Old 02-02-2013, 09:56 AM   #15916
Kiko
Kiko's Avatar
Oddometer: 1,856
Originally Posted by AirCommando View Post
I just purchased a used MIKUNI TM40 and was hoping to get some inmate info on initial settings.
My XRR is uncorked with factory exhausted. Factory air cover. Here in Tucson my play area is 2000'-6000' and 80-100 degrees.
Looking for MJ #, PJ # and needle positions.
Thank you.
1.2 air jet, 25 pj, 140 mj, and clip 4 down (with washer under clip) on the needle works for me. A lot will depend though on how the exhaust tip was modified when the bike was uncorked, You'll be lucky if you get it tuned right quick, mine is real finicky. You may need to tweak the AP adjustment with a small gap in case you get a bog when you whack the throttle. Good luck.
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 02-02-2013, 11:06 AM   #15917
KYLEISCOOL
Who
KYLEISCOOL's Avatar
Oddometer: 144
Originally Posted by bamfslap View Post
Hell yeah! Nice to see someone else jump the pig. Though I haven't done any fancy tricks yet (unless you count and accidental super man).
As long as you looked good doing it Thanks AJ.
Gotta ride something! 02' XR650R slightly personalized
KYLEISCOOL is offline   Reply With Quote
Old 02-02-2013, 12:38 PM   #15918
mdlak
Oddometer: 201
Kyle IS cool!
Great pic!
mdlak is offline   Reply With Quote
Old 02-03-2013, 08:31 AM   #15919
AirCommando
AirCommando's Avatar
Oddometer: 44
Inmates, here is the gas lines that came with my used TM40. Which goes to the tank and what's is the other one for?
Thank you.
RJ Nelson
'09 R1200GSA
AirCommando is offline   Reply With Quote
Old 02-03-2013, 08:41 AM   #15920
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,036
Thank you.
That is a T setup for dual petcocks like on the big Acerbis tank.
Old 02-03-2013, 08:56 AM   #15921
AirCommando
Oddometer: 44
Thanks for the info. Any recommendations on where to attach the choke cable?
RJ Nelson
'09 R1200GSA
Old 02-03-2013, 11:57 AM   #15922
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,036
Some place it will reach and you can reach with the tank on. Make sure it doesn't pull on the 90*, fragile plastic that breaks easily.
Old 02-03-2013, 03:49 PM   #15923
pwrtrippin
Oddometer: 446
TM40 cable choke
Right about here, it takes a little tweak to the bracket but ends up under frame line so its safe from boots, branches etc. Also can turn it off with the side of your boot.
Me for a Politically Correct free America.
There is nothing manly about tassels.
pwrtrippin is offline   Reply With Quote
Old 02-03-2013, 03:52 PM   #15924
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 540
Thank you.
Same question but maybe from 0-1000' elevation?
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 02-03-2013, 05:32 PM   #15925
HeadShrinker
Lost for a Reason
HeadShrinker's Avatar
Oddometer: 1,476
Just picked up this 03 and shredded my plate the first time out...
Where has she been all my life???
HeadShrinker is offline   Reply With Quote
Old 02-03-2013, 05:49 PM   #15926
jm-2008
jm-2008's Avatar
Oddometer: 513
[QUOTE=AirCommando;20633361]I just purchased a used MIKUNI TM40 and was hoping to get some inmate info on initial settings.
Thank you
This works well for mine -
Pilot = 25
Pilot Air Jet = 1.1
Jet Needle = 9DJ1 third groove down from the top (plastic washer underneath)
Needle Jet = Y4
Main = 140
Mainly ride around 2-4000 ft altitude
Side cover stock
Exhaust stock - uncorked (think the US versions you need to take out the centre of the cap with a hole saw)
Stock ignition
The settings above will get you in the ball park and from there its little steps at a time.
Good luck.
jm-2008 is offline   Reply With Quote
Old 02-03-2013, 05:53 PM   #15927
CharlieXR4
CharlieXR4's Avatar
Oddometer: 57
I just picked one up myself
CharlieXR4 is offline   Reply With Quote
Old 02-04-2013, 07:28 PM   #15928
AirCommando
Oddometer: 44
MIKUNI TM 40 idling problems.
Here is my situation:
I am at 2000'. I am running a 22.5 PJ and a 1.2 AJ. The pilot screw is set at three turns open per the manual as a starting place for tuning.
The bike starts fine on the first kick and idles with the choke on. It dies shortly after the choke is turned off.
With the choke off the bike will start momentarily and then die. If I catch it running with the throttle it will rev and is rideable. Coming back down to idle it dies.
I am wondering if it could be the float level, the manual does mention a too high of a float level making idle tuning impossible.
Second question, what is a good initial place to set the idle adjuster. Once it is idling of course.
Any thoughts are appreciated.
RJ Nelson
'09 R1200GSA
Old 02-04-2013, 11:38 PM   #15929
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
Can xrr carry weight?
i reckon they can now
the added plate near the bolt mount will stop a lot of the side flex causing the ally to fatigue
nice work poppy
Sean-0 is online now   Reply With Quote
Old 02-04-2013, 11:41 PM   #15930
Beserker
Red Rider
Beserker's Avatar
Oddometer: 94
nice work poppy
Indeed...how much does it weigh compared to the stock item?
Beserker is offline   Reply With Quote
Times are GMT -7.   It's 05:11 PM.
