Old 02-26-2013, 06:45 PM   #16201
worldrider555
worldrider555's Avatar
Oddometer: 437
Originally Posted by mitchn06 View Post
quickie: do you have to remove the engine from the frame to remove the cylinder? thanks
Nope, all top end work can be done in situ.
worldrider555 is online now   Reply With Quote
Old 02-26-2013, 06:52 PM   #16202
Shibby!
Oddometer: 1,656
Originally Posted by nigelcorn View Post
I'm not very good mechanically, I'm learning this stuff as I go along. Anyone see any problems with this?
It's not great. Lots of carbon and appears to be a worn electrode.
I'd consider adjusting your jetting and putting a new plug in. That much buildup could/is likely oil consumption too.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 02-26-2013, 06:54 PM   #16203
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 804
Yeah, I'd planned on putting a new plug in. I'll see what's going on with the jetting. I haven't seen a lot of spark plugs before so I don't have much experience, but this does seem to have a lot more carbon build-up than the others I've seen.
I really hope it isn't burning oil, I've already had to deal with one bike burning oil that turned into a nightmare.
nigelcorn is offline   Reply With Quote
Old 02-26-2013, 06:54 PM   #16204
mitchn06
mitchn06's Avatar
Oddometer: 551
Thanks i was able to squeeze it out.
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 02-26-2013, 08:50 PM   #16205
Shibby!
Oddometer: 1,656
When was the plug last changed?
Just keep an eye on oil level. See if your buddies see puffs of smoke under hard acceleration, etc.
These bikes are pretty tough.
Old 02-26-2013, 09:29 PM   #16206
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 804
Not sure, I just picked it up a week or so ago.
Sent from my Nexus 7 using Tapatalk HD
Old 02-27-2013, 09:58 AM   #16207
crypto666
Oddometer: 1,231
Make sure to brief yourself on how to check the oil. Sounds stupid I know, but a lot of us started out by over filling our bikes.
Basically, just take it fo spin around the block before you check it. Do not start it and run it for 1 minute and shut it down thinking its good, because it won't be. Also, with the bike sitting on the kick stand, it can never scavage all of oil from the case.
Warm weather in 3, 2, 1, awesome weekend ahead. Hopefully the doctor doesn't tell me I am off the bike for rest of the season.
crypto666 is offline   Reply With Quote
Old 02-27-2013, 10:06 AM   #16208
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,562
That one is worn out and it looks like it wasn't fully tight, close, but not fully...that's why the threads are black.
Check for a stuck open thermostat, it will make the engine run too cool and cause carbon buildup about like that.
larryboy is online now   Reply With Quote
Old 02-27-2013, 06:09 PM   #16209
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 804
Buddies? What are those?
Yeah, I had read about that. I think I've got it figured out, but I'm waiting until I get the engine all back together and a new spark plug before I start it so I can change the oil.
Thanks for the tip on the thermostat, I'll check it out. I've read that can be a common problem with these bikes, particularly the earlier ones. I have read of some people just taking the thermostat out, and then making sure it gets a good 5 minute or so warmup before taking off. Any thoughts on that?
I know the best would be to buy a new thermostat, but if we hypothetically pretend that my wife hates motorcycles and the less I have to spend on this one, the happier she'll be--would it be ok to take out a stuck thermostat and just warm the bike up really good before riding it?
Old 02-27-2013, 06:26 PM   #16210
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
I loved the maxis desert it tires when they were fresh, but had terrible luck with them chunking here in az. Tried three sets, and they all did the same thing, but mostly the side lugs on the front.
I now run the mx71's and have zero complaints.
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 02-27-2013, 07:45 PM   #16211
Shibby!
Oddometer: 1,656
Are you sure they were the DESERT IT's?
I've had issues with the normal ones chunking, but never an DESERT model.
Between myself and my friends we have over 45,000 KM's on them..
Old 02-27-2013, 08:57 PM   #16212
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
positive. it's the only tire i'd run for a while because i liked them so much. until i got tired of the knobs ripping off either entirely or partially before the tire was worn.
i do ride on a LOT of rocks and decomposed granite. pretty much like 5 grit sand paper.
Old 02-28-2013, 10:23 AM   #16213
cognugget
cognugget's Avatar
Oddometer: 243
My dual sport. Soon to come, baja designs speedometer, LED lighting with High Low dimmer.
cognugget is offline   Reply With Quote
Old 02-28-2013, 11:05 AM   #16214
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,562
It'll run even cooler and carbon up worse without the thermostat in there. Search for the NAPA part number, it's cheap to put a new stat in it and it runs better with it.
Old 02-28-2013, 02:27 PM   #16215
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
it'll run even cooler and carbon up worse without the thermostat in there. Search for the napa part number, it's cheap to put a new stat in it and it runs better with it.
+1
Times are GMT -7.   It's 10:52 PM.
