Old 12-12-2012, 11:10 AM   #15511
Unsung
Oddometer: 60
Originally Posted by larryboy View Post
Yep, when you take the nut off the center comes off by hand and you're left with this:
Thank you larryboy, and thank you sweet baby Jesus. Less work = more riding time.
Unsung is offline   Reply With Quote
Old 12-12-2012, 11:40 AM   #15512
Mur
Wheee!
Mur's Avatar
Oddometer: 21
Tire Age?
I just bought a 2000 XR650R, and I think it has the original front tire on it....
Anywho, does anyone know how to tell how old it is? The only numbers I could find are:
R2052,
EU X519,
5857.
And the 5857 is right before the dimensions 80/100-21 51M It's a Dunlop D739FA If that helps....
The other tire is a POS Chen Shing (Obviously not the original) and the number it has on it is 13082 6648 .
I'm replacing both of these, and was curious of the age of the tires. I think it might help to tell me the mileage of the bike..
TIA!
Mur screwed with this post 12-12-2012 at 11:46 AM
Mur is offline   Reply With Quote
Old 12-12-2012, 12:09 PM   #15513
Shibby!
Oddometer: 1,665
It's made in 2052.
It's a pig from the future.
Now go ride it.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 12-12-2012, 12:19 PM   #15514
Mur
Wheee!
Mur's Avatar
Oddometer: 21
Originally Posted by Shibby! View Post
It's made in 2052.
Now go ride it.
I think your'e right, but it looks like the bastard before me took the flux capacitor out.
Old 12-12-2012, 01:02 PM   #15515
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
Originally Posted by AirCommando View Post
XR650X AVrider's,
I need some help deciding the best way to scratch my dirt bike itch. I currently ride a BMW R1200GSA. Great bike but it is pretty expensive and emotional to scratch and break so I am looking for something better suited for the mountains and desert of Arizona. I have narrowed it down to either the XR650R or CRF450X. At the age of 44 I will not be doing flips on either one. Either will be an earlier version '00-'07 set up with large capacity fuel tank. I understand the weigh vs power trade offs. Is one more maintenance intensive then the other? Is one cheaper to farkle-out with aftermarket's? Any thoughts is appreciated. Thanks for your inputs.
Well, I went from a GSA to a drz to an xrr to a crf. The xrr was definately a hoot to ride. Wide open stretches were great, and even some of the technical stuff wasn't a problem. Where I lost patience was really my own fault, but when the bike went down it flooded. Now you've gotta clear it before the starting hokey pokey. Around 6-8 kicks to clear it, then the just past tdc, then swift kick. Hopefully, it starts first kick, otherwise, you're doing the hokey pokey thing again. I really like my lighter crf with the magic button. But at times, I miss the xrr. Not usually, though!
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 12-12-2012, 01:34 PM   #15516
pigpen
Gone Riding
pigpen's Avatar
Oddometer: 761
1200 vs xrr vs crf
XR650X AVrider's,
I rode an 1150GSA for a long time, Bought an XR650R, and I ride a CRF450R in the trails and ohv areas! The GSA is gone and all I ride on the road is the XR. I just always got on the XR vs the 1150 as it was way more fun, I owned them both for about 4 years. Always rode the XR unless it was a road trip. That being said I have ridden the GSA on the CDT and OBDR and throughout The western US mainly off-road, until got the XR. You can remedy the fall, drop , and restart procedure by purchasing and installing a pumper carb, TM40. Problem solved. The CRF is a great machine, but maintenance and light weight leads it to an substandard adv bike unless very technical trails and short trips are the norm for you. The XR has some shortcomings, kickstart and weak subframe, but I like both shortcomings. Let me explain; I can always start my bike, it has never failed me, no real battery just a dirt bike! The subframe leads me to pack carefully and light! The riding is always better with light weight bags and equipment! My CR450R is and R and I really like it for it's intended purpose, as it is not an X it is a tad different but I would not want to ride the street for an extended time on the 450 in either version! The XR can be a very capable ADV and DS bike once your have done some basic mods!
PIGPEN
Ride more, write less, work when !!!
Having fun is not a sport! It's a full time job for some of us!
pigpen is offline   Reply With Quote
Old 12-12-2012, 02:33 PM   #15517
tennessee thumper
now in Mt. View, AR
tennessee thumper's Avatar
Oddometer: 739
Repair, replace or ignore
One of the 4 axle pinch bolts welded to the RH fork leg snapped off.
Has this happened to anyone?
Did you repair, replace or ignore?
I just finished a good run around Terlingua, TX and Big Bend with it like this and no issues.
I
tennessee thumper is offline   Reply With Quote
Old 12-12-2012, 03:33 PM   #15518
bump
COLOR ME GONE
bump's Avatar
Oddometer: 713
Really?
Perhaps you are thinking of the L instead of the R because Honda lists the current CRF450X at 269 pounds and I think the XR650R was listed at 277 with most magazines saying the XRR weight was 280ish. The L though is usually listed about 350 so that would be a huge difference. If one is comparing the 650L to the 450X then it's not a fair comparison IMHO.
I would say the two bikes have three major differences: Ergos, power characteristics, and maintenance.
The CRF feels much newer and slimmer. If you are an average sized guy then the CRF will feel better most likely. If you are a bigger guy then the XRR will likely feel better.
