Old 11-21-2008, 12:44 PM   #1
Shoganai OP
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,761
Talking The Blue Streak Wrenchin' Thread
She's home!!
BB = Baby Blue
SW = Shop Whore
Some comments after riding her home last night:
1. BB has 51,700 mile and it shows. Less overall vibration felt thru the grips, saddle and pegs than the SW with 180,000 miles.
2. The pull on the clutch is 35% - 45% lighter and the shifting up and down is very, very smooth. (I suspect I now need to adjust the cable on the SW)
3. The excelleration is smoother and quicker.
4. It is more nimble in the turns.
5. The throttle is more responsive.
Well, it begins
So the first thing we needed to do was puts some lights on her.
We started with these pics...
And we sent them to a friend of ours.
While waiting to hear back, Steve set up the PIAA's with HID's.
Time to test fire it...
Our friend sent these pics.
Ok, here's some more pics of the process.
Steve mounted the Blue Sea fuse block. We didn't use it for this light project, but set it in place for future projects.
Hey! Look! My bike matches the floor!!
Steve wired it so the the high beam switch turns on the PIAA's. So low beam is the main head light, high is all three.
We wanted the relay and 30 amp fuse (white box) in a place that was not too hard to get to.
Wires pulled thru.
More prorgess forward.
The inner plate and outer plate center holes were slightly enlarged to allow the connectors to pass thru.
Ok, now the brackets are here, time to make them fit.
It's out of focus, but you can see the raised bushings, they'll need to be shaved down.
I cut out the rubber washers on the back
Then I pushed out the bushings.
This was the sanding set up I managed to come up with.
This was my first attempt
Well, that clearly didn't work. I couldn't control the bushing very well.
Ok, STOP! Think.
This was my next attempt. Different bolt, and washers, #12 3/4" socket...
That worked GREAT!!. I had very good control of pressure and the ratchet allowed me to gently rotate the surface I was grinding.
However, when I assembled all the parts, there was a gap between the bracket and the rubber mount.
I marked out where each bracket will go.
Then I pushed out all the bushings again, and began with Dremel, to create a recessed area for the bracket.
Here's the finished mount less the light.
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Old 11-21-2008, 12:53 PM   #2
a1fa
Throttle Jockey™
a1fa's Avatar
Oddometer: 13,881
Welcome home baby blue..... You are my boy blue.
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 11-21-2008, 01:37 PM   #3
exwingnut
Entremanure
exwingnut's Avatar
Oddometer: 8,996
Sweet modification! Looks real profeeshional n'all.
~What wisdom can be found
that is greater than kindness~
exwingnut is offline   Reply With Quote
Old 11-21-2008, 02:13 PM   #4
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Thank you both. the left side is now finished with the seating of the bracket into the stand-off.
When Steve gets home, he said he'll work on the wiring.
I'm no good at herding electrons
ZZZaaaP!
Nana korobi ya oki
Old 11-21-2008, 02:50 PM   #5
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,758
If I had one 'o them things I'd rack up too many speeding tickets to hang on to my license.
Old 11-21-2008, 04:10 PM   #6
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,369
Wow, Gwen, you do some nice work. I understand your attraction to the flying bricks. One of these days I'll break down and find a K1200RS or GT. Those are my favorites.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 11-21-2008, 05:25 PM   #7
nwgs
solarfied
nwgs's Avatar
Oddometer: 33,931
My old K bike was the same color. What a beauty Gwen.
What a beauty...
Originally Posted by unaweep View Post
I don't care what the facts are. I believe this is true.
The List
nwgs is offline   Reply With Quote
Old 11-22-2008, 07:39 AM   #8
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,668
Test fit and test fire works...
Now she gets to take the brackets off and clean them up.
Can you say "holy shit" light...PIAA 910's with a 35w H3 HID. ZAAAAAAAAAAAPPPPPPPPPP...
Steverino is offline   Reply With Quote
Old 11-22-2008, 07:49 AM   #9
Steverino
Oddometer: 36,668
Old 11-22-2008, 08:00 AM   #10
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,578
Love the color of the bike Gwen.
Great write-up and pictures.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 12-05-2008, 05:07 PM   #11
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Testing an idea. The c-clip the fit the seat pin is a PIA.
1. the clips often fall out.
2. The ones that stay in, when I need to remove the seat, are a bitch to remove and replace.
So, this is what I did tonight.
I'll grease it up tomorrow and see how it works out.
Nana korobi ya oki
Old 12-08-2008, 07:50 AM   #12
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Steve mounted the Blue Sea fuse block and ran wires to power the GPS, tank bag and Gerbings.
Next he replaced the worn out handlebar bushings.
In the mean time I sanded and painted the light brackets. I'll be mounting them back up today.
Pics to follow.
Nana korobi ya oki
Old 12-08-2008, 09:07 AM   #13
Putts
Gettin' there.
Putts's Avatar
Oddometer: 11,395
Wow, looks great. Have you had it out at night yet?
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is offline   Reply With Quote
Old 12-08-2008, 09:40 AM   #14
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Yes, we have...
Low only.
PIAA's and high.
Low only.
PIAA's and high.
Nana korobi ya oki
Old 12-08-2008, 01:56 PM   #15
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
OK, I'm done in the garage for today.
PIAA lights are mounted.
GPS is mounted. I cut and painted the bar yesterday, but it turned out like this...
So I said screw it, sanded it all off and left it like this.
I made two small bushings and cut these screws down to the right legnth.
Next I mounted my Heat-troller for the Gerbings.
I cut another peice of alum. bar and shaped it.
Steve will be home soon, so off to fix supper.
Nana korobi ya oki
Times are GMT -7.   It's 02:07 AM.
