01-29-2013, 01:40 PM
#15886 |
aka Birdkilla
Oddometer: 2,408
The extra-large tanks like the Acerbis 6-gal do provide an excellent amount of radiator protection from sideways tip-overs. I never have noticed the sloshing of the fuel with half-empty tanks, and you don't HAVE to fill them up all the way for those shorter sections....But you WILL notice the difference in suspension when the tank is full.
Cpt. Ron Sack-O-Tomato, CA '05.5 950 Adventure S "Bad Mutha F@&ker" '04 R1150RTP "cop motor, cop suspension.." '00 XR650R Dual Sport "Lil' Mule" '75 RL250 '01 TTR90 '01 PW50 Conti TKC80 tire swing "I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P. "Without the possibility of death, adventure is not possible"--Reinhold Messner |
01-29-2013, 02:39 PM
#15887 | |
Oddometer: 1,422
I'd sooner ride my 6.3 full than my 4.3 full. That says a lot. My suspension is revalved and resprung though. I'm 200ish without gear. I could stand to have a bit firmer springs both front and rear when loaded down. Problem is I do a varying degree of riding from trail days with no load to full on trip with 70lbs of gear.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
01-29-2013, 07:17 PM
#15888 |
Kicker Brother
Oddometer: 3,120
6.3 is nothin .......mine holds that then i add bladder bags for a total of 12 gal
bladders hang over the side of the tank ...now thats some weight ....suspension is workin over time when fully loaded ...but i dont motorcroos the bike when she's got full weight on on another front ..we are making some steal rear subframes ..made out of box steal ...better that globtotting subframes ..as we keep them box section same as stock and add gussets to give more strength .... we test them out very soon ![]() we need to carry 12 gl of fuel and 3 gal of water for our desert trip later this yr |
01-29-2013, 09:06 PM
#15889 |
Oddometer: 81
What kind of range can be had out of the 4.6? 6.3?
Sent from my SCH-I535 using Tapatalk 2 |
01-30-2013, 01:18 AM
#15890 | |
Red Rider
![]() On the actual design of the subframe, I saw an article somewhere where the standard frame was re-inforced with huge success. The engineer that did it had a whole technical document on forces at play, that drove out the final design. If I recall correctly, the issue is not the strength of the subframe, but the way the lower attachement location is not balanced, giving rise to tortional forces. I'll try and find it. 12 Gallon = 45 litres. I had to carry 55 litres, and having some of the fuel at the back is the way to go. I carried the 30+ litres at the back, with the standard frame, and had no issue. I have my toolbox upfront and low (on the skidplate) Tools, weight per volume is a lot more than fluid, so you can balance the bike front to back easily, without having huge volume in the front that gets in the way once the riding gets technical, imho. Keep us posted on the frame though, I would be very interested in the final design and design considerations. |
01-30-2013, 01:49 AM
#15891 |
Kicker Brother
Oddometer: 3,120
yes its steel ....hahaha ..um yes we have talked about the mount issue ....keeping the stock shape i think we have come up with a solution ....
we dont tecnical stuff ... more wide open around here ... sand tracks ....it dont take long to go threw 30 ltrs ....with the tank bra and bladders on the side of the tank its well balanced ...gear at the back ...water onboard at the rear ..keeps the weight even theres a few pics and talk on the aussie subforum xr650r owners about the steel subs |
01-30-2013, 02:26 AM
#15892 |
Red Rider
01-30-2013, 03:21 AM
#15893 |
Kicker Brother
Oddometer: 3,120
01-30-2013, 11:21 AM
#15894 | |
Oddometer: 1,422
My stock carb and 4.3 had me around 200-220 KM I think. My 6.3 with TM-40 I can almost always do 400KM, often a lot more. I bet if I had to on a gravel or paved road I could do over 500KM. I've never pushed it though. I've done low 400KM a few times. There has only been once I've hit reserve at 380KM, and that was in Baja, all deep sand roads and roosting around corners. I get around 50-52 MPG with the TM-40 and 70lbs of gear. For those wondering, 1.6KM / Mile. If you ride WTF out there, having a tank with lots of gas is a GREAT feeling. I've been in some VERY remote places and knowing my tank is half full still always brings comfort.
01-30-2013, 11:51 AM
#15896 |
Kicker Brother
Oddometer: 3,120
14 days .. you cant carry enough stuff
01-30-2013, 11:55 AM
#15897 |
Oddometer: 1,422
Haha. I can't say I share the same way of thought... I had less stuff with living off my bike for 4 months... Provided I didn't have to bring food or cooking gear. I think we covered this before, but always fun to bring it up again. ahha. In my opinion, lighter = better. Not only easier to ride, more simple, quicker pack-ups, etc. I know you aussies like your massive sleeping mats / tents, but you should really see about a Thermorest or similar pad. If you don't need thermal properties, there are ones that weigh very, very little. The ProLite + which is my other matt weighs quite a bit more but much, much warmer. What I brought on my trip was awesome for size, but too cold. Even here in the summer I feel chill using it, often resorting to my Pro-lite Plus for better sleeps.
01-30-2013, 12:51 PM
#15898 |
Kicker Brother
Oddometer: 3,120
its hard to xplain .....the swag on the back has my clothes and all sleeping stuff
its now been retired off the bike ...am going to tent from now on ..i have a exped mat was in my swag on that trip we had way diffent temps over the 14 days from freezeing cold to hot the bladders sit up front there a must ..we have big distance with low fuel options the bags on the side 1 held food and 1 held spares and nick knacks ..all up the gear is light just the swag makes it look heavy running the CSR this yr for 4 weeks ......gear is getting cut down as its all tuff sand .....bladders will still be there but going a giantloop tent and exped and sleeping bag ....4 xrr's in the desert makes it easy for us to spread the tools and spares between bikes ... gunna take 1 set of clothes and throw them away each week and buy new stuff where i can 60 ltrs fuel on board and 10 ltrs of water ...hard going in desert |
01-30-2013, 01:16 PM
#15899 |
Oddometer: 81
What kind of reserve range are you seeing with the 6.3?
01-30-2013, 01:48 PM
#15900 |
Oddometer: 322
[QUOTE=Sean-0;20611514]its hard to xplain .....the swag on the back has my clothes and all sleeping stuff
its now been retired off the bike ...am going to tent from now on ..i have a exped mat was in my swag on that trip we had way diffent temps over the 14 days from freezeing cold to hot the bladders sit up front there a must ..we have big distance with low fuel options the bags on the side 1 held food and 1 held spares and nick knacks ..all up the gear is light just the swag makes it look heavy running the CSR this yr for 4 weeks ......gear is getting cut down as its all tuff sand .....bladders will still be there but going a giantloop tent and exped and sleeping bag ....4 xrr's in the desert makes it easy for us to spread the tools and spares between bikes ... gunna take 1 set of clothes and throw them away each week and buy new stuff where i can 60 ltrs fuel on board and 10 ltrs of water ...hard going in desert Sean-O Guess you must have a portable shower packed in there somewhere as well. ![]() Enjoy the trip! JM |