The XRR has more power and more fun power. The power is down low and in the mid where it is usable. Adding parts to create the Bob Bell engine make it giant fun to ride. You could ride about anything in 3rd gear if you wanted. Naturally, the 450 is at a disadvantage here against the XRR's 50% more cubes. The XRR will feel (seat) and look (plastic) just a tad old school. That said, the sort of riding you plan to do may be the best indicator of which bike is best. The 650 is simply a bike that requires little maintenance and if you run OEM filters and do basic maintenance like valves then I think the engine could easily go 50,000 miles and I'd reckon that is several times more than the CRF will go. Bob Bell told me that they really didn't need to take apart the 650 after any of the races including the 1000 and they only did it because they had Honda in charge. He said that engine would easily race all the events they could enter without a problem.
If you buy the CRF you must install the stainless valves but not much more to have a great bike.
The big XRR is very rideable stock IMHO but for less than a grand you can recreate the 1X engine.
I'd guess that if a license plate is valuable to you then you will find more XRRs plated than CRF450Xs. Also, know that the 2009-2012 CRF450X/R were considered a bad chassis. I think Honda still races the '07 chassis.
I think a better companion bike or comparison bike to the XR650R is the current KX450. I'd get the MX bike and change the gearing. I'd recreate the bike THR is using in the 1000 currently. Last month I drive Phil and Ryan down to Ensenada to drop off the THR 8X bike at the hotel before the 1000. We had alot of time and we talked about the differences between the Honda 1X XR650R that won everything for many years which Bob Bell developed, the current Honda 450 that JCR races which was developed by Bob Bell before Ogilvie died, and the current KX450 THR races also developed by Bob Bell. One thing is clear every time I talk with real racers (of which I am NOT) and that is that less weight is nearly always better in every way.
Also depends on your budget... I've seen very clean stock XR650Rs for $1500 lately. I bought one that was little used for $600 recently complete, running, and with a few accessories. So for $5K you can have a decent 450X, a full on 1X XR650R with cash left over, or part of a Precision Concepts KX450.
If you are looking for a dirt only bike and want the most fun then a newish Yamaha YZ250 is impossible to beat. They are very light, have great power, have better suspension stock than any other motorcycle in the world, are almost free to maintain, have lots of aftermarket parts like 150 watt stators ( a guy in Washington State is making them now), large gas tanks and weigh 60lbs less than any 450, are a third the weight of what these hugely stupid European fire road sleds weigh, and will make you a much better rider on any Sunday because of the light weight. I think the 2011 YZ250 are 211lbs!
If you choose the Honda 450 then here is a useful article: http://powersports.honda.com/experie...080a4a0dd.aspx
Congrats on avoiding the GSTurds and going for a real dirt bike instead of the pencil protector version of women driving Mercedes SUV/Minivans in Beverly Hills. Not that there is anything wrong with that.
Originally Posted by BigToad View Post
The XR will be less maintenance but will weigh like 55 lbs more. There will definitely be more farkles available for the CRF as they haven't made the XR since 07. Personally any farkle that adds weight to me is not a good investment for an offroad bike unless it makes it safer like a steering stabilizer...
Since I bought the XR I have barely ridden the GSA, its a fantastic bike with a cult like following, damn near bomb proof...and what like 8 Baja 1000 wins to its credit... Buy it, set it up right, and you will never regret it.......
bump screwed with this post 12-12-2012 at 03:47 PM
bump is offline   Reply With Quote
Old 12-12-2012, 04:32 PM   #15519
Singletrack Gardener
Singletrack Gardener's Avatar
Oddometer: 52
I
Funny, I just did this the other week. I ran it for a while, I have done it before on my 2T and ran it for a while mainly due to laziness. They are not welded on, hopefully you can get some vise grips around what is left of the stud and pull it out. It's like a $2 part so just replace it instead of constantly having to worry about it on the trail.
I believe the proper torque is 8 ft-lbs. I was just too lazy to bust out the torque wrench and figured I could tell by hand. Was I wrong
Singletrack Gardener is offline   Reply With Quote
Old 12-12-2012, 05:36 PM   #15520
seasider
Just a rider
seasider's Avatar
Oddometer: 403
Ah HAh! Now I know the truth!!! Don.... hope the the crf is treating you well but I see you still hang around the BRP boys
Could not stand to be without the beast and went and bought another one. I'm back on a BRP with a Big Ass Smile! Hope all is well buddy.
Lost time is never found
seasider is offline   Reply With Quote
Old 12-12-2012, 05:57 PM   #15521
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
: ) nice! i was wondering about the sale... i thought you loved that bike. they are a frickin' hoot to ride, aren't they? and that one had the precision concepts suspension that i just loved.
yes, the crf is still treating me well. so far, it's the overall best off road bike for me that i've had.
Old 12-12-2012, 07:21 PM   #15522
AirCommando
AirCommando's Avatar
Oddometer: 44
Design changes in the XRR from '00-'07
When shopping for an XRR, are there any design changes that occurred between '00 and '07 that I should be aware of in considering an older or newer XRR?
Thanks for your time.
RJ Nelson
'09 R1200GSA
AirCommando is offline   Reply With Quote
Old 12-12-2012, 07:43 PM   #15523
pavemike
I fall down alot
pavemike's Avatar
Oddometer: 343
Updated clutch bushing in 2001, and BNG!
SOMB!!!!
pavemike is offline   Reply With Quote
Old 12-12-2012, 09:36 PM   #15524
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
Doesn't matter what year you get, they are all good. You should replace the clutch bushing when you buy a BRP anyways. The updated bushings are cheap.
Capt. Egregious is offline   Reply With Quote
Old 12-12-2012, 09:47 PM   #15525
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
I feel enlightened after having read that. A YZ250.... Hmmmm
Jayrod1318 is online now   Reply With Quote
Times are GMT -7.   It's 01:45 PM.
