02-21-2013, 09:19 PM
#16141 | |
Oddometer: 1,382
DON"T run it! Sounds like your oil pump is rubbing on your cover. I bet there are marks if you take it off. You can maybe mill this down, but at this point you might want to find a used one, or buy a new cover. I know it sucks, but consider the option. Pump does not have to be primed but many on here (including myself) hold the decomp in and kick it a good 10-15 times after changing the oil to hopefully pump the oil into the lines. Another topic under discussion is kicking while drained to remove oil form the lines (put bolt back in or it will spray out). About 200 mls comes out after doing this. I do it and button it up and do priming kicks. You can feel slightly more resistance after a few kicks. I think it helps anyways.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
02-21-2013, 09:26 PM
#16142 | |
Oddometer: 102
Anybody got a right crank case cover off a spare engine they wanna sell? HAHAHA. |
02-21-2013, 09:50 PM
#16143 | |
Torque Junkie
Oddometer: 3,565
02-22-2013, 07:10 AM
#16144 | |
Pumpkinhead ;-)
Oddometer: 455
Medisyn, My fault, I forgot to tell you this. The skimming is only possible when it's less than the axial play of the pump-rotors in the housing, and I skipped telling you how to measure this. It appears that the pump-parts are lodged-in solid now, so please don't start it. You must buy another/new cover, I'd not skim the pump's parts. Sorry for my incomplete advice! |
02-22-2013, 09:57 AM
#16145 | |
Oddometer: 102
I have been ordering my parts on partzilla. Where does everybody go online to get theirs? The prices seem pretty good. |
02-22-2013, 10:38 AM
#16146 | |
Solo con rambo
Alan My ride reports 2000 Xr650r Supermoto/dualsport ![]() 1991 Dodge Oversize...err 250 4wd Diesel ![]() 1985 me |
02-22-2013, 12:40 PM
#16147 |
Wannabe.
Oddometer: 739
Just got out on the inaugural run on my new XR. These bikes are beasts!! Not that you all didn't know that already.
Question for you all; everything worked great except after about an hour or so out, it would die when idling. Not that big of deal when I was out in the desert, but not nearly as fun when I'm at a stop light on the way home and it dies just as the light turns green. Any ideas what I should look for? Since it is new to me, I plan on changing the oil and checking the valves before my next ride. I would have done that all before this one, but I wanted to get out for a bit while I had the chance. Here it is:
02-22-2013, 01:11 PM
#16148 | |
Oddometer: 609
Ah yes, Henderson, NV. You aren't one of those flatbillers are you? Henderson is lousy with them.
Die at idle? Stock carb? The ususal answer is to clean the carb, which I think should be done yearly anyhow. Adjust your air screw (or it may be fuel screw). Once setup correctly, the stock carb is wonderful for a non-pumper. Someone will suggest checking your valve clearance, even though you planned on that. How does the plug look? Also, there is a mod to the stock carb that may help. Basically disable the decelerator valve. Borynack had the process on his website, but good luck finding it. Its not hard, but I can't remember the steps. Nothing more than putting some silicon in a hole. Don't let it idle too slow, its not good for it. If you make it to Lincoln county, let me know. I know a few good rides. Quote:
02-22-2013, 02:08 PM
#16149 | |
Oddometer: 1,382
As in walking around with DC shoes drinking a Monster or Redbull?
02-22-2013, 02:46 PM
#16150 | |
Wannabe.
Oddometer: 739
I'll add "clean the carb" to my list of crap to be done. Sent from my Nexus 7 using Tapatalk HD |
02-22-2013, 02:54 PM
#16151 | |
Oddometer: 609
Do you ever wonder why you see people drinking energy drinks when it looks like they don't even have a job? Bingo! But being that he's got a XRR, he is probably imune to the disease. Doesn't fit the M.O. ![]() And even then, I still got friends that could be considered FBs. So I try not to be too harsh. crypto666 screwed with this post 02-22-2013 at 03:06 PM |
02-22-2013, 02:58 PM
#16152 | |
Oddometer: 609
Don't worry, you aren't. We welcome all either way, and weed em out as we go dow nthe trail. Note what your jetting is while you are in there, and clip position. Oh, and don't forget to check the screws in the choke plate. Locttite them good, or get rid of the little flapper thing al together. The choke works without it. You will see what I am talking about, hopefully, because I am not really sure what I am talking about anymore. BTW, I party with your mayor Andy. He is a neighbor at certain times of the year. |
02-22-2013, 05:25 PM
#16153 |
Wannabe.
Oddometer: 739
I figured that's what you were talking about. I don't take the time to break down the different sub-categories of douche's (like flatbillers). I'm just lazy and call them all douches.
I've never messed with or cleaned a carb before, so I'll take it slow and see what's going on in there once I get some time. Thanks for the suggestions. |
02-22-2013, 05:30 PM
#16154 |
Oddometer: 1,382
No better time then the present. Just be careful not to strip bolts. Some of them can be pretty soft. Also don't lose any parts or bend anything. You'll see what I mean. Just don't man handle it and you should be fine.
02-22-2013, 08:03 PM
#16155 |
Kicker Brother
Oddometer: 3,072
I was and still am a noob on carb's
Clean work bench .correct size tools for the job ..nice clean cloth on the bench .righty tighty lefty loosey i work left right as i remove parts they go in order on the cloth in order as i remove them then its easy to put back together .. the first time i did it i took load of pics then just worked back ....great success |
