Old 10-22-2012, 05:32 PM   #15001
walkergreenlabel
Oddometer: 200
Thumb
Originally Posted by Jayrod1318 View Post
For Reference the STOCK DID front rim width measures:
2.45'' (+/-).020''.
thats what I need to set the rim centered to the hub. without that i would have a nice straight and true rim that is too far to one side.
thanks gents!
walkergreenlabel is offline   Reply With Quote
Old 10-22-2012, 06:34 PM   #15002
RalphyDo
Oddometer: 308
Originally Posted by aaronp1264 View Post
yeah, it makes sense. i wouldn't be surprised at all if i tore apart the clutch and found it with an updated bushing anyway.
so while my bike was on its side it started leaking fluid. never had this issue on two wheels. is it time for seals? here's where the fluid was escaping.
What year is your bike? The bushing was updated in 02-ish if I remember right.
re you sure your forks where not leaking at the top cap and the oil was running down to the lower clamp? If not, then your fork tube is cracked from over-tightening!! I'd loosen the clamps and slide the fork down alittle for inspection!
RalphyDo is offline   Reply With Quote
Old 10-22-2012, 06:39 PM   #15003
RalphyDo
Oddometer: 308
2.45'' (+/-).020''.
Alternatively you could lace it up and keep it loose and mount on bike and find the center between the two fork tubes which by my eye is dead center.
Ooops, just saw this. My Excel Takasago front wheel is 2.170" wide. That means he needs .660" measured from the rotor mating surface to the outside of the wheel!
Edit: My front has around .937"
RalphyDo screwed with this post 10-22-2012 at 06:45 PM
Old 10-22-2012, 08:21 PM   #15004
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Originally Posted by walkergreenlabel View Post
thanks. Thats pretty much the same set up I am using without the dial indicator. I should be able to do it but but how did you center the rim to the hub to ensure its centered vertically on the stand? the excel rim is not the same diameter as the DID rim so the measurement in the service manual will be different.
thanks in advance for any tips. you can throw in a FYFFF salute if you want.
I just guessed and then eyeballed it. It worked out ok.
lstzephyr is offline   Reply With Quote
Old 10-22-2012, 11:28 PM   #15005
FlyGuy
MachineHead
FlyGuy's Avatar
Oddometer: 165
Likeing the EBC clutch kit
So a few pictures to see what I like
I got the dirt racer Clutch kit. It comes with springs/ fibers and steels
106 bucks at MCSS
The fibers are in oil, I used the package as the bath tub
the springs are suposidly 15% heavier
EBC says
15% uprated heavy duty clutch springs to clamp those plates together firm and strong for the life of your clutch
the steels are different than stock and you can see how.
EBC says
Pin planished steel driven plates that spread the oil around the clutch better and prevent clutch burn-up THEN EVEN MORE………
On the fibers they are a cork based formula with aluninum bits in the mix
EBC says
EBC unique alloy article impregnated clutch facings that wear longer and resists burning PLUS…….
You can see the alloy particles in the picture
this clutch is working better than the stock set up on my application but is a heavier pull on the lever, I am pleased with the preformance and price
Time will tell but so far it hooks up where the stocker would slip
FlyGuy screwed with this post 10-23-2012 at 02:28 PM
FlyGuy is offline   Reply With Quote
Old 10-23-2012, 08:13 AM   #15006
walkergreenlabel
Oddometer: 200
sorry its not diameter I was looking for width of the outside edge to outside edge width of the DID rim. I need to sleep...
Old 10-24-2012, 04:34 PM   #15007
sintax
Oddometer: 495
Anyone tried the Mishimoto Silicone hose kits?
I'm planning on ordering up some Fluidynes and figured I might as well swap the hoses out too.
sintax is offline   Reply With Quote
Old 10-24-2012, 04:35 PM   #15008
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Any interest in carb adapters for the newer-style FCR MX carbs? I used one of Noss' universal FCR adapters on my 650R with a 39mm FCR off a late-model CRF450 and it ripped, but the adapter dimensions weren't quite right. So we're going to have them make some custom adapters for the XR650R and the XR650L. I don't have a 650R anymore, but my buddy James wants one and I need to have some 650L adapters made for these bikes. Figured we might as well make them available. His regular universal adapters cost $65, so am guessing these will probably be a little bit more expensive, but can't imagine they'll end up costing any more than $80. It's pretty easy to find good deals on used FCR MX carbs ($300?) because there are so many of them out there (being used on virtually all of the modern 450cc motorcross bikes). So this can be a relatively low-cost upgrade, and the performance is flat-out awesome. Fitment is pretty straightforward, and you do not have to modify the gas tank in order to clear the carb if you just install it a few degrees off vertical. So this is literally a bolt-in deal, and you can use the FCR throttle cables and twist-grip (stock CRF cables are perfect length with aftermarket tripleclamps and taller bars). Shoot me a PM if you want one!
jesusgatos is offline   Reply With Quote
Old 10-24-2012, 05:10 PM   #15009
nick5446
Oddometer: 71
I run them with Fluidynes as well...no issues to speak of. Been about 5k miles, 80% street. Took them off recently when I had my engine out for rebuild and didn't see any damage or anything.
nick5446 is offline   Reply With Quote
Old 10-25-2012, 04:45 PM   #15010
ride4fun562
ride4fun562's Avatar
Oddometer: 207
I saw an add on craigslist from some guy offering to pay people to teach him to start his xr.
ride4fun562 is offline   Reply With Quote
Old 10-25-2012, 05:57 PM   #15011
sintax
Oddometer: 495
i've come to terms with the fact that if it does not start easily something is wrong with it mechanically.
I'm blown away with how easy mine starts once all the pieces are put together right, and are dialed.
Old 10-26-2012, 10:31 AM   #15012
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 471
Not funny , if you dont know the correct technique and never seen or owned big single its quite hard to start them .
It took me 2 days to learn how to start mine , and now i find it dead easy , dont even use much force it starts so easy , ( yes i have never seen decompressor before)
Feel sorry for the lad , his leg will be in serious pain .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 10-26-2012, 08:49 PM   #15013
StroupDog
Shut-it Beotch
StroupDog's Avatar
Oddometer: 196
Originally Posted by Kiko View Post
Nice work,
but don't forget to fix the R footpeg.
Yes nice find Rob, Alllllsooooooo the BRP suffers from a floppy rear fender syndrome and loves to eat plates, especially with all the extra weight you've just added; get a sub-frame extender that bolts to the subframe and sits underneath the fender.; Trust me on this. I have this one and it works just fine, the one JesusGatos is/was/might make looks good but looks like overkill to me.
Bend>Cedarville>dirt>600miles>2 days
Mini-GiantLoop-09 RR
Jims BigAss road trip
"Living life one day at a time".
StroupDog is offline   Reply With Quote
Old 10-26-2012, 09:51 PM   #15014
RZRob
RZRob's Avatar
Oddometer: 1,571
Just went online and I think you're directing this to me. I did notice the stock set-up, with the added weight of the plate was a tad floppy. I'll be looking for that now. I may have to womp her again tomorrow though.
Thanks folks,
RZ Rob
RZRob is offline   Reply With Quote
Old 10-27-2012, 12:02 AM   #15015
RalphyDo
Oddometer: 308
Thanks folks,
RZ Rob
My stock rear fender cracked after installing the BD D/S plate/tail light thingie to it. It flexed alot! I have since installed a UFO fender which is much strong/thicker. It still bounzes but nothing like the stock one did.
Times are GMT -7.   It's 12:27 AM.
