Old 05-30-2011, 05:47 PM   #76
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,009
Nice work. But wrenching means no riding. Unless you have a couple spare ponies in the stable.
Me, I've been working on the farm and estate stuff. Not as much fun as riding I can assure you.
David
'07 VFR800, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Alaska Trip Report
MTrider16 is offline   Reply With Quote
Old 05-30-2011, 07:32 PM   #77
Shoganai OP
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,626
I have a K1200S to ride.
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Old 05-30-2011, 07:50 PM   #78
DynaSport
Oddometer: 448
So, did you buy this bike just to work on it? You must be very happy with it!
Your work is an inspiration. Maybe you could work part time at the dealership.
DynaSport is offline   Reply With Quote
Old 05-30-2011, 09:32 PM   #79
Shoganai OP
Shoganai's Avatar
Oddometer: 1,626
Thank you. No, it's like any older machine; it just needs love.
I rather do the lovin' and not pay someone else.
No, I'm a cardiac nurse, wrenching is just for fun.
If you have time, look for my Shop Whore gets Naked thread.
Yes. I still have that one also
Nana korobi ya oki
Old 05-31-2011, 09:31 AM   #80
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,516
You do?
Steverino is offline   Reply With Quote
Old 05-31-2011, 12:35 PM   #81
Dismount
Boring bastard
Dismount's Avatar
Oddometer: 7,949
Send a message via ICQ to Dismount
I gotta meet you two hellions one day and show off my "chrome duct tape" version of wrenching.
I like cold wet doggy nose in my crack.
Dismount is offline   Reply With Quote
Old 05-31-2011, 08:16 PM   #82
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,009
Originally Posted by Steverino View Post
You do?
What's yours is mine, and whats mine is mine. Read the fine print and give the lady the keys. (God knows she deserves it, putting up with your cranky old self.)
I really hope I get a chance to meet up with you two sometime.
David
Alaska Trip Report
Old 06-06-2011, 07:25 AM   #83
Steverino
Oddometer: 36,516
David
She does...any time she wants to.
Please do not paint it pink.
Old 06-06-2011, 07:34 AM   #84
Shoganai OP
Shoganai's Avatar
Oddometer: 1,626
True.
As you wish dear.
Nana korobi ya oki
Old 06-06-2011, 07:35 AM   #85
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 20,594
True.
As you wish dear.
Periwinkle it is!!
SmugMug coupon 0E8WP3kJcvvbY save $5 The Banjo Rides
knybanjo is offline   Reply With Quote
Old 06-06-2011, 07:40 AM   #86
Steverino
Oddometer: 36,516
True.
As you wish dear.
CALL ME CALL ME CALL ME CALL ME CALL ME CALL ME...please
Old 06-06-2011, 07:41 AM   #87
Steverino
Oddometer: 36,516
Originally Posted by knybanjo View Post
Periwinkle it is!!
She can do what ever she wants with it. After I get the RC8 if I do...
Old 06-08-2011, 07:05 PM   #88
Shoganai OP
Shoganai's Avatar
Oddometer: 1,626
I ordered the seal / o-ring set for the filler cap but due to being rushed to finish the project, I didn't take any pics.
I decided to increase my fuel top off capacity by removing the entire flapper assembly.
My riding range increased by 35+ miles at interstate speeds. And 50+ at casual paced riding.
There has been much talk about the fact that the stated total capicity of the fuel tank is 5 gallons and yet one can’t seem to put 5 gallons in it even when dead empty.
Now I know why.
This is with the mod above.
No, it doesn't leak when filled to the max, the cap closed and on the side stand.
Nana korobi ya oki
Old 06-08-2011, 07:59 PM   #89
Shoganai OP
Shoganai's Avatar
Oddometer: 1,626
Finished.
Next thing on the list to fix was this.
These side panels are real PITAs.
Steve suggested using magnets so that’s the direction I went.
There are in fact three contact points, two pins fore and aft and the broken “C” clip in middle. I’ve used rubber tubing over the years, and it works ok but not great.
So I’ll be replacing them as well. First I cleaned the pins then to give the Rescue tape a firm place to bind to I put some heat shrink on them.
Rear pin.
Front pin.
Found this.
Repaired with Rescue Tape.
The center...I needed to create a flat place for the magnets and yet attach it to the round pin.
Left is the rubber I need to replace. So I insert a bit of nylon tubing that I plan to drill out to fit the metal pin on the bike.
Well, it didn’t work. The drill bound up on the inside and I couldn’t hold it tight enough and still keep it round.
So I found a bit of silicon tubing.
Test fit feels good.
Cut to fit.
Attached with epoxy.
I took it for a big test ride today and worked great. I’m very happy with the results.
Nana korobi ya oki
Shoganai screwed with this post 06-09-2011 at 07:28 AM
Old 06-08-2011, 09:34 PM   #90
Shoganai OP
Shoganai's Avatar
Oddometer: 1,626
This next segment needs a little preface.
Are you listening?
Ok, this is it...I SUCK at all things that involve making electrons go the way I want them to. I simple don’t understand it and you are about to witness this first hand.
Let me set the stage.
Steve is at work and I decided to tackle this alone.
The rough plan was to use an existing dash switch to activate the dash light.
At first I thought about use the hazard switch.
I had talked with Duck about this and he sent me this diagram.
So put on some music...
And started taking things apart.
As it turned out this bike didn’t have heated grips, so I decided to cut the heated grip switch out of my other K1100RS and use it instead.
Now the high heat position on this switch hasn’t worked in a long time and after removing it I could see why. It has been soldered on in the past and not by me.
I start sending pics to Steve via Facebook asking if what I drew will work. The goal was to connect the LEDs through the modified switch power it through Blue Sea fuse block.
This was my first attempt.
Steve said ‘No’ then tried over the phone to help me understand what’s wrong with that drawing and how to overcome it.
This was the next.
SWEET! This will work.
I needed more room for more wires.
I had to repair one ring connector.
(Yes Phil, I tinned all my wires in this project and used heat shrink)
Steve came home and found me stopped dead in my tracks. I was trying to use a multi-tester (never used one before that day) to figure out why in spite of everything appearing to be connected right, it didn’t work.
Steve found there was no power to the Blue Sea and that a 30 amp fuse was blown. As it turns out I crossed up the (-) and (+) connections on the Blue sea. Everything had to be disconnected on the fuse block and put back in the order.
Then I solder everything together and flip the switch and it doesn’t work again.
Steve found I didn’t put a big enough fuse on the switch. That replaced with the right side and POW! LIGHT!
Nana korobi ya oki
Shoganai screwed with this post 06-09-2011 at 07:33 AM
Times are GMT -7.   It's 04:33 AM.
