Old 10-27-2012, 07:46 AM   #15016
slogger
Oddometer: 654
Manracks(he's a member on ADV) makes the best fender support I've found. I've broken 6-7 of the type you showed. Manracks uses the same design but added a couple tweaks for added strength.
Originally Posted by RZRob View Post
Just went online and I think you're directing this to me. I did notice the stock set-up, with the added weight of the plate was a tad floppy. I'll be looking for that now. I may have to womp her again tomorrow though.
Thanks folks,
RZ Rob
slogger is offline   Reply With Quote
Old 10-27-2012, 08:49 AM   #15017
Dread Pendragon
throttle to the donk
Dread Pendragon's Avatar
Oddometer: 2,547
Originally Posted by sintax View Post
i've come to terms with the fact that if it does not start easily something is wrong with it mechanically.
I'm blown away with how easy mine starts once all the pieces are put together right, and are dialed.
+1
"Never get excited in a rally, its a race, but its never a race at that exact moment" -Quinn Cody
Dread Pendragon is offline   Reply With Quote
Old 10-27-2012, 09:08 AM   #15018
RZRob
RZRob's Avatar
Oddometer: 1,693
He's da Man
. Yep, my first source. He's beefed my XRL up and has a great support for the XRR at a great price for inmates. I've already got my PM in to him.
RZ Rob
RZRob is offline   Reply With Quote
Old 10-27-2012, 04:23 PM   #15019
RdrMtn
RdrMtn's Avatar
Oddometer: 159
Question rear axle play
I have noticed a bit play between the ID of the brake side rear wheel bearing and the OD of the axle. The bearing rolls smooth with no play and seems to be in good shape. They are pivot works bearings a couple of seasons old. Anybody else have this? It's not severe and has not got worse in the last 250 miles since I first noticed. I was going to replace the bearing today but that doesn't seem like the problem. Can the axle wear out?
RdrMtn is offline   Reply With Quote
Old 10-28-2012, 06:00 PM   #15020
szramer
szramer's Avatar
Oddometer: 273
anybody is doing bolt on fan for BRP?
szramer is offline   Reply With Quote
Old 10-28-2012, 06:07 PM   #15021
bamfslap
Oddometer: 205
KTM
Might need some mods though.
bamfslap is offline   Reply With Quote
Old 10-28-2012, 08:16 PM   #15022
sintax
Oddometer: 495
Originally Posted by tomaszb2 View Post
Hi! :)
My name is Tom, I live in Poland and I am owner of BRP. I use the HS40 Mikuni carburetor. Does anyone have more information about this carburetor than the link?
http://www.zodiac.nl/instructions/234862.pdf
I know this is a simple carb but want to know more about him.
Thanks in advance for any information about this carburetor and greet.:)
Hey Tom.
What type of information would you like to know? There are lot of people here that use the HS/TM 40 carb.
I am currently working through the jetting process with mine. I have some jets showing up next week to continue to fine tune it.
sintax is offline   Reply With Quote
Old 10-28-2012, 09:24 PM   #15023
lukeinlondon
lukeinlondon's Avatar
Oddometer: 431
Hi. Found a 650R which looks nice. Except it isn't platted and doesn't have the lights setup. Can anyone tell me how much work and $ it's going to cost me to legalize over here in CA?
lukeinlondon is offline   Reply With Quote
Old 10-28-2012, 09:52 PM   #15024
Desert Scoundrel
Oddometer: 131
You'll never be able to get it plated in CA. You'd have to buy one that is already plated.
Desert Scoundrel is offline   Reply With Quote
Old 10-28-2012, 10:00 PM   #15025
sintax
Oddometer: 495
That is the official stance. You can sometimes sneak them by, but there is a good chance the plate may get pulled. That whole deadline in 2002 is why plated dirtbikes carry such a high value here in CA.
Maybe register it in AZ or NV?
You are looking at about $350 for a decent dualsport kit, something like Baja Designs. It should have all the gear you need to get it solid, except the mirrors.
Old 10-28-2012, 10:13 PM   #15026
Desert Scoundrel
Oddometer: 131
Does anyone make an externally adjustable main jet for the stock carb?
Old 10-28-2012, 10:14 PM   #15027
Desert Scoundrel
Oddometer: 131
I know UT and CO are the easiest. Never tried Nevada since I didnt live there or know anyone who did.
Old 10-28-2012, 10:31 PM   #15028
Desert Scoundrel
Oddometer: 131
Another question: Is there any real difference in billet clutch baskets between brands? There is the Hinson, Barnett, Wiseco and a few others. Not a huge difference in price amongst the batch.
Old 10-29-2012, 04:37 AM   #15029
Slim86
Slim86's Avatar
Oddometer: 18
Eek Head gasket?
Has anyone ever blown a head gasket on their BRP? Toll mine on the trails a couple weeks ago, laid it over a couple times, later while cruising along the trail an antifreeze bomb goes off between my legs. Had the radiators pressure checked and they came back good. Can't see any obvious clues on any of the hoses that would warrant a big and sudden leak like that. Wondering if anyone has had this happen to them or have any ideas about it. Thanks.
Slim86 is offline   Reply With Quote
Old 10-29-2012, 09:02 AM   #15030
Dread Pendragon
Oddometer: 2,547
My brother had his XR650R plated in AZ, and he didn't need turn signals for it. In fact I don't think it even had a brake light. He lives in UT now and has to put on a dual sport kit to get it plated here. (I think he's going to go with a cheap one from rockymountainatvmc.com )
Times are GMT -7.   It's 11:09 PM.
