Old 09-10-2009, 01:00 PM   #1501
JustinT OP
I will ride my whole life
JustinT's Avatar
Oddometer: 955
Originally Posted by chip
So I'm riding yesterday and start heading home right before dark. I notice my front light isn't working. So I pull over and pull the light off, the bulb actually broke inside the headlight housing. It's one of those cheapo 35/35 bulbs that looks like a big christmas light. Can I upgrade that bulb with anything better on the stock stator and same bulb connector?
You can get better wattage bulbs all over but I'm not sure how hot is too hot with the plastic housing. Baja Designs has a glass housing. When the bike is yours....Rewind the stator yourself. its easy and for just the cost of the wire and a better regulator you can have a 100W bulb!
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 09-10-2009, 01:57 PM   #1502
Loy
Oddometer: 2
Hello! First post here!
This winter I'm going to upgrade my Xr a bit. I already got Arrow full system and a TM42. But what do you guys think off adding a hotcams stage 1 (can get a good deal at this) and a high-comp piston, 11:1 or 12:1.
Will it be good?
Edit: A pic of the ride, from this summer :)
http://pici.se/469562/?size=medium
Loy screwed with this post 09-10-2009 at 02:04 PM
Loy is offline   Reply With Quote
Old 09-10-2009, 07:18 PM   #1503
Dave JP
BRP Rider
Dave JP's Avatar
Oddometer: 372
Headlight
The OEM XR650R headlight upgrade should be:
Mfg Product Number: 33123-MK2-671
This is a direct replacement with a glass lens, and a 55W bulb works well in it (compared to stock). I think they are ~$35.00.
It even works significantly better than the 50W bulb mod in the original plastic headlight.
Dave
Dave JP is offline   Reply With Quote
Old 09-11-2009, 09:06 AM   #1504
zaptoad
just a guy
zaptoad's Avatar
Oddometer: 302
headlight housing here
http://www.ronayers.com/browseparts....=33123-MK2-671
this is just one option......
zaptoad is offline   Reply With Quote
Old 09-11-2009, 10:58 AM   #1505
chip
Follow Me
Oddometer: 1,763
I was planning on either rewinding or buying the upgraded stator. If I could put in the other type of plug or connector to run, say a PIIA light, that would be cool.
Yeah, the bike has to be mine first. Still no interest in collecting cash. Money hasn't been transferred yet, so it kinda works out.
chip is offline   Reply With Quote
Old 09-11-2009, 01:11 PM   #1506
Not for Highway Use
Wannabe hasbeen
Not for Highway Use's Avatar
Oddometer: 1,010
Speaking of lights. Is there any way I can check the bikes power system without starting the engine? That is, can I plug a battery into the loom somewhere to get 12V running through it?
I want to do some headlight stuff (no lowbeam) but I don't want to let the bike just sit there gurgling away while I get my shit together. It's spring here in Australia and stating to warm up.
Cheers,
Andrew
DL650, DRZ400,CRF250X, PW80
Legend in my own Control Panel
Not for Highway Use is offline   Reply With Quote
Old 09-11-2009, 01:15 PM   #1507
Not for Highway Use
Wannabe hasbeen
Oddometer: 1,010
Originally Posted by modette
I was responding to your chain slider, you got to look under the swing arm section. It is $31.42 I believe, so if I am right you knock off 40%.
Hi Modette,
Where did you get the parts diagram? I had a website that had all makes and models but the 'puter got rid of my bookmarks so I lost it.
Cheers,
Andrew
Old 09-11-2009, 01:25 PM   #1508
JustinT OP
JustinT's Avatar
Oddometer: 955
Cheers,
Andrew
Could you just use a battery or another 12v source and use alligator clips and power just want you needed power to so you don't have it going through the whole system? Maye a 12v source AFTER the regultor. but I'd disconnect any expensive electrical parts you aren't checking like CDI and coil?
Hi Modette,
Cheers,
Andrew
Most online sites that sell OEM parts have Microfiche. I use Ronayers and service honda but bike bandit also has searchable parts diagrams.
Old 09-11-2009, 07:05 PM   #1509
Not for Highway Use
Wannabe hasbeen
Oddometer: 1,010
Thanks for the info. You ARE the King
Old 09-11-2009, 07:18 PM   #1510
JustinT OP
JustinT's Avatar
Oddometer: 955
Thanks but, not me!
Old 09-11-2009, 08:33 PM   #1511
the_hulkamaniac
the_hulkamaniac's Avatar
Oddometer: 79
For anyone looking to put a fcr carb on there pig check the link just gathering interest.
http://www.thumpertalk.com/forum/forumdisplay.php?f=22
the_hulkamaniac is offline   Reply With Quote
Old 09-13-2009, 07:35 AM   #1512
BRPRider22
Big Red Pig-FoxHondaRider
BRPRider22's Avatar
Oddometer: 27
Does anyone have a stock exhaust they want to give up for the XR650R?
2001 Honda XR650R Dual-Sport BRP(Big Red Pig)
BRPRider22 is offline   Reply With Quote
Old 09-13-2009, 08:10 AM   #1513
header
Chris
header's Avatar
Oddometer: 1,746
ebay dude, they're always on there and only run about 50 bucks.
header is offline   Reply With Quote
Old 09-13-2009, 03:41 PM   #1514
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
have you guys seen this video? halfway threw when hes in the water is the best!
http://www.youtube.com/watch?v=vKcEQ...eature=related
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is offline   Reply With Quote
Old 09-13-2009, 06:43 PM   #1515
chip
Follow Me
Oddometer: 1,763
Nice video
My eyes hurt now.
Just finished an incredible ride in central California today. One of the best I've ever had. However, Busted my right radiator, broke the shroud, i think that's about it right now. But during the clean up I found this:
Does anyone else have a little hole like that on top of their engine?
Times are GMT -7.   It's 05:53 AM.
