11-17-2012, 11:13 PM
#15256 | |
Oddometer: 308
Nope, never seen any plastic ones, ever Negative, Honda never made frame guards for the XRR, neither plastic nor any other material. |
11-18-2012, 09:23 AM
#15257 | |
Oddometer: 248
Cheers guys Babuja ________ KTM 950 ADV www.babuja.smugmug.com http://www.nomadstrail.net/site/ |
11-18-2012, 10:31 AM
#15258 |
Oddometer: 19
Oops(damnit!)
So I changed the front sprocket this morning on my XRR. While I was adjusting the left rear axle adjuster it decided to snap clean off inside the swing arm. Now instead of going a nice dirt ride I'm heading to the parts store to a) try to find a replacement bolt and b) buy a couple of new drill bits and an easy out. Damnit!
11-18-2012, 10:47 AM
#15259 |
Big Nasty
Oddometer: 502
I would not easy out they break in this small of a size. then it is really a pain. just drill it out and tap new. if you do try the ez out get a can of that air spray (like for a key board) flip the can up side down and freeze the bolt once you are ready to use the ez out have the hole drilled and ready to go. maybe that will work. if the ez out breaks you will need to chip it out good luck. then drill it out. B
Dr350, XR650R Dual Sport,XR600R,KTM ADV990R |
11-18-2012, 11:09 AM
#15260 |
fishing with dynamite
Oddometer: 2,034
Drill it out larger and insert heli-coils.
11-18-2012, 12:03 PM
#15261 | |
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 236
good things them hondas |
11-18-2012, 01:26 PM
#15262 | |
Oddometer: 17
Look in to just drilling out and re-tapping for a KTM 525 adjuster bolt. It is a little bigger than the Honda. My buddy did this to his 650R and has put on 1000s of mile with out any issues. You may want to drill and tap a small hole on the bottom of the swing arm so you can spray some lube on the inside of the bolt and to also drain out any water that may become trapped in the swing arm. I did this and I just capped off the hole with a SS flat head allen bolt. Just my .02 Good luck |
11-18-2012, 02:59 PM
#15263 |
idiot dirt rider
Oddometer: 1,917
normal R oil consumption
Mine used about 500 ml of oil during yesterday's ride. A 150 mile mix of desert two track, some high speed deep sand, 50 to 60 mph cruising and one 2nd gear low side in the rocks (crap!).
I know that the R is known to burn some but this seems high. Thanks to those who have posted the starting technique tips. Following the procedure mine starts within a few kicks every time. -dod
This is my only chance to assemble a disreputable past |
11-18-2012, 03:20 PM
#15264 | |
Oddometer: 308
What oil and what weight are you running? |
11-18-2012, 04:22 PM
#15265 |
idiot dirt rider
Oddometer: 1,917
Honda HP4 syn blend 10w-40
-dod
11-18-2012, 04:49 PM
#15266 |
Oddometer: 308
Dump the syn-blend and go conventional. Swap to Rotella T 10w40. Almost guarantee that the oil consumption with all but disappear. Give it a try, you have nothing to loss. If that doesn't cure it then you need to look into doing a top end. 500ml in 150 miles is not very good at all. |
11-19-2012, 10:16 AM
#15267 | |
Oddometer: 102
11-19-2012, 10:31 AM
#15268 |
Oddometer: 248
I would like to select a XR 650R fuel filter for stock carbs but would like to confirm maximum flow rate...anyone could help?
11-19-2012, 11:30 AM
#15269 |
Oddometer: 2,034
All of our 650R's consumed oil. Even brand new ones.
11-19-2012, 11:43 AM
#15270 | |
AKA DoctorXRR
Oddometer: 645
Rear Axel Adj Fix
The chain adjusting bolts snapped off in the swingarm, due to corrosion on the threads. All I can say is thank goodness for the SwingArm Buddy! The most difficult (and most important) part of the procedure is drilling out the broken bolts. You have to work your way up to with two smaller diameter drill bits before using the 3/8" bit provided in the kit. At least one of the smaller bits needs to be extra-long, otherwise your it will not clear the swingarm and you will drill crooked. Also critical, is making a very deep center punch mark - in the center of the broken bolt. I hit the center punch several times to be sure to get a deep punch mark. The finished 3/8" hole must be centered in the swingarm... not a procedure for the squeamish! The kit makes a very solid repair and I applied anti-seize to the new adjusting bolts. The only down-side to the kit, is the new bolts are 5/16" american, which means you have to use a 1/2 wrench to adjust your chain, which may mean having to pack an extra wrench in your tool kit, although you might still get away with using a 13mm metric. The steel insert is slightly over-sized compared to the 3/8" drill bit, so it is a good press fit into the swingarm. ![]() ![]() ![]()
