a wise saying and your name will live forever" - Anonymous |
12-15-2010, 04:45 PM
#12815 | |
Fattest thin man
Oddometer: 3,461
![]() Az
12-15-2010, 05:15 PM
#12816 | |
Life behind "Bars"
Oddometer: 6,245
There musta been some pretty good blast coming out around the cylinder. Good thing it was a revolver.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
12-15-2010, 05:24 PM
#12817 |
Hmm...
Oddometer: 4,081
"I'm going to shift gears now.... This will involve man touching." - Jeremy Clarkson |
12-15-2010, 05:40 PM
#12818 |
Fattest thin man
Oddometer: 3,461
Whattya know? That makes it a bit more impressive, for sure.
Az
12-15-2010, 06:50 PM
#12819 |
Cochetopa dreamin'
Oddometer: 463
it does improve the balance for pistol whipping......
12-15-2010, 07:01 PM
#12820 |
Undercover KTM rider
Oddometer: 807
theres no way that's a .357
*edit* looks like a single 6. Even tank-like rugers will banana peel the barrel if you do that with calibers more powerful than 22 mag. SteelJM1 screwed with this post 12-15-2010 at 07:10 PM |
12-15-2010, 07:13 PM
#12821 |
PNW Heel Rounder
Oddometer: 19,313
He was holding it sideways, squibwad.
Let’s not reinvent the wheel, let’s wear it out. |
12-15-2010, 07:17 PM
#12822 |
Oddometer: 807
12-15-2010, 07:26 PM
#12823 |
Hmm...
Oddometer: 4,081
It was said to be a 357 on the Ruger Forums. The barrel was not cut to the center of the barrel but stops short, as you can still see the front sight was left mostly intact. Do they make jacketed 22's? Not washed but actual jacketed? Also they look to be wadcutters.
12-15-2010, 07:36 PM
#12824 |
Oddometer: 807
Not trying to call you a liar, its just that it would be an insanely bull barrel (over an inch in diameter). As far as the wadcutter.. well theyre sqished in there pretty ood, plus a jacketed wadcutter?As far as jacketed 22's im not sure. Were they ALL squibs? If that's the case (and they're not 22's), then the guy doing the reloading has to lay off the crack pipe while reloading, or the manufacturer needs to really check their qc.
My opinion on what happened. Single-6 .22, first shot was fine, the second was a squib, and the following 4 didn't alert the guy that he was having problems somehow. I can't imagine having 5 centerfire squibs in a row, and i know of no centerfire gun that can take 4 full power rounds behind the squib and not so much as bulge the barrel. |
12-15-2010, 07:44 PM
#12825 | |
Hmm...
Oddometer: 4,081
Like I said before the barrel wasn't cut in half. When you cut it short you get the appearance that the barrel is thicker then it actual is. You're not seeing whole dia. of the bore.
| Thread Tools | |
